My acer one wont connect to my wireless router but will to any other router in the area, even if i unsecure the network it wont connect
    President:
  • 1,179 Answers
Check to make sure that your router is compatible with the card installed in your acer. If your router does not support what the acer is putting out then they will never work together and your only option would be to buy a new router that would be compatible with all your equipment. Hope this helps.
Posted on Sep 10, 2009
Acer E1-531 can connect to wireless but not through ethernet connection, amber light is blinking and green light is idle
Are you very far from wireless router? Also check which wireless signal is the strongest and if that is yours. Unsecured w/less are usually weak in residential areas. Again is your internet high speed?
Dec 13, 2013 | Acer Aspire E1-531-4444 15.6" Notebook...
Wireless connection
Turn off the laptop, unplug, remove battery, plug in. Push and hold the reset button for 30 seconds or so on the Netgear to reset to default settings. Boot laptop, when boot is complete, Open Network and Sharing Center, click on Manage Wireless networks, remove your OLD wireless network. Close Network and Sharing Center. In your Tray Notification Area , left click on the network icon, select unsecured Netgear Wireless Network. When connected, reconfigure SSID and Security Password.
Dec 16, 2012 | Acer Aspire 5742Z-4200 Notebook
My computer doesnt want it connect to internet,, appear the connection icon but when the page try to open , it cant do
Please follow the steps provided below:
Q: Basic Wireless Troubleshooting
A:
The following steps will help determine if the wireless card in the system is functioning properly.
IMPORTANT:
Please go through all the troubleshooting steps. If the wireless card is functioning properly, please check the network configuration. Acer America can not assist with configuring the network.
Before you start:
  • Make sure there is a wireless router or wireless access point.
  • The wireless router/access point is plugged in.
  • Refer to the owners manual to ensure the wireless adapter is on (you can turn the wireless card on and off by pressing a clear button)
  • Contact the internet service provider to make sure ther account is active and the network is connected in a way that supports their configuration.
If the computer was working properly at an earlier time:
If the laptop was working fine, do a System Restore which rolls the system back to the last known working configuration. System Restore is located in System Tools under Accessories. Here is a link to explain the use of this feature:
http://support.microsoft.com/default.aspx?scid=kb;en-us;306084
To find the wireless network:
1. Click on Start winxpstart%20button.jpg then click on "Control Panel."
xpmenu.jpg 2. In the Control Panel window, click on "Network and Internet Connections."
3. In the "Network and Internet Connections" window, click on "Network Connections."
networkconnect.jpg 4. Once in Network Connections, right-click on the wireless connection then select "View available wireless networks"
5. If the wireless network is a secured network, please refer to the manual of the wireless router to make it unsecured for the purpose of testing the wireless network.
NOTE: Acer does not recommend leaving a wireless network unsecured and is not responsible for data accessed due to unsecured wireless networks.
6. If the wireless network is listed, the wireless adapter is functioning properly. If unable to connect to the wireless router, go through "Before you start" at the beginning of this article.
Mar 05, 2011 | Acer Aspire 5100 Notebook
All internet connections failed with Acer Aspire One with Linux
Atheros AR5007EG adapter only WEP compatible. Wireless networks using WPA(2), or anything else won't work. If network is unsecured, it should connect.
Dec 30, 2008 | Acer Aspire One AOA150-1570 Notebook PC
ACER 5720 WIRELESS CONNECTION PROBLEMS
can you pull up your router, I had this with an acer last week, I had set it up on my router then taken it to the clients house and it wouldn't work, the thing was that it never droped my router and was in the my network places several times. as soon as I realized that I deleted all of the routers and anything that wasn't supposed to be there and just went to make a new connection and bingo i worked. also don't forget the encryption key if you put one in you will need it to get on you network, good luck
Dec 27, 2008 | Acer Aspire One PC Notebook
I have an acer aspire and am trying to connect to an unsecured network in a house I now live in. I cannot connect; do I need to change my LAN or wireless router settings? How do I do this?
First after you have a wireless adapter is to install the drivers for it and scan for a wireless network with your wireless address name. Then just connect. If it dosn't connect or if you need further instruction just tell me.
RCF
Aug 30, 2008 | Acer Computers & Internet
Sounds like a bad router or antenna. Try replacing the antenna or checking the connection of the antenna on the router. Have your ISP replace the router and the problem should go away.
Jul 30, 2008 | Acer Aspire 3050-1733 Notebook
I am trying to network my acer with windows vista to the desktop wireless router belkin 54g. My other two laptops worked after making the wireless connection secure but the Acer laptop will not go to any...
Have you verified the wireless card that is in the machine? (Are you certain there is one there?) Even if there is one inside it, the PC may not see it. Go to device manager (My Computer, Properties, Hardware tab, Device Manager button). Then look through the list to find "Network adapters", click the "+" to the left, and it will display a list of adapters present in the machine. Make sure there are no yellow caution symbols or other error icons in any area.
Then, if you can see a wireless card listed, right-click to view the properties. Please post back with the results, and the exact info regarding your PC and the wireless card if you need more help. Otherwise, thank you for using and rating FixYa!
Jul 08, 2008 | Acer Computers & Internet
Netgear wireless router
Hi!
Try these:
1. Go to CONTROL PANEL > MANAGE WIRELESS NETWORKS
2. Remove all the preferred networks
3. Restart your laptop
4. Reconnect to your network
Hope this helps!
May 04, 2008 | NetGear WGR614 Wireless Router
D-Link router wont let me go onto the net with the wirless router
At the bottom right hand corner of your screen, you have a wireless connection icon. right click and view available wireless network...if you see your network there. connect to that network, if secured, then call d-link to verfiy what is your network key. if it is unsecure then you can log on right away.
if that wont allow you to connect then upgrade firmware of router.
Oct 13, 2007 | D-Link DI 514 Wireless Router (DI-514)
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
