Question about Bissell 1425-1 Little Green ProHeat Canister Wet/Dry Vacuum
How to operate - Bissell 1425-1 Little Green ProHeat Canister Wet/Dry Vacuum
  • 22 Answers
Here is the link to the manual for your little green machine. :)
http://www.bissell.com/images/UserGuides/1400_1008.pdf
Posted on Sep 15, 2009
How can i extend operating time on dc59 vacuum cleaner it only operates for 8 minutes, can i use a second battery?
2nd battery does not seem to be a viable option, reduce the suction power if u require less and it should work for 25 minutes approximately. (hope u know it automatically stops when dust the cup is full)
Jun 03, 2016 | Dyson DC59 Animal Bagless Cordless Stick...
.65A Fuse for Beaumark Microwave
You can buy it through electronic shop and look for that ratings. When you install it to the microwave and operate it without blown, you'll sure the microwave is back to normal operation. But when you install it and operate then the fuse is blown again. Then problem is there's a shorted in microwave circuit.
Thanks for asking.
Jul 07, 2011 | Vacuums
Bissell powersteamer
BISSELL User's Guides can be downloaded at www.bissell.com
On the front page under Customer Service click on User's Guides and enter the model number of your unit.
User Guide will be displayed as a PDF file.
Jul 09, 2010 | Bissell 8806 Powersteamer Upright Vacuum
The machine turns on and the indicator seems to be spinning but the water is not moving.
Operating the trigger does not dispense water into the spinning brushes - is that the problem?
If so, remove the clean water tank and look in the opening behind the black grommet that seal the water tank. Operate the trigger and look to ensure that the valve is operating (moves downward when trigger is pulled). If it does not move, the trigger shaft is stuck or broken and will need to be repaired.
Nov 21, 2009 | Hoover SteamVac F5914-900 SpinScrub...
How to operate bissell carpet cleaner.
Look at the Bissell web site. You can enter the model number and get the operator's manual for Bissell products.
May 27, 2009 | Bissell 1699 ProHeat Clear View Upright...
I need an operation manual
http://www.hoover.com/pdfs/manuals/F5915900.pdf
Apr 24, 2009 | Hoover SteamVac F5914-900 SpinScrub...
I need basic instructions on how to operate a Dyson.
Copies of Dyson Operator Manuals are accessible on the Dyson website.  You will find everything you need there!
Feb 06, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
How it works
Yes, your Roomba has an embedded operating system and you can read about hacking it here:
http://hackingroomba.com/
May 28, 2008 | Roomba Vacuums
96 v6 mustang a/c only comes from top of dash unable to control
This could be caused by a loose or broken vacuum line or a broken vacuum operator. It is also possible that the a/c switch assembly is defective. You'll have to inspect. If you want to know if a particular operator is working, use a piece of tubing attached to the operator and **** on it. If you don't feel a vacuum, the operator is bad. Hope this helps...but without actually working under your dash, this is the best I can do. Try your local library for a copy of the manual and vacuum diagram.
Mar 19, 2008 | Vacuums
Cannot shut vacuum on hose
Will the main unit operate if you switch to manual operation. If so, then it could be that the PC board has a stuck relay and you will have to replace the PC Board. Could be the switch inside the handle. You take your hose to your local dealer and or someone that you know that has a beam system and plug it in and see if it works or not. If it does, then it is in the main unit, if it doesn't. then there is a problem with the hose or switch asm.
Nov 21, 2007 | Beam Industries 2775 Serenity Plus Central...
Bissell 1425-1 Little Green ProHeat Canister Wet/Dry Vacuum Logo
122 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
