Question about Samsung HL-R4264W 42" DLP HDTV
Distorted screen purple swooping stripe on top... screen is distorted. what's wrong? how much? can i fix myself?
  • Samsung Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony, Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit from the link below.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on - TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the button. If it fails to fix the convergence your need to fix it. See below for a solution
93a1209.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you know what you are doing. If you have never done this before we would advise calling a shop or if you want to do it yourself get a complete kit with instructions and support from www.TvRepairKits.com
Posted on May 15, 2010
Olympus u820 image distortions colour and form
One answer time for a new camera the cost to repair is about the same as new.
Mar 15, 2017 | Olympus Stylus Stylus 820 µ Digital 820...
Color is distorted on I pad
Try this - Reset the iPad by holding down on the Sleep and Home buttons at the same time for about 10-15 seconds until the Apple Logo appears - ignore the red slider - let go of the buttons. (This is equivalent to rebooting your computer.) No data/files will be erased.
If there's the possibility it was dropped, turn the iPad over and give it a HARD SLAP on the back. May take several slaps.
dropped iPad dropped my Ipad sideways the screen is only black and it wont turn on
Feb 22, 2014 | Apple Ipad I-pad
Yellow Stripe Down Middle of Screen on Laptop
This system has a VGA port so you can plug in an external monitor. You can buy one for less than $130 based on the Sunday ads. Other than that, it is new laptop time.
Jul 31, 2010 | Acer Computers & Internet
There is a yellow ''swoop'' in the upper left portion of the tv and shadowing. The ''magic focus'' does not resolve the problem. When I try to adjust manually, the grid shows arched lines (''swoops'' along...
Sounds like you have a bad convergence circuit, it's what lines up your picture so the colors are correct. Most brands (excluding RCA) use the same basic design. There are 2 big ICs called STKs that normally fail, some resistors or fuses may also go. Its about $300-$400 bucks to have someone repair it. If you want to try it yourself, this link TVrepair will take you to a site that sells kits with the parts and step by step instructions on how to fix it. Good luck
Mar 06, 2010 | Televison & Video
Purple and green color
It sounds like a convergence problem to me. I had the same problem with my set and fixed it myself using a kit I bought from www.TvRepairKits.com. These guys rock!
Aug 19, 2009 | Hitachi 61SWX10B 61" Rear Projection...
3 pixel wide stripe on lcd
Hi Casey,
If the problem is getting worse, than either the pixels are dying (so to speak) or you might have a problem with the monitor's screen.
Unfortunately, if either of the above are true, then the only way to fix it would be to replace the screen, which can be quite expensive. If you agree that this is the problem then you'd be better off getting a new monitor instead of spending money to get it repaired.
Good Luck.
Jun 07, 2009 | Acer AL1711 17" LCD Monitor
1995 Ford Windstar Speaker Coding Scheme.
www.installer.com as speaker schematics
Dec 22, 2008 | 1995 Ford Windstar
Imagin fashion designer new york
bell bottoms in purple and white stripes. Top sort of peasant look in purple with the multi square design. Hope this help.
Oct 22, 2008 | Nintendo DS Console
Yellow stripe down the screen.?
And a good evening to you!
It is possible that you have a bad LCD assembly, or possibly the LCD cable connector is loose. The only way to find out is to remove the LCD assembly from the top cover so that you can access the connector. It is located behind the LCD screen.
If you want a copy of a service manual for the disassembly process, let me know and I'll see what I can do for you.
Ron-
Dec 01, 2007 | Acer Aspire 1642WLMi Notebook
Samsung HL-R4264W 42" DLP HDTV Logo
160 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
