Question about Troy Bilt 5.5hp Self Propelled Mower
Self propelled unit , will no engage - Troy Bilt 5.5hp Self Propelled Mower
  • 472 Answers
YOUR BELT COULD BE BAD OR THE CABELL MAY BAD IF YOU FOLD YOUR HANDELS THATS WHAT IT IS
Posted on Sep 30, 2009
My yard king performance 675 series has problem with self propelled unit.
your drive belt that turns the self propelled unit is worn or stretched and not turning the gears. or the gears themselves are worn down causing them not to engage. check your belt first that is most likely your problem. hope this helps
Sep 11, 2015 | Kelty Yard King 21" Push Lawn Mower w/...
John Deere JS-35 self-propel will not engage now. Help!
Check under the cover of the self propel unit to see if the belt is off the bearing or broken.
Feb 04, 2018 | Garden
I have a Toro self propelled walk behind mower model # 20016. The self propelled just stopped working. My owners manual does not mention anything about the self propell. Can you direct me as to what to...
Toro 20016 self propelled walk behind when the wheels are engaged it moves, when the wheels are not engaged, the wheels look up.
What should I do to fix the problem
Apr 19, 2011 | Toro Lawn Boy Self Propelled CARB Walk...
Limited self propell
The self propel cable needs to be adjusted. This can be done with a 7/16 wrench. loosen the nut that holds the self propel cable in place. You may need to pry this open with a screwdriver. Don't overdo it or you could break the plastic. Once the cable is loose pull it toward the mower deck, once the slack is out of the cable press the self propel handle in about a half of an inch. This should be close to what it was from the factory. Then re tighten the nut. And check the self propel to make sure it is engaging properly. If you hear a grinding noise when trying to engage the transmission then you will need a new transmission. Depending on if it is a front or rear self propel the part alone is either $60-$75 retail. Most repair shops will charge an hour to do this repair. I hope this answers your question.
Mar 24, 2011 | Toro Lawnmower 20099 Mower Mowers Lawn
Self propel issue ????
The gear drops and lowers blade slightly until the gears are changed and engaged.
Aug 14, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Self propel issue's
I am not sure what the problem is but may be. A couple of things I would do is check and make sure that every thing with the self propel is as it should be like springs not broken or bad connectors. Also I would make sure that all bolts are tight that holds the self propel unit. The first thing I would check is see if all the wheels are at the same height.
If this doesn't help I would go to the Troybuilt web site and see if they have tech support, or see if they have a phone number under contact and call them and talk to some one there.
Good luck. I hope this helps.
roundo4
Self-propelled feature does not work at all! Any suggestions?
You might have a broken belt to the self propelled or a broken spring or whatever engages the self propel. Take off the cover and see if anything is broken or missing. Have someone engage the self propel while you are watching and see what is going on.
roundo4
Aug 12, 2009 | Toro Lawn Mower With Toro Power Tools
Self Propelled mower quit self propelling
you probaly have a broken gear or engagment lever. the part the cable goes through before the cable goes thru the deck. you also could have sheared a pin or the plastic gear that drives it.
Jul 02, 2009 | Troy Bilt 5.5hp Self Propelled Mower
If you take the wheels off and remove the belt from the small pulley on the the front axle underneath the pulley you should see a small transmission. You usually can split this unit in half . You will see two gears and sometimes one plastic and one metal. The plastic one is usually the culprit. Hope this will help you out. Donnyb60
Mar 18, 2009 | Toro Lawn Mower With Toro Power Tools
Snow Thrower does not self-propel
Did you check under the handle area, near the blower itself for a transmission lever? This will engage & disengage the transmission.
Jan 25, 2009 | Mowtownusa Snow Thrower Starter Switch for...
Troy Bilt 5.5hp Self Propelled Mower Logo
88 people viewed this question
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
