Question about JVC HD-61Z786 61" Rear Projection HDTV
Have lamp message in JVC HD-52Z585 to replace lamp #TS-CL110U.
Is it smart to replace when I( have read so much on new bulbs failing....is it worth replacing? thanks
  • 556 Answers
I would, it's cheaper than replacing the whole TV and you can do it yourself so no labor bill. The new lamp usually comes with directions and in my experience the JVC lamps are outlasting some of the other ones.
Posted on Sep 10, 2009
    Problem Solver:
  • 12 Answers
Its about time somebody steers a person into fixing it themseles instead of tv repairmen saying bring it to them, its as if they are here to make money not help the common man!!
Posted on Feb 08, 2010
When you turn the tv on it makes a buzzing sound 3 different times and remains black
Sounds like you just have a bad lamp. The buzzing sound would be the spark gap on the ballast trying to fire the lamp. Access door for the lamp is on the side in the rear. A few screws and pull it out, you'll prob find that the glass has broken inside. New lamp part# is TS-CL110U and around $170
Bill W
integrityhomeworx.com
Mar 09, 2011 | JVC HD-52Z575 52" HDTV
61 inch projection tv flashing on and off
The most common problem with JVC LCD rear projection TV is bulb failure. Do not panic, this is normal after 2-5 years of use.
You can change the complete assembly or for less cost just change the bulb. Do not use Osram or other funny brand "rebuilt" or locally made bulb. Use a Philips replacement and all should be good.
Changing the bulb involves removing the lamp assembly and taking it apart like a puzzle and replacing the bulb. JVC are a little more difficult to do than most others because the wires on the original bulb are molded into the glass on the original bulb. Wires must be cut and stripped of insulation before connecting to the new bulb.
All JVC LCD Rear projections TVs use TSCL110 TSCL110U TS-CL110U Lamps.
HD-61FB97 HD-61FC97 HD-61FH96 HD-61FH97 HD-61FN97 HD-61G587 HD-61G657 HD-61G787 HD-61G887 HD-61Z456 HD-61Z575 HD-61Z575AA HD-61Z585 HD-61Z786 HD-61Z886
Check this out for all JVC models to identify the lamp and bulb. JVC Gallery.
easyab
Apr 22, 2010 | JVC Televison & Video
TV was on and had a picture, and then nothing w/flashing power
Your lamp has blown. Time to get a new one.
the hyperlink button doesn't seem to be working, but just copy and paste this link into your browser. It is linked directly to your tv's replacement bulb.
http://www.discount-merchant.com/JVC-LCD-Projection-TV-Lamp-TS-CL110UAA-TS-CL110U-p/jvc-ts-cl110uaa-hd-56fn97.htm
Nov 11, 2009 | JVC HD-56FN97 56" Television
Power button flashes blue continously and TV will not turn on.
The lamp is probably gone. Part # TS-CL110U. Easy to change yourself.
Apr 15, 2009 | JVC HD-56G787 Television
Projector lamp part number ts-cl110u
There aren't any issues being reported as far as I know. If you ever need to get a replacement TS-CL110U, you can actually get one for $155, brand new with free shipping.
Aug 25, 2008 | JVC Televison & Video
Jvc hd -61z456
These guys are correct, you need a new dlp lamp. The lamp # for your particular television model is the TS CL110UAA.
Apr 21, 2008 | JVC HD-61Z786 61" Rear Projection HDTV
TV not turning on
This is the lamp error code. The lamp part# for your unit is
TS-CL110U. Hope this Helps.
Mar 21, 2008 | JVC HD-52G886 52" Rear Projection HDTV
Looking to buy part# TS-CL11OU. Looking for a JVC service center in my area. I live in Oxon Hill, MD 20745
There are no registered JVC service centers in your area for a rear projection HD. The closest one it shows is Cypress, CA...which isn't a lot of help for you.
I found this part on several websites as well as Ebay and JVCs website.
This website had it for about $160.
jvc-ts-cl110uaa-new.htm&Click=98
I also found a website that had a great "How To" with steps on replacing it once you get the bulb.
http://fixyourdlp.com/blog/?p=10
Feb 12, 2008 | Televison & Video
Blank Screen; Blinking Blue Light.
try to re seat the bulb again dont touch it lens or anything unplug ist as u do then reset timer on it ok in menu maby it just not in tight or came loose after 1st heat
Jan 21, 2008 | JVC HD-52Z585 52" Rear Projection...
Jvc tv
It may be lamp, Look at the lamp and see if there is any discoloration inside, but do not touch the lamp glass. The oils from your hand will heat up and blow the lamp. The lamp part# for your model is TS-CL110u. Hope this helps.
Dec 15, 2007 | JVC HD-52G886 52" Rear Projection HDTV
JVC HD-61Z786 61" Rear Projection HDTV Logo
420 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
