Question about Kenmore Kitchen Ranges
Kenmore gas range beeps and displays code E1-F2
Kenmore gas range beeps and displays code E1-F. Oven won't reach proper temp.
    Scholar:
  • 61 Answers
I'm not sure if the error codes are the same for gas ranges as they are for electric, but this is the solution for that same error code with the electric version. you might give it a try with yours and see if it works the same for gas as well (I would assume the electronics are similar between the two).
you probably don't need to replace any parts to solve this problem. E1 -F2- = the keytail (connector ribbon) that plugs into the control board is not making good contact. first unplug your range and then remove the two screws on the underside of the back-splash controls panel to access the back of the control board. now simply cut a slip of heavy paper such as a business card to the width of the ribbon and slide it into the slot along with the ribbon connector. that will help press the contacts on the other side together snuggly. screw the back-splash back in place, plug in your range, and the problem might vanish. if the error code returns, try pulling out the connector, cleaning the contacts with a pencil eraser, reinserting it into the slot and repeat above with the paper.
the paper trick worked for me for about two weeks, then the problem happened again. the next fix I tried was to unplug the keytail (the ribbon connector) from the slot on the control panel. there is a clip in each side of the black plastic receptacle (the place where the keytail plugs in on the electronics control board). pres them inward to separate the top portion of the receptacle, which I think helps to clamp the keytail into the bottom portion. the top and bottom fit tightly together, so you might need to use a small screwdriver at the joint to pry them apart, however, I did not find it necessary to remove that clamp in order to remove or replace the keytail on mine.
smoke and other sticky cooking fumes cling to the contact wires on the keytail and the pins in the receptacle (as well as other surfaces) and that buildup interferes with the electrical connection they need to make. once the keytail is free, clean it well with a mild cleanser (I used a slightly soapy, damp dish sponge) and dry it with a clean paper towel. FYI, one side of the keytail has the exposed wires which make contact with pins in the receptacle on the control board. the exposed side is on the inside surface of the curled keytail ribbon, the outside surface is translucent plastic insulation (you can feel that the outside is smoother than the inside because the inside has the contact wires exposed). the inside is the side you want to make sure is clean because those are the wires that need to make electrical contact with the pins in the receptacle.
next, use sharp scissors to carefully trim a small uniform strip (roughly 1/16 of an inch or less) off the end of the keytail. then plug it in again (remembering to use the top portion of the receptacle to secure it in if you had removed it). doing this provides a fresh spot on the exposed wires to make contact with the pins in the receptacle. my theory is that over time the wires wear out at the points where they make contact with the pins. trimming the edge allows you to insert the keytail deeper into the receptacle and therefore, the pins will contact the wires in the keytail at a new, unworn spot. it's been over a week now and so far, it seems to have fixed the problem on my stove. if I get the error message again in the future, my next step will be to try paper trick again (at least as a temporary solution), but I doubt it will be necessary any time soon.
be sure to try all other solutions first before ordering any parts. I first changed the control board for $125 and there was no change. then I ordered the touchpad, but ended up fixing the problem before it arrived. I sent the touchpad part back to Sears Parts Direct after I figured out I didn't need it and they eventually refunded $15 less than I'd paid. of that difference, $13 and change was for shipping, so the other dollar plus must have been a miscalculation or a restocking charge or something, but I didn't bother following up to find out. I also had to pay about $3 to ship it back to them via USPS because I didn't hear the UPS guy when he dropped it off on the doorstep, so I wasn't able to simply refuse the delivery.
good luck with your repair.
Posted on Nov 18, 2010
    President:
  • 744 Answers
Hello, E1 error code relates to the EOC (electronic oven control) Failure. You should turn the breaker off for 30 seconds and then switch back on. This might clear the error code. If this does not clear up with the reset I have just mentioned you are going to have to replace the EOC, This can be located in the control panel by removing the screws from the back. If you have any other questions please feel free to comment again. Good Luck! Mike
Posted on Sep 10, 2009
My built in oven AKZ 110 is showing F 03 and nothing happens when I try to tune it in to work just stays on F 03 no fan no light either
This should help any further assistance please feel free to contact me.
