Question about Tascam CD-RW2000 Burner
Whenever I turn my burner on, it just sits with the welcome sign on the screen. The drawer does not open but it sounds like it would, but it does not move. What could be wrong or what do I need to fix it?
    Problem Solver:
  • 14 Answers
It seems to be jammed.so if you look at the front, where you can see the button, you will find a tiny hole...so take a paper pin and insert it in the hole and the tray should come out...then you can clean it.
Posted on Sep 10, 2009
I have a Samsung E 1540 Cash Register showing CLOSED on the screen. The drawer won't open. How can I open drawer?
You haven't signed on. If you sign on with your PIN number, the closed message will be removed and allow operation. See your book for sign on info
Jan 24, 2017 | Samsung Retail Supplies
My Frigidaire affinity washer leaks water into the washer stand. Whenever I open the drawer after washing a couple of loads there's water in the drawer.
That's what I thought was wrong with mine to I had 1.75 in change and a piece of a wash clothe in the screen. I toke all that out and it still leaked. Took it apart further and found a piece of the weight that is made out of cement broke of and rubbed through the drum. That sounds like junk to me!!!
Oct 30, 2012 | Frigidaire ATF6000ES Front Load Washer
The burner drawer will not open. The WELCOME! message statys on and no other menu items are available i.e. no other operations appear to be permitted except turning the unit off
make sure that the dvd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
click start control panel administrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or
select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
if this does not fix the problem it might be a registry problem
Close all open programs
Click on Start, Run, and type regedit and press Enter
Click on the plus signs (+) next to the following folders
HKEY_LOCAL_MACHINE
SYSTEM
CurrentControlSet
Control
Class
{4D36E965-E325-11CE-BFC1-08002BE10318}
This folder is the DVD/CD-ROM Drive Class Description in the registry. Look for any of the following names in the right hand column.
Upper Filters
Lower Filters
Upper Filters.bak
Lower Filters.bak
If any of the above keys shown in step 4 are listed, right-click on them and choose Delete
After deleting the keys, close the registry editor
Reboot your computer
Open My Computer and check to see if your CD or DVD drives have returned. You may also want to open Device Manager and verify that the yellow exclamation and error code on the CD or DVD drive is gone.
hope this helps
Jan 24, 2011 | Tascam CD-RW2000 Burner
This is a dvd recorder for a tv the door door to yhe dvd will not open
sounds like something has jammed in the drawer track
on the front of the drive is a very small hole
that is the manual open override
use a paperclip and push it into the hole as far as needed until the drawer opens
then slowly open the drawer by hand
look on both sides of the drawer to make sure there is no dirt or other foreign matter in the tracks where the drawer opens
Dec 16, 2010 | Lite On LiteOn 16X Dual Layer DVD...
Lite on drive drawer is sticking. wont open
Sounds as if you may have a disk in there that's lodged between the tray and the inner mechnism. Use the release pinhole, and a small screwdriver or butter knife to pry open the tray, gently. You'll feel it releasing when you insert a straightened paperclip or other small object.
Oct 25, 2009 | Lite On LH-20A1H DVD RW Dual Layer Burner
Cd burner drawers wont open or close
sounds like a bad cd rom. as cheap as they are the best option is to replace.
Mar 19, 2009 | Dell Dimension 2400 PC Desktop
Soap dispenser drawer jammed
Dear SK8RMOM,
ngfam at you service!
This sounds like it will only fixed by service
Yes sounds like you need service!
Call A&E Factory Service /They service nation wide
And are available 24/7 for making appointments!
If the appliance is 10 years old or more,it may make sense not to invest any money to fix it!
Happy to assist you,
Neil
PS.Before you sign off!
PLEASE GIVE ME A GOOD RATING HERE ON FIXYA.COM
Aug 25, 2008 | LG WM-2277HW Front Load Washer
Cant use yahoo messager
welcome to fixya
sounds like your firewall is blocking it goto your firewall settings and allow that program through
hope this helps out have a good day :)
Jul 19, 2008 | Acer Aspire 5500 5570-2609 Laptop
Tascam CD-RW2000
THE CARRIAGE UNIT (CD TRAY) is damaged, replace the tray
or the drive
or u can use it as is until its dead
Nov 08, 2007 | Tascam CD-RW2000 Burner
Frozen
take the burner to be reaired sounds like on of the chips have gone for the burner to give you the freeze out then won't turn off. hope you get this sorted.
Aug 15, 2007 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Tascam CD-RW2000 Burner Logo
162 people viewed this question
Top Tascam Computers & Internet Experts
Ben Armstrong
Electric Dime
Electric Dime
Are you a Tascam Computer and Internet Expert? Answer questions, earn points and help others
