Question about HP LaserJet 9040mfp All-In-One Printer
When intering a fax # it says reconfirm # ,then
When intering a fax # it says reconfirm # ,then have to enter again. How come? For HPlj9040MFP
After following instructions on how to renew by entering product key ..to complete what then? how do I know it is renewed???
If it is renewed, u will see a message which says "Renewed successfully". You can also reconfirm by checking the subscription period.
Feb 27, 2015 | Symantec Norton Internet Security 2008:...
How do I register my fax machine
Dear
As the model and make was not mentioned so in general the setup is done as bellow.
Press FUNVTION or MENU key and scroll for fax setup.then press OK or ENTER. The corresponding display is self explanatory and input the keys for setting ID and nos. May be done as in standard mobile phone.
Thanks.
Feb 04, 2015 | Panasonic Office Equipment & Supplies
We a incoming fax comming, we don't get fax but fax call report with "comm error 392"
Assuming you have an HP laserjet, you can either try again in a little bit or disable v.34 on your machine and use v.17 instead
Perform the following to turn V.34 off and access the lower speed of the local machine.
1. Press the ENTER/MENU button one time.
2. Press the or > button until the front display reads "Fax Setup".
3. Press the ENTER/MENU button.
4. Press the or > button until the front display reads "All Faxes".
5. Press the ENTER/MENU button.
6. Press the or > button until the front display reads "V.34".
7. Press the ENTER/MENU button.
8. Press the button until the front display reads "Off" and then press the ENTER/MENU button to save the setting.
Feb 28, 2011 | Office Equipment & Supplies
My hand set states it is not connecting to the base, This is with-in 5 feet. It worked before, now nothing. whats up? I've tried to reset everything.Even let the battery go down then retried again and...
Hi, if you have tried the best solution which is resetting the handset and it still does not connect to base, entering a new or the old code won't make any change a solve the issue. Then you have to contact the technical department of the phone company to make a report....
Oct 03, 2010 | Office Equipment & Supplies
I forgot my nokia 2600c security code. please help me.
You will observe that after entering a wrong code thrice, it will demand for your puk code, this puk code is at the back of your sim pack.
You will see where puk code i written at the back of you sim pack. enter this puk code on your, it will tell you to reconfirm, enter it again, your phone will be unlock and you can now start operation.
Take care.
Apr 14, 2010 | Nokia 2600 Classic Cell Phone
How do I set up the fax to print a confirmation (comm journal) for every fax sent?
Press Function, enter 74 from keypad and hit the middle SET button in circle.
FAX PARAMETER should appear.
Enter number 012 from the keypad, hit SET
The value should be 2 for printing a journal always.
If it's not (default is 3 - only when unsuccessful), then enter 2, hit SET
Press Function again to go out of the menu.
That's it :)
Oct 28, 2009 | Panasonic PanaFax UF-8000 Laser Fax
HP Laserjet 3330 w/ green fax light staying on and orange cancel light blinking My Fax is not reciveing and every time someone trys to send me a fax it says Busy. What can i do to fix this problem so my...
start it up again from the power source, press the menu enter button to get to service , use the < button, under service, press menu/enter, browse to service: restore defaults, press menu/enter twice.
It works, give it about 2-3 minutes to finish rebooting, it will continue flashing and then go away
May 28, 2009 | HP LaserJet 3330MFP All-In-One Printer
Storing numbers in speed dail for the Savin Fax 3699
1. Press "USER TOOL"
2. Press 1.
3. Press 1 again
4. Enter 01
5. Press a free Quick Dial key
6. Enter the fax number.
7. Press [Name]
8. Enter name for this Quick Dial
9. Press [OK]
10 Press [OK] again
11 Press [PrevMenu]
12 Press [PrevMenu] again
13.Press [Menu]
14.Press[Exit]
Aug 18, 2008 | Office Equipment & Supplies
HP Laserjet 3030 printer/scanner/fax Language has
press Enter bottom
press left arrow key twice
press enter key
select the language you need then press inter
Mar 25, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 9040mfp All-In-One Printer Logo
Seeker5211
Seeker5211
