Question about GE Profile JTP56 Electric Double Oven
GE Double oven flashing F2
I have a problem with my double oven flashing F2. I turn it on and set temp and just before it gets to that temp the F2 starts flashing. When I opened the over the broiler element was on instead. We have checked the bottom element and it is fine. What could be the problem?
  • 8,197 Answers
The f2 code means that the oven temp sencer needs to be replaced.
Posted on Sep 10, 2009
GE oven error code f2 is displayed
Hi
Thanks for using FixYa. Error F2 in your oven means oven temperature sensor circuit failure. To resolve this issue you’ll have to check the oven temp. sensor circuit if the reading is more then 1100ohms then it should be replaced however, if the rating is fine then it is the Electronic Range Control (ERC) that has gone bad & should be replaced. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Aug 24, 2010 | GE JRP28 Electric Double Oven
My oven gets a F2 code
F2 means usually, that the board detected that it's too hot.
You either need a new control board or a temp. sensor.
ge oven repair orange county, ca
Feb 06, 2010 | GE JTP45 Electric Double Oven
F2 Failure Code after cleaning cycle on GE Double
f-2 is usually a runaway oven temp which most of the time means a bad oven sensor.try replacing this first.
Jan 16, 2010 | GE Ovens
I'm getting a F2 Error and door locked with flashing and beeping after I ran the self-cleaning mode on my GE Model JTP85 built-in oven.
f 2 code states that your oven temp exceeds 590 w/unlocked door .. the oven tempt sensor will need to be replaced .. hope this helped mm
Dec 04, 2009 | GE JTP85 Electric Double Oven
Bake element doesn't heat, broil does. When I turn on pad, it goes to 100 but won't heat up
replace element. it is approx 19 dollars. 2 screws in back and then 2 screws holding element to wires. not a hard job
Nov 12, 2009 | GE JKP45 Electric Double Oven
I have a GE model JKP13 and it keeps going off, beeping and flashing f2 or f3
HI, the oven has experienced a very high temp due to a failed sensor. Check sensor harness and harness connection between oven sensor and oven control. Replace the oven temperature sensor (RTD) if wiring is ok.
Next. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Look for welded relay contacts as well on the control and sensor. replace, both the control and temp sensor if weld spots are visible.
Aug 04, 2009 | GE JTP45 Electric Double Oven
F2 Oven overheats
jaz3133, it's probably the temp sensor that has gone bad. You should be able to get it from the front. It's the probe that comes out from the back wall of the oven. You can have someone ohm it out. Should read approx 1100 ohms at room temp. Part number for the temp sensor is WB20K5040. Make sure power is off befor removing the sensor. Catriver..post back.
Mar 04, 2007 | GE JTP15 Electric Single Oven
GE Profile JTP56 Electric Double Oven Logo
484 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
