Question about Asko T701 Electric Dryer
Asko t701 dryer makes exsessive noise and drum rotates slowly
Unit is level and still dries clothes
Lint gets in to blower because the plastic on lower portion (below lint filter) of door is warped away from drum seal. Could be caused by heat or clothes dropping against it. If you have lint in the blower it is everywhere including heating elements. tear it apart vacuum and bend the plastic back. Have Had this problem for 5 years plus. when the unit starts to get louder its time to do it again. Other than that its been a good dryer.
Posted on Dec 01, 2011
I have a t700 qwhich was EXTREMELY noisy. It finally stopped working so I attacked it with a screw driver (torx). There are two rollers that support the drum on the front of the cabinet. I replaced them and it is quieter than ever before.
Posted on Nov 09, 2011
THE DRYER MAKES A BANGING NOISE LIKE THERE IS A DENT ON THE DRUM ITSELF
Posted on Jun 30, 2011
Mine was very noisy. Then I found the impeller clogged with lint. I cleaned it and now the noise is gone.
Remove the lower panel (2 Torx T20 screws).
Remove the impeller cover (1 Torx T10 screw and 4 snaps).
Clean impeller.
Reinstall covers. Don't overtighten screws.
Posted on Sep 24, 2009
Asko t701 dryer burning smell
Loud noise is not a good description. What does it sound like? The dryer has a belt that turns the drum, the belt can wear and slip, there is a also a tensioner pulley on the belt system and then there is the motor that turns the drum. The smell could be from the belt, however you should know that dryers are not maintenance free and you have to clean them at least annually because they can build up lint in the cabinet and that lint can get into the heating element and it can start a fire.
Aug 19, 2016 | Asko T701 Electric Dryer
Asko T701 stopped running.
Test the wirings to control panel and the switch.
Try also a different outlet, and eventually check with a tester the power cord.
Also the switch must be tested.
If the wirings are ok then the whole control panel can be replaced.
If you want to buy parts you find them here.
Sep 13, 2008 | Asko T701 Electric Dryer
Asko dryer squeaks when drying
BEARINGS MAY BE BAD AND AFTER HEATING UP STARTS A NOISE, MAY WANT TO CHECK DRUM GLIDES ALSO. AND DRUM ROLLERS THEY CAN SQUEAK WHEN THE WHEELS LOSE THEIR GREASE AND DRY UP
Sep 26, 2014 | Asko T793 Dryer
What does the code C3 mean on my Asko Dryer
Asko electric dryer model T701 has timer-controlled drying in addition to the two automatic (thermostat-controlled) programs. Without electronic, there isn't possible display fault code.
Dado
Sep 26, 2014 | Asko T701 Electric Dryer
Asko dryer takes forever to dry clothes lately -- only 5 years old.
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Sep 14, 2011 | Asko T701 Electric Dryer
Dryer making more noise than normal. clothes taking longer to dry.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Aug 07, 2011 | Asko T701 Electric Dryer
Ive rinsed the bottom filter as advised and dryer still shuts off
also wash the door filter,it may need to be serviced
May 15, 2010 | Asko T701 Electric Dryer
My dryer is making an increasingly noisy rolling sound when in use. It is an Asko T701 model
sounds like your drum guides or felt thats wore
out or something stuck inside there rubbing
Jun 17, 2009 | Asko T781 Electric Dryer
Asko T701 Electric Dryer Logo
306 people viewed this question
Top Asko Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Asko Dryer Expert? Answer questions, earn points and help others