WHIRLPOOL
Range/Stove/Oven Fault Codes Non Y-Line
NOTE: Not valid for Y line. If there is a Y near the end of your model number, do not use this chart.
Failure
Code
Condition Check/Repair 4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock (ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock (ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock (ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
2. Test relay contact operation
3. High resistance in oven temperature sensor F3 Open oven temperature sensor or thermal fuse Replace oven temperature sensor or thermal fuse F4 Shorted oven temperature sensor Replace oven temperature sensor F6 Problem in time keeping circuit 1. Reset time and/or cooking operation
2. Check for proper ground F7 Stuck function switch or button on Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F8 Failure Electronic Range Control (ERC) Replace ERC (Electronic Range Control/Clock) F9 Door lock circuit Check wiring and test operation of door lock switch bkg-faultcodedivider.jpg txt-gototop.jpg WHIRLPOOL
Range/Stove Oven Fault Codes, Common
Failure
Code
Condition Check/Repair Digit Failure Code2 F1 Analog to Digital Failure Disconnect for 30 seconds - if display reappears - replace control board F1 Safety flip flop Replace board F1 Shorted keypad Replace keypad F3 Oven temperature sensor opened Replace oven temperature sensor F2 Oven temperature sensor shorted Replace oven temperature sensor F3 Oven too hot Replace oven temperature sensor F3 Clean temp too hot Replace oven temperature sensor F5 Check door/latch switch Replace switch if defective 4 Digit Failure Code F1 - E1 Safety flip flop Replace board F2 - E0 Shorted keypad Replace keypad F3 - E0 Oven temperature sensor opened Replace oven temperature sensor F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace switch if defective
Jul 16, 2011 | Whirlpool Ovens
Self-cleaning electric range
Hi
Here are the codes for you range:
F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1Safety flip flopReplace Electronic Range Control/Clock (ERC) F2 - E0Shorted keypadReplace Electronic Range Control/Clock (ERC) F3 - E0Oven temperature sensor or oven temperature sensor fuse openedReplace oven temperature sensor or fuseF3 - E1Oven temperature sensor shortedReplace oven temperature sensor F3 - E2Oven too hotReplace oven temperature sensor F3 - E3Clean temp too hot Replace oven temperature sensorF5 - E0
F5 - E1 and E2 Door latch problemCheck door/latch switch, replace if necessary
Looks like yours is a bad oven control. There is a # at the end of yourmodel # 0-5 that will determine which control it takes. Once you havethat # you can look it up at http://www3.sears.com/ Looks like the part costs about $165.
Oct 08, 2008 | Kenmore Kitchen Ranges
Tip
Whirlpool oven, stove and range fault codes (ERC and EOC display errors).
Here a list of Whirpool oven fault codes. The codes had been collected from different service manuals. This was a memo that I wrote for my own use. I think this can be useful to owners and technicians.
WHIRLPOOL - most models
Range/Stove and Oven Fault Codes, Common error codes.
F1 - Analog control board Failure
Disconnect for one minute - if error comes back, replace control board
F1 - Shorted control keypad
Replace keypad
F3 - Oven temperature sensor open
Replace oven temperature probe
F2 - Oven temperature sensor shorted
F3 - Oven too hot
F3 - Clean temperature too hot
Replace oven probe
F5 - Door latch switch fault
Test and replace the door switch.
Whirlpool with 4 Digit Failure Code:
F1 - E1 - Electronic control (flip flop)
Replace control board
F2 - E0 - Shorted control keypad
Replace keypad
F3 - E0 - Oven temperature probe open
Replace temperature probe
F3 - E1 - Oven temperature probe shorted
F3 - E2 - Oven temp too high
F3 - E3 - Clean temp too hot
Replace temp. probe
F5 - E0 - Check door latch
F5 - E1 - Check door latch
WHIRLPOOL Polara models 5 digit codes:
F1 F0 - EEPROM communication error
Replace ERC
F1 E1 - EEPROM checksum error
Replace ERC
F1 E2:7 - UL A/D errors
Replace ERC
F1 E4:2 - Model ID error
Reinsert keytail.
