Question about Microsoft Windows 95 + Internet Explorer for PC
Steering is sticking will not turn by it self
95 ford explorer some times when I turn wheel will not return to center by it self help !!!!!
    Brigadier General:
  • 10,406 Answers
Microsoft Windows 95 is no longer supported by Microsoft.
Upgrade to Windows XP, or buy a new computer with Windows Vista pre-installed (and with a coupon for Windows 7).
Get your 95 FORD EXPLORER towed to a certified mechanic; it is *NOT* safe to drive the vehicle.
Posted on Sep 10, 2009
Why doesn't steering return to center?
Hi Paul, How is the condition of your front tires? If the pump is whining at higher rpms that will change pressure down at the rack, is the rack a variable assist? My advise would be to get the pump replaced or rebuilt asap, If the pump is whiny or grinding it will send small metal particles through the system and contaminate the rack and pinon etc. Did you flush the system when you replaced the rack? Let me know a little more info, Hope this helps, Good Luck Randy.
Jun 08, 2015 | 1998 Ford Ranger
Steering wheel does not return on turns
jack up the front of the car and see how difficult it is to turn the steering wheels from lock to lock. Allowing for the steering box resistance they should turn freely once you have established movement. If you have power steering you may have to disconnect from the box. What you are looking for here is binding ball joints or king pin bearings . If you are happy that there is no appreciable resistance then have a wheel alignment done paying attention to castor settings as this is what gives the self centring affect to steering. The bigger the angle the harder to turn but the quicker it returns . AS the wheels are turned the vehicle is lifted up because of the angle and when the wheel is let go the vehicle drops back down and so spins the wheel back to centre.. If you have leaf springs in the front I would be checking out the spring camber AS this problem comes from sagging leaf springs turning the axle forward and so putting the castor in negative territory.
Feb 22, 2014 | Ford E-250 Cars & Trucks
I have a 2004 explorer. i get in the car put the key in ignition and turn it. everything turns on but the car. i have to unlock the steering wheel, lift the steering wheel and at the same time turn the key...
Not sure if this helps, but I've seen cases where the steering wheel and tilt assembly loosen up from the steering column. When this happens, the linkage that activates the ignition switch becomes "too short". That's why if you lift the wheel, it "lengthens" the linkage and activates the switch. If this is your problem, the steering wheel has to come off to tighten the tilt assembly bolts. I don't recommend messing with it personally due to the complexity buried inside modern steering wheels (air bag, horn, tilt, cruise controls, audio controls, etc.). Take it somewhere you trust.
Good luck.
Feb 14, 2011 | 1998 Ford Explorer
2000 ford contour. About a week ago when initiating my turn signal it made a noise (the handle its self) and then stopped functioning a bit later. Ever since it has come back to function and not...
on the back side of steering wheel remove screws <2>disconnect battery first so u dont set airbags off.remove front cover .remove bolt in center,then use a steering wheel puller.
Dec 09, 2010 | 2000 Ford Contour
Logitech g25 steering axis not working wheel returns to center
to chk the sensor on the calibration unplug the wheel from the usb port and plug back in if the wheel turns left then right and centers the sensor is fine. go to the control panel>game controller>properties and test the wheel if everything is working there it is a problem with the game. look for a profiler or calibration utility in the game itself to bring back to center.
Jul 17, 2009 | Logitech G25 Wheel And Pedals Set
How to change the power steering on 96 ford explorer
Section 11-02C: Steering Gear, Power Rack and Pinion, Explorer 1996 Explorer with Power Rack and Pinion Steering Workshop Manual REMOVAL AND INSTALLATION Steering Gear SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Pitman Arm Puller T64P-3590-F
Removal
  1. Start engine.
  1. Rotate steering wheel from lock-to-lock (entire gear travel). Record n umber of rotations.
  1. Divide the number of rotations by two. This gives the required number of turns to place system in the on-center position.
  1. NOTE: Verify the front wheels and steering wheel are in the straight-ahead position.
    From the lock position, rotate steering wheel the number of turns determined in Step 3. This places the gear in the on-center position.
    Steering Gear, Explorer
  1. NOTE: Do not rotate steering column when intermediate shaft is disconnected or DAMAGE TO CLOCKSPRING will result.
    Remove bolt retaining the lower steering column shaft to the steering gear input shaft.
