Question about Dyson DC07 Bagless Upright Cyclonic Vacuum
No suction at base...
Yup. Looks like several people had this problem.
I have the animal (purple) version. I've cleaned the beater and it spins well also check the hoses - no obstructions (or holes).
Works fine if I use the wand - but that's not too practical for the entire floor!
At the cost of a replacement, I'm pretty frustrated about now.
    Sergeant:
  • 197 Answers
Take the sole plate off and check for blockages - where the transparrent hose connects to the beater compartment
Are the filters clean?
Make sure the bucket is properly aligned to the main body
Make sure the inspection covers are clear and properly fitted.
They has be a blockage between the beater bar and the main hose which works ok.
Still no good?
Come back to me
Posted on Sep 10, 2009
Testimonial: "I'd tried all the things you suggested then had my husband do it all again - seems the little clear hose was not on thoroughly. Thanks 4 your reply!"
I have a DC41 Animal. It has suction through the hose. When I try to vacuum it stops sucking through the hose but seems to have no suction in the base and the beater roller doesn't work.
Check for a clothes peg at the motor iintake port. They can get that far then jam at the curve so tight youll wonder how you missed it. It will drastically reduce suction yet not cause a clog , and you can't see it
Feb 09, 2017 | Dyson DC41 Animal Bagless Upright Vacuum...
Very little suction at beater brush.
Hey, this is Leland with Crucial Vacuum,
If the brush bar is not working properly there may be several reasons.
Firstly, the motor may be the problem. If you hear any noises while the machine is running, you should contact the original manufacturer for trouble shootingsolutions.
Secondly, your vacuum may be in need of new parts. By changing either the brushroll or belts, you should be able to increase the quality of the suction.
You can purchase replacement parts for the DC17 direct from Crucial Vacuum with freeshipping and an exclusive 10%coupon for Fixya.com readers, use code: FIXYA10
http://www.crucialvacuum.com/catalogsearch/result/?q=dc17
Feb 11, 2016 | Dyson DC17 Animal Bagless Upright Cyclonic...
Why does the suction stop after 10 minutes of use on my Dyson DC43?
Your vacuum may be overheating and shutting off the suction motor. Clean the cyclone assembly and the filters to see if they could be restricting the airflow.
Jun 18, 2014 | Dyson DC43 Purple Animal Bagless Upright...
A burning smell when in use
Martinsivyer:
Turn the machine upside-down and see if you can turn the beater/brush bar with your hand. You should see the brush turning and feel the resistance from the motor. The brush/beater bar may be binding, and what you are smelling is the motor shaft spinning against the rubber belt. You can remove the base plate and check the brush/beater bar with the belt disconnected. If the brush/beater bar is difficult to turn, you need to remove the brush/beater bar and clean the bearings at each end, Remove any threads that are wound around the beater bar ends so that the bearings roll easily and smoothly. Check to see that your machine is not set too low for the surface that you are bacuuming. While you have the belt disconnected, check thi inside surface to see if the motor shaft has been spinning against the belt, you'll see the damage to the inside circumfrence of the belt.
Oct 21, 2012 | Dyson DC07 Animal Bagless Upright Cyclonic...
Low suction
Hi Megan,
I'm sorry to hear you're having difficulties with your DC17. If it doesn't seem to be picking up as well as usual, you may have a blockage somewhere in the machine. To check for this, please follow the steps shown in our online support guide:
http://www.dyson.com/support/help.asp?article=954&product=DC17-ANIMAL
Although I note you've already cleaned the filter, please see the video below to check you've done it correctly. In normal use, the filter should be washed at least once every 3-6 months in cold water. Don't use detergent, and allow at least 24 hours for it to dry completely before replacing it.
This should resolve your issue, but if you need any further assistance, please call us free on 1-866-693-9766, or email askdysonUS@dyson.com so we can help.
Kind regards,
Jack
Dyson Online Customer Support
Dec 18, 2011 | Dyson DC17 Animal Bagless Upright Cyclonic...
Dyson Animal, purple ball, no suction upright
you might be missing a blockage in the hose from the brushes to the dust collector Take apart the hoses and check
Jul 28, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
No suction for rugs but the hose works fine. Removed the canister and suction is at that point
Remove the base plate and beater bar. Clean the suction cavity behind the beater bar. That's where they almost always plug up.
--W.D--
Aug 19, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Hi the suction on my dyson hoover has gone very poor. I have cleaned all filters but suction is still pretty poor.Is there anything else i can do?
your problem with Dyson is the reason why a lot of them end up in the trash. here is the link to an article that will help you locate the cat fur, or hair or other debris that is lurking inside your machine and causing you to loose suction
http://www.insanityideas.com/blog/Thursday-24-March-2005
Aug 14, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Dyson DC07 Bagless Upright Cyclonic Vacuum Logo
67 people viewed this question
Top Dyson Vacuums Experts
AskDyson
AskDyson
Nick Olsen
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
