Question about Brother MFC-8860DN Printer
Brother MFC 8860 has ip conflict. How do I resolve this? The issue is that the IP address is different on my computer versus the printer and thus doesn't allow them to connect. Greg
  • Just Gort
    Just Gort May 11, 2010
    All devices on a network (PC, Laptop, printer, etc.) must each have a unique IP address. If the address of the Printer and your PC are different, that is good. There is some other conflict...: 1. Please post the IP Address of the printer and your computer. 2. The printer may be in conflict with a firewall or some other device, like a WiFi Access Point. 3. Two devices have (maybe) 192.168.1.1 or 192.168.1.0 or 192.168.0.1 4. All devices have to have the SAME first THREE sets of numbers (The network number) and a different fourth number (the node number): example: Network: 192.168.1.x Node: xxx.xxx.x.3 Your IP address: go to a Command Prompt: [Start] [ Run] "cmd" type ipconfig (and press the enter key) Your IP Address will be listed. Please comment.
    Brigadier General:
  • 10,406 Answers
Each IP-address on a network (private in your home, or public on the Internet) must be unique; hence "IP conflict" when two devices (computers or printers or iPod Touch) try to "claim" the same IP-address.
If you have configured a "static" IP-address into the printer, change it to an IP-address that is *NOT* used on your network.
Or, find the computer on your network that is using the same IP-address as your printer, and change its IP-address and reboot it.
In order to connect, your computer and your computer *MUST* have *DIFFERENT* IP-addresses.
Posted on Sep 10, 2009
Printer offline and not printing
Since this is a network printer there are a few potential sources for problems.
  1. IP address conflict. When items on a network are powered on and off sometimes the auto-assigned IP addresses aren't refreshed. The router may think the printer isn't there and re-uses the IP address for a new device on the network, but the printer is still trying to connect with the original IP address.
    1. Log onto your router. See if the printer shows up in the DHCP Client Table of your Local Network - it may have names or just MAC addresses depending on the router. You can print out a test sheet from your printer and see what *it* has as it's IP address and see if that's assigned to something else.
    2. If you do find a conflict, the easiest solution, IMO, is to assign a static IP address to the printer.
  2. Bad cable or hub. Both can go bad and a problem with either will cause the printer to appear to be offline.
    1. Check for lights at both ends of the ethernet cable.
    2. Try a different port in the hub or router
    3. Try a different cable
  3. An recent update corrupted your printer settings.
    1. Uninstall the printer, then reinstall it
Nov 13, 2013 | Brother MFC-7460DN Multifunction Laser...
Tip
IP Conflicts in a work place
An IP address conflict occurs when two computers on a LAN or the Internet have been assigned the same IP. IP conflicts between two computers normally render either one or both of them unusable for network operations.
How IP Address Conflicts Happen
Two computers can acquire conflicting IP addresses in any of several ways:
· A system administrator assigns two computers on the LAN the same Static IP Address.
· A system administrator assigns a computer a static IP address within the local network's DHCP range (dynamic IP range), and the same address is automatically assigned by the LAN DHCP server.
· A malfunction in the network's DHCP server allows the same dynamic address to automatically be assigned to multiple computers.
· An ISP accidentally assigns two customers the same IP address (either statically or dynamically).
· A mobile computer is put into standby / hibernate mode and then awakened later.
Note that other forms of IP conflicts can also occur on a network. For example, one computer may experience an IP address conflict with itself if that computer is configured with multiple Network Adapters. System administrators may also create IP conflicts by accidentally connecting two ports of a network switch or router to each other.
Recognizing IP Address Conflicts
On most Microsoft Windows computers, if you attempt to set a fixed (static) IP address that is already active on the local network, you will receive the following pop-up error message:
The static IP address that was just configured is already in use on the network. Please reconfigure a different IP address.
On newer Microsoft Windows computers having dynamic IP conflicts, you should receive a balloon error message in the Taskbar as soon as the operating system detects the issue:
There is an IP address conflict with another system on the network.
Sometimes, especially on older Windows computers, a message similar to the following may instead appear in a pop-up window:
The system has detected a conflict for IP address...
On Mac or Linux computers, a similar message will normally appear on screen.
Resolving IP Address Conflicts
Try the following remedies for IP conflicts:
1. For networks where IP addresses are fixed (statically assigned), ensure each local host is configured with a unique IP address.
2. If your computer has a dynamically assigned address, releasing and renewing its IP address can workaround IP address conflicts.
