Question about Nintendo Wii Console
Wii sticking hi when i switch on my wii it seems to stick and won't move. the batteries are new and a light comes on and although i can use a key i can not switch off the wii with any of the controllers
Try this page from Nintendo.com
Posted on Dec 21, 2007
My ignition switch on my pontiac aztek must be manually moved from the start poistion to on. Like the spring does not take it out of start.
You have a bad key cylinder. You need to replace the cylinder. You can find kits on line for your brand of car for a new key cylinder. It will come with instructions on how to assemble the cylinder for the old key
Oct 07, 2015 | 2004 Pontiac Aztek
Won,t come out of park
Not sure what coming out of park has to do with custom sub boxes? May be you can give us a clear ask?
Dec 14, 2014 | JVC Mtx Thunderform Custom Box For Ford...
Samsung sgh T669 won't turn on
Dear Brother;
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Dec 06, 2012 | Samsung Gravity SGH-T459 Cell Phone
The battery in my 1998 Honda CRV works fine. Had a problem with the key sticking, now the key turns in the ignition but won't catch to start the car. Not sure what to do
Sounds like the ignition switch is worn out(or the linkage from the lock cylinder to the switch has come loose or something like that)
Oct 08, 2012 | 1999 Honda CR-V
Controller all four lights come on controller cant get it to work will one controller play on second unit have new batterys
Have You Tried syncing it? all you have to do is look at the front of your wii console and flip open the little door. it will have a small red button then where you stick the battery in on the controller you will see another red button, hold both red buttons down at the same time. (the one on the wii, and the one on the wii controller) and then your controller should work properly
Dec 12, 2010 | Nintendo Wii Console
The hazard lights are sticking on and draining the battery
Hi.
Replace the hazard lights switch.
Series 3 hazard light switch malfunctions are quite common. The switch may not work, or like in your case, it may short and drain the battery.You can find the procedure to remove the switch summarily described on this forum.
The switch can be tested disconnecting it from wires, and using an Ohmmeter on its contact to ensure it is opening and closing fine, and not sticking.
If the switch is fine, wiring, alarm system and crash sensor must be tested. The most common reason for this kind of problem is the switch itself.
See also:
Hazard Lights turning on by themselves.
Hazard lights keep coming on.
Regards.
Ginko.
May 19, 2010 | 2001 BMW 325
Door lights won,t come on when open door.check
Souns like it's your door switches, or the wire to your door switch's could have a braek in them. Good luck and hope this helps.
Apr 08, 2009 | 1998 Cadillac Catera
Wii Fit Balance Board Won't turn on
i fixed it by re-syncing it with the console. all good now, although it seems a little out of balance, but at least working....
Jan 04, 2009 | Nintendo CTA Digital WI-BBP Wii Fit...
Nintendo Wii Console Logo
54 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Zhenya Ogorodnikov
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
