Question about Epson LX-300 Matrix Printer
Printing in different regional language
Hello Sir/Madam,
I am using the vb application and need to print the output which are generated by my application in regional indian langues and also set a printer height as per the lines means it could not skip the page after few lines printed and i dont know how much line will be generated for printing by my applicaiton.
Please help me and give me some solutions on this.
waiting for reply
    President:
  • Epson Master
  • 2,022 Answers
Pls try to reset the printer default seeting .that will fix your regional setting
Posted on Dec 27, 2007
In my application,i want to print the barcode generated from the application.i am using TTP 244 plus printer for printing the generated Barcode.but printer skips two lables and print the generated bar
Please verify the following:
- Driver: If you are using the standard printer driver, maybe you want to try another driver(Download an excellent driver at www.nicelabel.cl, searching by your brand and model name).
When installed, you should go to advanced settings and use the callibrate options.
- Software: Maybe your software has a configuration and the driver has another, set the same length for both and verify if the problem persists.
- Sensor: If the sensor has an issue, then you should try contacting a local reseller or partner for zebra. If that's the case, you probably will have to repair the printer($) or definitively replace it for another($$). Since it's a desktop printer, check your warranty first and maybe you are covered.
Jan 16, 2015 | Zebra GK420t thermal transfer and thermal...
Image runner 2200 its showing code error E000007-0000 what can i do sir/madam
image runner 2200its showing code error E000007-0000what can i do sir/madam
Feb 24, 2011 | Canon (6981A002AA) for imagerunner 2200,...
I dont know the disadvantages of visual basic.
visual basic, is only a basic programming language, most programs will run on Java script, microsoft is visual basic though, but it uses a lot more complex scripts then, if you like the programing language, go for it, but i did not like it.
Also
VB is undoubtedly the simplest and easiest platform to build major Windows applications. The problem is that like other Microsoft products they change faster than I change my socks.You will certainly need more than just VB. Get into server and client side scripting and the use of VB Net.
Jul 06, 2010 | Microsoft Visual Basic V6.0 Fundamentals...
Dotmatricx printing
Each machine has it own printing language (HPCL, HPGL, PostScript, etc.) You must first find out what command language it responds to.
Hope it helps.
Aug 28, 2009 | Epson LX-300 Matrix Printer
An example of visual basic program
Visual Basic (VB) is the thrid generation event-driven programming language and integrated development enviorment (IDE) from Microsoft for its COMprogramming model. VB is also considered a relatively easy to learn anduse programming language, because of its graphical development featuresand BASIC heritage.
Here is an example of a code that displays a message box "Hello, World!"
as the program runs:
Private
Sub Form_Load()
MsgBox "Hello, World!"
End Sub
simply making duplicated lines of text and changing the words in the
speech marks can draw a different text and ammounts.
For example:
Private
Sub Form_Load()
MsgBox "Welcome, blue_skies61!"
MsgBox "My name is Siwek06!"
End Sub
you can also bold the text by puting this line before a text:
Sub SetFontBold()
Overall i think this is a easy language to learn.
Go on to microsoft.com help center, or the forums to learn more.
Feb 23, 2009 | Visual Land V-Touch Digital Media Player
Need to download languages but no cd at hand
will home .if you have any xp cds put it in the drive then go to start menu >Control Panel>Regional and Language Options>languages>then check the group of languages you want and it will load the files needed then restart your computer and it will be \\\\\\\\\\\\\.
Dec 21, 2008 | Microsoft Windows XP Home Edition
Language problem
hai
to change the language follow these steps.
Usually, the language and country or region are set when you install the,
HP PSC. If you set the country/region or language incorrectly during.
installation, use the following procedure.
1. Press Setup.
2.Press 5, then press 5 again.
This selects Maintenance, and then selects Set Language & Country/
Region.
You are prompted with a list of languages. You can also scroll through
the languages using or .
3 Using the keypad, enter the two-digit number for the desired
language.
4 When prompted, press 1 for Yes or 2 for No.
You are prompted with all the countries/regions for the selected
language. You can also scroll through the countries/regions using
or .
5 Using the keypad, enter the two-digit number for the desired country/
region.
6 When prompted, press 1 for Yes or 2 for No.
7 You can confirm the language and country/region by printing a Self-
Test Report, as follows:
a. Press Setup.
b. Press 1, then press 5.
This selects Print Report, and then selects Self-Test Report.
Jul 27, 2008 | HP PSC 2210 All-In-One InkJet Printer
Last page of some docs won't print
Within the driver you can select what graphical language to use try a different one and see if that helps also check the paper size settings
hope this helps and please rate me
Cheers J
Aug 29, 2007 | HP LaserJet 1100 Printer
Paper margin problem in pagemaker application
Do you mean the left margin is too large so all the content is shifted to the right and off the page? If this is the case, it is probably a setting in Pagemaker. In the file menu, choose "page setup" or "print setup". Check the paper size. Check the margins.
Jun 24, 2006 | HP Color LaserJet 2600n Printer
Epson LX-300 Matrix Printer Logo
113 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