3. If your home router is believed to have a faulty DHCP server causing IP conflicts on the home network, upgrading the router firmware may resolve this problem.
on Nov 24, 2010 | Computers & Internet
Where is IP address for the MFC-7220 printer
Network printers do not have a set IP address, you need to configure the printer with an IP address that uses the same range of IP addresses as your network.
The IP configuration is normally done through the printer's Menu on the printer's buttons.
If your are using a network IP range 192.168.0.*** that your wireless router issues automatically then select a fixed IP address on your printer above the number of computers that is installed on your network. (ie if you have 10 computers the make the printer's fixed IP address say 192.168.0.30) so the wireless router cannot issue a conflicting IP address.
When you install the printer driver on each computer then go to the Printer Properties - Port tab - click Add Port - IP port and enter the printer's fixed IP address and printer name.
Do a test print to check if your computer connects to the network printer.
Oct 18, 2012 | Brother MFC-7220 All-In-One Laser Printer
I just configured my MFC 490cw for wireless printing. It works but now I have IP address conflicts across all computers XP & Windows 7) and X-box in the house. If I turn the printer off, the network...
When configuring an address for the printer, the IP configuration might look like (just an example):
IP Address - 192.168.1.2
Subnet Mask - 255.255.255.0
Default Gateway - 192.168.1.1
It's important to note that even though you are not using any IP addresses in the default range for DHCP, the Subnet Mask and Default Gateway addresses will be THE SAME.
If you have another device on your network that will be assign a fixed address, you would use for example:
IP Address - 192.168.1.3
For any other devices, just increment the IP address by one, 192.168.1.4, 192.168.1.5, etc and use the same Subnet Mask and Default Gateway.
(see the owners manual or site for steps on configuraing the printer TCP/IP information). This should take care of any conflicts.
Jan 29, 2011 | Brother MFC 490cw Color Inkjet...
I have a message that say Ip address conflict, what can I do
I have changed my router and my networked printer no longer works
Hello Warren !
What happened is that when you replace the router, the IP Address for your printer changed as well. Your network printer connects to your computer through a number called the "IP address" wich is assigned by your router, since you replace your router, the new router assign a new Ip address for the printer, so you will need to change that IP address on the printer driver on your computer as well.
What you need to do is print a configuration report directly from the printer to figure out what the new IP.
When you have this number ( it will look something like "192.168.0.1")
you need to go to "printer and faxes" under control panel, make a right click on the MFC-465 icon, go to properties, then go to the ports tab a click on "Add Port" select Standard TCP/IP and type in the new ip address.
This should reentablish the communication between your printer and computer.
Good Luck
You can contact me directly here:
eliteprintersolutions@gmail.com
Jul 15, 2010 | Brother MFC-465CN InkJet Printer
IP address conflicting
Have you checked to see if either computer has a static IP address? that might conflict with the DHCP table.
Jun 27, 2009 | Belkin (F5D7230-4) Router (587009)
"brother mfc 7840w printer goes offline and i cannot print need turn printer on and off.
The solution, and it took me a long time to find the simple solution, is to right click on your printer, click properties, click the ports tab and click on your Brother printer and click on configure port (or you can delete the existing one and then add another one). What you want to do is update the IP Address. The problem is that the printer does not have a static IP address, it is dynamic. If you want to confirm that, go to your printer and press the reports button and print out the network configuration report. Your IP address will show on that. It's really the last digit in the IP address that changes. This will absolutely solve your problem. Good Luck!
Apr 17, 2009 | Brother MFC 7840W Printer
BROTHER MFC 420CN WILL NOT PRINT FROM LAPTOP
I had the same problem and what I found was that the IP address I used did not agree with the IP address stored in the printer. You can find the IP address using the setup TCP/IP option from the menu button. I changed the IP address in the TCP/IP port properties and it worked. I don't know how it changed, but I suspect the IP changed because of a conflict. When I turned the laptop off the IP went back to the original one that I had been using.
Apr 15, 2009 | Brother MFC 420CN All-In-One InkJet...
Brother 845cw printer is offline -
Had same issue and here is what worked for me.
1. Go to Printers and right click on Brother printer and choose 'Properties'
2. Click the 'Ports' tab and with proper Brother printer port highlighted click 'Configure Port'
3. In second field titled "Printer Name or IP Address" enter the IP address of printer*
4. Click 'OK' as need to exit out.
I'm using XP so this may be slightly different depeneding on your flavor of Windows. The main thing is to name the port with the IP address and not rely on name resolution.
Hope this works for you too!
* If you don't know your printer's IP address then you can go to your printer and under the 'Reports' section print-out the Network Configuration report to find IP address.
Feb 29, 2008 | Brother MFC-845CW multi-function...
Brother MFC-8860DN Printer Logo
680 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
