Question about Canon i9100 InkJet Photo Printer
Printer prints color, but not black even with new cartridge
Prints prints color text of graphics, but does not print black text. I installed a new black cartridge, but the problem persists
  • Canon Master
  • 739 Answers
First thing to do is a head clean then do a test print. Do you see any of the black lines?
If not, don't do a deep clean as this uses up too much ink. Remove the ink cartridges and then remove the print head unit.
Run the print head under a hot tap for a few minutes until all the run off is clear. Take it outside if you can and shake it dry vigourously. You can use paper towel if you like but try not to wipe across the nozzles. Make sue the contacts are all dry and refit it to the printer. reinstall the ink cartridges and print a few test pages - the first couple may well be wasted but then it should start to print properly.
Is the black still missing? If it is do another head clean and another test print. Any improvement? If you start to see some black do some more head clean routines and it may well come back to normal. If on the other hand you see no trace of black at all, it could be that the print head is worn out and needs replacing.
This printer is now of an age where the print head may well be failing. Mine had to be replaced last year as one of the colours stopped printing.
The head is not exactly cheap - but it's cheaper than buying a new A3 printer.
Posted on Sep 10, 2009
My canon MP145 three-in-one printer cannot print because the coloured ink has finished. How can i continue to print using black ink only?
Hi joyce2020
Some printers do print even if one cartridge is empty.
This is what you have to do. Goto the print setting page. you will find check boxes for Print in Color OR Black& White.
Usually, the color box is checked. When you check the box for color, you can print in black and white as well provided the text is written in B&W. If you check the B&W, the printer will print everything in black including color text and graphics.
Hope this will work for you.
Good Luck
luciana44
Apr 10, 2010 | Canon PIXMA MP150 All-In-One InkJet...
Hp c4480 prints blue instead of black
Check the print properties and verify the black ink cartridge still has ink in it.
Otherwise, you may have a bad ink cartridge. If the cartridge has not been used for a while, the ink gums up the nozzle. You can try cleaning the ink cartridge and slot with alcohol. However, new color and black cartridges may be the best solution.
May 02, 2009 | HP PhotoSmart C4480 All-in-One Printer ...
Prints only color ink nothing in black
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Lexmark X75 All-In-One InkJet Printer
I have a Lexmark x1100 Series printer and cannot print anything now. This printer has been working but it stopped printing. Do not have the CD.
Need more info. Any error messages? Did it just stop pumping ink on paper. Are you trying to print black text or color picture? If no error, your cartridges may be empty. If black text does not work, try color picture. Usually one cartridge goes empty and the other still has ink. If color pic prints replace black cartridge. If neither black or color prints at all, it may be a toasted printhead
If you need to reinstall the software, uninstall it, then go to lexmark.com and get new drivers from their site. RESTART COMPUTER! Reinstall from the downloaded file.
If all the above fail to make it work, it is hosed, shop for new printer.
Dec 09, 2008 | Lexmark Office Equipment & Supplies
Printing RAINBOW of colors!
Change the color cartridge and see what happens.
Aug 06, 2008 | HP Deskjet 6940 InkJet Printer
Canon i560 won't print black text anymore
I have now found the solution elsewhere in the internet: black text only prints on the Canon i560 if selct "normal paper", but not,for instance, if you have "professional photo-paper" selected.
Apr 16, 2008 | Canon BubbleJet i560 InkJet Printer
Cartridge/Printer problem - very weird (HP PSC 1315)
quiet easy you have to change you print selection to all or everyday printing that way it will print both color and black all together instead of not this and that
Mar 23, 2008 | HP PSC 1315 All-In-One InkJet Printer
Print Out
yes replace the cartridge it appears the cartrige is defective
Dec 06, 2007 | Dell 924 All-in-One InkJet Printer
Prints black on test page, but not when a job is sent to the printer
make all your printer settings to default. If any problem in that simply uninstall & re-install the driver.
If still no good, your black cartridge might have dried-up
Oct 18, 2007 | Canon BubbleJet i560 InkJet Printer
Canon i9100 InkJet Photo Printer Logo
199 people viewed this question
old marine
old marine