  1. Disconnect the lower steering column shaft from the steering gear.
  1. Remove stabilizer bar attachment from frame for clearance to remove gear.
  1. Unscrew the quick connect fittings for the power steering pressure hose (3A719) and power steering return hoses (3A713) at the steering gear housing (3548).
    Power Steering Hose Connections
    Item Part Number Description 1 3A674 Power Steering Pump 2 3A719 Power Steering Pressure Hose 3 3F780 Power Steering Cooler and Hose Assembly 4 3504 Steering Gear 5 5005 Frame
  1. Plug ends of fluid lines removed and ports in gear to prevent damage and entry of dirt.
  1. Remove two (2) nuts from P/S cooler.
  1. Remove P/S cooler from vehicle.
  1. Remove and discard the cotter pin retaining the nut to tie rod end (3A130) and remove nut.
  1. Separate tie rod ends from front wheel spindle (3105) using Pitman Arm Puller T64P-3590-F.
  1. Remove the two nuts, bolts, and washer assemblies retaining steering gear (3504) to front crossmember (5019).
  1. Remove steering gear from vehicle. If required, remove steering gear mounting bracket housing insulators (3F640) and steering gear insulators (3C716) from steering gear housing.
    Item Part Number Description 1 N807881-S60 Bolt 2 385935-S36 Washer 3 3F640 Steering Gear Mounting Housing Insulator 4 3504 Steering Gear 5 N800255-S60 Nut 6 5019 Front Crossmember 7 3C716 Steering Gear Insulator
Installation
  1. If removed, install steering gear mounting insulators into the steering gear housing.
  1. Push the steering gear mounting insulator and steering gear insulator in until there is no space between the lip on the insulator and steering gear housing.
  1. Position steering gear on front crossmember. Install nuts, bolts and washers retaining steering gear to front crossmember. Tighten to 128-172 Nm (94-127 lb-ft).
  1. Position power steering cooler onto bolts and install nuts. Tighten nuts to 68-92 Nm (50-68 lb-ft).
  1. NOTE: The fittings design allows the power steering pressure hose and power steering return hose to swivel when properly tightened. Do not attempt to eliminate looseness by overtightening, since this can cause damage to fittings.
    Connect power steering pressure hose and power steering return hose to appropriate ports on steering gear housing. Tighten fittings to 27-34 Nm (20-25 lb-ft).
  1. NOTE: Make sure the tie rod ends (3A131) are seated in the tapered spindle holes to prevent rotation while tightening nut.
    With the steering gear, steering wheel (3600) and wheel (1007) in the on-center position, attach the tie rod end to front wheel spindle and tighten to 56-76 Nm (77-103 lb-ft).
  1. If necessary, advance tie rod nuts to the next slot. Install cotter pins.
  1. NOTE: Verify that no rotation from the on-center position has occurred.
    Position steering column lower intermediate shaft over steering gear input shaft. Outer input shaft dust shield must be in place. Replace pinch bolt and tighten to 41-56 Nm (30-42 lb-ft).
  1. Replace the front wheel and tire assemblies. Refer to Section 04-04 .
  1. Replace wheel covers.
  1. Lower vehicle.
  1. Refill power steering oil reservoir (3A697) with Premium Power Steering Fluid E6AZ-19582-AA or equivalent meeting Ford specification ESW-M2C33-F.
  1. Purge air from steering system. Refer to Section 11-00 . Verify absence of any unusual power steering noise.
  1. Check and adjust toe alignment specifications. Refer to Section 04-00 .
  1. Make sure steering gear operates correctly and is not leaking.
  1. Check and adjust fluid level in power steering oil reservoir.
Jul 10, 2009 | 1998 Mercury Villager
Steering sticks when turning
sounds like either the camber or caster is off on your alignment or possable you got your steering gear box adjustment too tight .. this will cause it to not return to center.. thanks and holler if you have more..
May 18, 2009 | 1981 Chevrolet Corvette
1965 Mustang Pwr St doesn't return to center
I've got a chilton's 1965 -up manual, I'll have a look for you, and get back.
Mar 29, 2009 | 1966 Ford Mustang
Steering issue
Your steering rack has a leaky internal seal, you will need to replace the rack and flush the system to remove any debris fro,m the failed rack.
Sep 16, 2008 | 2004 Volvo XC70
Microsoft Windows 95 + Internet Explorer for PC Logo
56 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
