Question about CDV Software Blitzkrieg for Windows
My game starts up then quits right when i get to the menu giving me no report when i debug it and i wont run ever. any advice?
  • 22 Answers
Make sure you meet the minimum system requirements for the game you are trying to play.
Posted on Sep 10, 2009
I have z wave sensor that has stopped reporting. I suspect that it may be too far from the hub. Is there a way to tell if the sensor is talking to the hub?
The best way to check is with electronic equipment. If your not prepped THE ONLY WAY I COULD TELL YOU AND PLEASE DONT CONSIDER THIS PROFESSIONAL ADVICE! GIVE IT A SHOT! IF THE PARTS STORE IS WILLING TO REPLACE A USED ELECTRONIC PART, TRY A NEW ONE . THE ADVICE I CAN REALLY GIVE YOU IS YOU MAY HAVE A RUSTY MOUNTING SURFACE AS A GROUND! OR A POOR ELECTRICAL CONNCTION. START WITH THE BASICS. GOOD GROUNDS & ELECTRICAL CONTACTS. & GO FROM THERE. MAY BE TOO FAR ALSO, COMPARE W/ OTHER SENSORS ALIKE OR POSS DEFECT. GOOD LUCK , FRANK M .
Feb 15, 2016 | Cars & Trucks
Tip
How to solve safari slow script error
This error prompt is easily remedied, however, you'll need to access the Safari Debug Menu to do so. If the Debug Menu is activated, click on it in the Menu Bar and uncheck "enable runaway JavaScript timer. That ought to solve this problem.
If the Debug menu is not activated, follow these instructions:
Quit Safari
Open Terminal.app in your Utilities folder,
When the Terminal window opens, copy & paste the following command into the window:
defaults write com.apple.Safari IncludeDebugMenu 1
Click on the return key, you may be prompted for an admin password. If so, enter it.
Press "return".
When you see your Mac's name, it's done,
Quit Terminal
Restart Safari and go to the Debug Menu, following the suggestion above.
on Mar 17, 2010 | Apple safari
How to run a report on a fax machine?
To run the auto dial and speed dial report you need to do the following:
Press Menu, 5, 2, then Start. The display will prompt you to the correct numbers. This will give you a list of pre-programmed numbers.
Jul 15, 2014 | Brother MFC-8220 Fax
After install can't get call of duty GHOSTS to load
right what sort of system are you running (specs wise)
ghosts is a new PC game if your hardware is a few years old it may not be supported or meet the minimum requirements.
if you have got a flashy PC then my advice would be try compatibility mode (probably wont work) or try updating the drivers especially your graphics driver.
if you are still having trouble try changing what DirectX version you are using
Jan 05, 2014 | Computers & Internet
How do i enter cheat codes into star wars the force unleashed 2
Hope this will help you:
Cheat ListYou can insert the following passwords at the game's main menu for the desired result.
  • 1,000,000 Studs - Start, Right, Up, L, Down, Select, L, R
  • 3,000,000 Studs - Start, Start, Down, Down, Left, Left, Up, Up, Select
  • Open Debug Menus - Up, Left, Down, Right, Up, Left, Down, Right, Up, Left, Down, Right, R, L, Start, Select
  • Unlock Bonus Game - Up, Up, Down, L, L, R, R
Thank you for using fixya..
Please rate me on fixya and provide testimonial if ever to continue my further assistance..
May 30, 2011 | Nintendo DSi Blue Console
Runs good for about 45 seconds then quits running starts right up again runs another 45 seconds then quits again
I have a altima that did this, turned out to be the fuel pump. But I would replace the fuel filter first and see if it solves your problem. Filters clog up, they will give the pressure to start , but wont give the flow and pressure to keep up.
May 18, 2011 | 1985 Nissan 300ZX
Does my printer give a confirmation after faxing is completed?
Normally if i fax is sent, it will just give a message as Fax sent or it wont give any error.
But if you want to get a confirmation whether the fax is sent or not, you can print a fax confirmation page on ever fax sent or received or both.
Press the SETUP button ( menu )
Scroll till you find Print Report - Press OK
Scroll till you find Automatic Reports Setup - Press OK
Choose Send Only - Press ok
Regards,
Ron
Mar 23, 2011 | HP OfficeJet 6110 All-In-One InkJet...
We'r getting pop up saying slow script with facebook
Quit Safari
Press "return".
Quit Terminal
Games loads but will not start. Can't quit. Yes or no does not blink. PSP 2001.
Try to take out the battery if the psp is totally stuck and you can't quit. When you turn it back on you should get the menu screen. If it wont take you to the menu screen take out the disk and than restart it.
Jan 24, 2010 | Sony PlayStation Portable (PSP) Console
Game keeps shutting down while playing
An update might not solve the problem. It could be that you have a dual-core processor. Some of the older games will only run with a single processor active. Here is how to disable the second processor core:
Open the start menu, click on Run,type in msconfig and click on OK
In the System Configuration window click on the start sub menu and the on Advanced Options button.
In the second window that appear, you should be provide with an option for enabling and disabling the number of processors you want to use. You need to select "1" for the NUMPROC box.
Validate your entry by clicking on OK.
Restart your PC and it should be fine.
When you are through playing Primal Prey you can follow the same procedure but select "normal startup" and restart your computer.
Hope this solves the problem.
-Bob
Mar 08, 2009 | Infogrames Primal Prey for Windows
CDV Software Blitzkrieg for Windows Logo
194 people viewed this question
Top CDV Software Video Game Consoles & Games Experts
James Wishart
comandomcl8
Level 1 Expert
Bill Boyd
Are you a CDV Software Video Game Console and Game Expert? Answer questions, earn points and help others
