It depends on how much you use it. If you use every day all day them change oil once a week and cleaned at the same time. If used rarley then change oil when food tasted not as good as it shood.
I've got a double Imperial 40 lb fryer. I get one pilot lit, go to light the other one and the other one goes out. Also, I sometimes get both lit, turn the thermostat on for one of them and they both go out. Then sometimes have problems getting both of them to light period; the produce a flame but when I release the pilot light button, they go out!
I have replaced the thermopile on imperial fryer. The unit heats up to 325-350, runs good for two or...
(More)
I have replaced the thermopile on imperial fryer. The unit heats up to 325-350, runs good for two or three cycles, then shuts down, pilot and all?
I have a 40lbs Imperial gas fryer.When i fry something in the fryer let said for 10 minutes,the...
(More)
I have a 40lbs Imperial gas fryer.When i fry something in the fryer let said for 10 minutes,the burner fire and the pilot light of the fryer will gone off completely.when the fryer on,temperature control always at 350'c. Could you help me to solve out the problem please
imperial fryer, what to clean with? I am opening up a restaurant, I inherited a fryer that has not...
(More)
imperial fryer, what to clean with? I am opening up a restaurant, I inherited a fryer that has not been properly cleaned. How do I get the old gunk out from under the elements in the bottom? What cleaning products are safe? Can I flush it out with water?
Add the things you own to your My Products collection and get product information, solutions to problems, manuals & guides, tips and how-to's, reviews & ratings and local repair service - all in one easy place.