F1 E6:0 - Latch signal mismatch error
Replace ERC
F2 E0:4 - Shorted key error
Replace keypad assembly
F2 E1:3 Keytail unplugged
reinsert the keytail
F3 E0:5 Top oven sensor open
Test and replace top probe.
F3 E1:6 Top oven shorted
Test and replace temp probe
F3 E2:9 Bake range over temperature
F3 E3:8 Clean range over temperature
Test and replace temp probe.
F3 E4:10 Bottom oven sensor open
F3 E:15 Bottom oven sensor shorted
F5 E0:14 Door switch errot
Test and eventually replace door lock switch
F5 E1:16 Door latch not operating
Test and eventually replace door latch
F8 E0:17 Refrigeration error
Test the cooling module.
PF Power failure - Does not indicate a fault.
PF occurs when power is disconnected.
WHIRLPOOL
Models SF3, 30'' and 24"
F2 - Oven temperature above specifications
Check 8-pin connector from temp. probe to Electronic Oven Control
F3 - Open oven temperature probe failure
Check wiring, replace oven probe if necessary
F4 - Shorted oven temperature sensor failure
Check wiring harness, replace oven temperature probe if necessary
F5 - Push button stuck or faulty
Check for binding of pushbuttons and control panel glass. If OK, replace touch panel
F6 - Electronic control logic error (timing)
Replace Electronic Range Control (ERC)
F7 - Electronic control logic error (lock motor)
Replace ERC.
F8 - Electronic control logic error
Replace ERC.
on Jan 31, 2010 | Whirlpool RBS305PDS Electric Single Oven
Kitchenaid gas range keeps beeping intermittantly, oven turns on by itself and code F2:E1 keeps comiong up on pad. What is the problem
Hi
Thanks for using FixYa. Error F2-E1 in your Kitchen Aid range indicates shorted keypad. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jul 29, 2010 | KitchenAid KGSA906PSS Gas Kitchen Range
Kitchen aid wall oven Model YKEBS2780B1 SHOWS
Hello,4 Digit Failure Code F0 - E0 Analog to Digital Failure Disconnect for 30 seconds - if display re-appears - replace control F1 - E1 Safety flip flop Replace Electronic Range Control/Clock(ERC) F2 - E0 Shorted keypad Replace Electronic Range Control/Clock(ERC) F3 - E0 Oven temperature sensor or oven temperature sensor fuse opened Replace oven temperature sensor or fuse F3 - E1 Oven temperature sensor shorted Replace oven temperature sensor F3 - E2 Oven too hot Replace oven temperature sensor F3 - E3 Clean temp too hot Replace oven temperature sensor F5 - E0 F5 - E1 and E2 Check door/latch switch Replace component 2 Digit Failure Code F0 or F1 or F5 Failed transistor Replace Electronic Range Control/Clock(ERC) F2 - E0 Oven temp too high 1. Test operation of door lock on self-clean models
Thanks
May 26, 2010 | Ovens
F2 on the display!
F2 Oven temp exceeds 590 w/ unlocked door High resistance or interference in oven temperature sensor. Replace oven temperature sensor
Apr 03, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Dec 16, 2008 | Ovens
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Oven beeping f1 and f3
Here are the error codes for your range:
F1 Circuit board defective Replace control board F2 1. The oven temp has risen above 665F and the door is not locked or
2. The temp has risen above 965F with the door locked 1. Check oven temp in mode that failure occurred. Replace EOC (Electronic Oven Control) if above limits
2. Check 8-pin connector. Check and replace oven temperature sensor if necessary F3 Oven temperature sensor is open (above 3000 ohms) Check resistance of oven temperature sensor, check for open wiring between oven temperature sensor and control F4 Oven temperature sensor is shorted (below 500 ohms) Check resistance of oven temperature sensor, check for shorted wiring between oven temperature sensor and control F5 Internal watchdog circuit has detected a failure Defective EOC (Electronic Oven Control) F6 Shorted buttons Check push buttons and dome switches on control F8 Logic interrupted (lock motor switch sequence) Check door lock switches and wiring
Most likely problem is the oven temp. sensor. Should check around 1100 ohms at room temp. I would replace that first because it is the easiest and cheaper than an oven control.
Nov 22, 2007 | Kitchen Ranges
Kitchen Ranges Logo
509 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
