Question about GE Tritonr XL GSD6260JCC Dishwasher
GE dishwasher arm keeps falling off. what is the
GE dishwasher top spinning arm keeps falling off. what is the name of the piece it connects to? can i replace that little piece myself?
    President:
  • GE Master
  • 1,922 Answers
You should replace 3 parts in diagram,these are the upper spray are,the bearing,and the holding screw the #s are AP3191593/AP3794248/AP3425295 they coincide with the above parts and are all G.E. part numbers
Posted on Sep 13, 2009
Dishwasher lower spray arm falls off
The arms on a dishwasher spin with water pressure remove your arm and thouroughly clean and flush through , also check for wear on the arm bushes to see if there is excessive wear , the washers may need to be changed. Check the supply hole to the top arm to make sure it is not blocked.
Feb 08, 2013 | Dishwashers
Tablet keeps coming out of the dispenser on my hotpoint fdl 570 dishwasher on all cycles and falls on to the floor, result is that the crockery isn't always clean on the top tray. Machine is still...
Hi Jeanette,
Maybe I misunderstood your question, but the tablet is supposed to come out of the dispenser and fall into the bottom of the dishwasher. It needs to fall into the hot water in the bottom of the washer to dissolve. The dispenser releases the tablet at different points in the cycle depending on which wash cycle is selected. On a shorter cycle it will be released soon after starting. On longer cycles, there is usually a rinse first, so the tablet will be released a little later. There would only be a problem if the tablet wasn't being released, or wasn't dissolving completely.
There are a number of reasons for poor cleaning on the top rack. The most common are the upper spray-arm not spinning, incorrect stacking or overloading. If the upper spray-arm isn't spinning, there may be caused by a blockage in the spray-arm or the water delivery system, but, as the dishwasher is new and it's not happening every time, it's possible that the dishwasher isn't levelled correctly. The spray-arms aren't motorised, they use water pressure to spin, but they wont spin if they aren't balanced, i.e. the dishwasher isn't level.
You can check whether the spray arm/s are spinning by pointing them front-to-back, or left-to-right (so you can remember the position) and allow the dishwasher to run for a few minutes. Then open the door and check the position of the spray arms. They should continue to rotate slowly for a short while after opening the door, but if they're in the same place and static, they're not spinning. I'd suggest repeating this a couple of times to eliminate the possibility of them having stopped in the exact same place you left them.
If the spray arms are spinning, test the dishwasher with only a small load in the top rack. If the top rack comes out clean with a small load, you may be overloading it or stacking it incorrectly some of the time. There should be a correct stacking guide in your user manual.
Hope this helps. If you need further assistance, check whether the arms are spinning then post back.
Regards,
BElectric
Jul 03, 2011 | Dishwashers
TOP SPRAY ARM DOES NOT SPIN AND IS NOT JAMMED UP
Check the nozzles at the end of the spray arms to make sure that they are not clogged with food particles etc. Make sure that water is reaching the top spray arm connection.
Jan 23, 2011 | GE Dishwashers
The middle arm on my dishwasher (ge Profile) is not turning...the top and bottom are working fine
Had same problem with mine. Actually bought all new middle arm assembly but as I was taking it apart to install new pieces, I noticed so much gunk in the middle swinging mechanism that I assumed that must have been the problem.. I really think the newer dishwashing tablets cause this buildup problem. Anyway, put on all new pieces and started the machine. Long story short, it worked great for about a month and then started doing the exact same thing. THE reason why the middle arm sprayer doesn't spin is that the little holes at each end (the ones that sit underneath and look like they should propel the sprayer arm ) get clogged. I bought some pipe cleaners, bent to an angle where I could come in from the top and pull out through the propellor hole and voila` the sprayer is swinging beautifully again.. I guess the only question I still have is why this started happening three to four years after I purchased the machine. Something somewheres else must not be doing its job.
May 18, 2010 | Dishwashers
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
These parts can be replaced easily and reasosnably cheaply for example the top spray arm is about £20.00p. But you need the back water feed tube as well as the lower spray arm which should come as one package. (depending on model i'm going by bosch). You shouldn't have to pay more than £30.00p + p&p. Hope this helps.
May 19, 2009 | Dishwashers
Top spinner arm of dishwasher keeps falling off
did you solve this. we have the same problem. the piece that the arm is connected to is slightly broken. I don't want to pay for a service call. let me know what you did.
Sep 07, 2008 | Dishwashers
GE triton dishwasher middle spin arm not spinning
I had the same problem and found two things which were causing it
-The O-ring was missing off of the tube connection on the back of the dryer that inserts into the sprayer tube. I found a size 11 O-Ring at Home Depot and it worked
-The openings on the underside of the spray arm are what propels the sprayer to spin. I found small pieces of plastic debris in the openings and cleaned them out.
Now the middle arm spins like it should.
Apr 27, 2008 | GE Tritonr XL GSD6260JCC Dishwasher
GE Tritonr XL GSD6260JCC Dishwasher Logo
359 people viewed this question
Top GE Dishwashers Experts
Mike
jdthefixer
Dan Webster
Dan Webster
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
