Question about Texas Instruments TI-73 Explorer Calculator
Upside down display
I have a TI-73 calculator that has the display showing upside down. There must be a way to fix this! Help!
  • Anonymous Mar 17, 2014
    ti-82 upside down
    President:
  • 566 Answers
I have read that to invert the LCD-screen you just flip the polarisation-plate (the plastic film that sits over the LCD display) 180º, that is, upside down.
Did you or someone opened your calculator? He might have reassembled it wrong. Or was it a prank?
If that was not the case, your best change is to reset the calculator and see if it solves your problem.
To manually reset your graphing calculator:
  • Remove all AAA batteries.
  • Remove the back up lithium battery.
  • Leave the unit empty for 5 to 10 minutes.
  • After the 5 to 10 minutes, place all the batteries back into the graphing calculator.
This process should restore the graphing calculator to the factory settings.
Good Luck!
Posted on Sep 10, 2009
How do I fix display show upside down. TCL LED TV Model: L24T2100
http://www.tomsguide.com/answers/id-1989729/picture-flipped-upside-fix.html
Feb 20, 2015 | Televison & Video
How to fix in upside down calculator screen
The calculator may have been subjected to a hacking procedure found on the Internet. Find a way to undo the hack or buy another calculator. Or hold it upside down to read the display (once you get the last result.)
Jul 11, 2014 | Casio FX991ES Scientific Calculator
Fix an upside down screen
Try doing a calculator reset - remember to get anything you have stored off of it before you reset!
2nd, mem, reset - try all ram, then defaults
Mar 12, 2014 | Texas Instruments TI-83 Plus Calculator
Screen upside down
I have seen a lot of questions of this sort but I have never this this inversion in a calculator. You could try to reinstall the Operating system. For the TI83 Plus, the last OS version is 1.19. If it is a TI84Plus/TI83 Plus Silver Edition the OS version number is around version 2.55 MP.
Oct 12, 2013 | Texas Instruments TI-83 Plus Calculator
Screen appearance
Check this article. It will show you how to force the reinstallation of the OS. If that does not solve your problem, you may have to send calculator for service.
Hope it helps.
Oct 08, 2009 | Texas Instruments TI-83 Plus Calculator
Numbers are upside down. How do I turn them around?
Frankly, I would love to see that. More seriously, now, if problem is software related you may be able to recover you calculator.
Use the link below to install TIConnect software
http://education.ti.com/educationportal/sites/US/productDetail/us_ti_connect.html You can also download the latest OS there.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. It will try retrieve the info.If it does your calculator is fine. Fill the screen with letters, symbols, numbers, and use TI connect ScreenCapture icon and compare the image with the actual screen. This may serve as a diagnostic tool in case you have to take calculator for repairs.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and try OK. If you are lucky and it works, you should reinstall the OS, which can be downloaded from education.ti.com. You drag and drop the OS on the TIconnect main window. Calculator must of couse be connected to computer.
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators are ready hit [ENTER])
If all that does not work, then it may be time to head for a place of worship to pray for its resurection, or look for a repair shop.
Hope it helps
Aug 17, 2009 | Texas Instruments TI-83 Plus Calculator
My TI-83 types numbers or shows menus upside down now
You sould reinstall the operating system.
Install TI connect on your computer and run it to open the main Window. Then connect you calculator to a USB port and, in the TIConnect main window Click the TIDeviceInfo icon. Software will try to retrieve the info. If it does your calculator is fine.
If it tells you Device Not found , Click communication settings in same pop up window where it said Not found, and Select Device, Select Cable, Select Port and Click OK..
If you have problem with TIconnect, use the calc-to-calc cable to transfer the OS of a working calculator. Yous should be on Receive mode [2nd][Link] --->>Receive. (When both calculators are ready hit enter.) The other calculator, you guessed exactly right, must be on Send [2nd][Link][SEND][G:SendOS]. (When both calculators hit [ENTER])
Hope it helps
Jun 20, 2009 | Texas Instruments TI-83 Plus Calculator
Screen is upside down as I type
Wow. Just wow. How did that person do that?! Anyways, try resetting ALL of the memory, and see if that helps, if not, ask the student what she did so that it can be reversed (probably by doing the same steps in the opposite order.
May 21, 2009 | Texas Instruments TI-84 Plus Calculator
Texas Instruments TI-73 Explorer Calculator Logo
850 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
