I need the remote control code for the Rogue Audio 99 Magnum Tube preamplifier. It has only one control as its only function is volume
  • 11,896 Answers
You can get it from rogue or from replacementremotes.com or ebay
Posted on Sep 10, 2009
Have not been able to get it to work to turn TV on & off and on sound---
Try by set it up with an other set-up code said for your device brand. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list,
use the Auto Code
Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may
be another code
in the code list that performs more functions. Try other codes from the code list for more functionality.
PROGRAMMING PROCEDURE
Direct Code Entry
Locate the Remote Code List provided in this manual. Find the DEVICE CATEGORY you wish to program (for
example TV, CBL,
DVR, DVD, SAT, AUDIO, AUX1, AUX2) and then find the BRAND of that device. Circle all the codes under that
brand. Example: For a GE TV, locate the TV code section then circle all of the GE TV codes.
Manually turn on the device you wish to control.
Press and hold the SETUP button until the red indicator light stays on (approximately 2 seconds) and then release
the SETUP button.
Press and release the desired device button on the remote (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2). The
red indicator will blink
once and then remain on.
Enter the first 4-digit code previously found in the code list using the number buttons on the remote. If the code
entered is a valid code, the
red indicator light will turn off. If the code entered is not a valid code, the red indicator light will flash and remain on
allowing you to re-enter the code.
[If no buttons are pressed for 35 seconds, the remote will exit the SETUP mode and you will have to start over.]
Point the remote at the device. Press the POWER button, if the device turns off, no further programming is required
for that device. If the device does not turn off, return to step 3 and use the next code found in the code list. Continue
this process until a code for your device is found.
To view a helpful demonstration video for programming your ONN remote, see QR code.
• You can use any device button to control other devices in your home entertainment system. For example, you can
use the AUX1 device
button to control an audio receiver or a DVD, VCR, satellite, etc.
• For combination devices, you may have to enter a code for each device. For example, for a VCR/DVD device, you
may have to enter a
code for the DVD under the DVD button and enter a code for the VCR using a different device button on the remote.
• Write down the code found to operate your device for future reference.
Auto Code Search
The Auto Code Search searches automatically through all of the codes stored in this remote. Read all the following
steps prior to starting the auto code search as you will need to be prepared to lock-in the proper code when found.
1.Manually turn on the device you wish to control.
2. Press and hold the SETUP button until the red indicator light stays on (approximately 2 seconds) and then release
the button.
3. Press and release the desired device button on the remote (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2).
The red indicator will blink once and then remain on.
4. Point the remote at the device and press and release the POWER button (for TV) or PLAY button (for DVD, VCR,
etc.) to start the search. The red indicator will flash (approximately every 2 seconds) as the remote searches. Note:
The remote must be pointed at the device for the duration of this search.
5. Place your finger on the #1 button so you are prepared to lock-in the code.
6. When the device shuts off or begins playing, press the #1 button to lock-in the code. The red indicator light will turn
off. Note: You have
approximately two seconds after the device shuts off or begins playing to lock-in the code.
7. Point the remote at the device and check to see if the remote operates the device as desired. If it does, no further
programming is required for that device. If it does not, return to step 2 and start the auto search.
• This process may take several minutes as the remote contains many codes.
• The SETUP button can be used during the search process to reverse the direction of the search of the remote
codes. For example, if you miss the code for your device and the remote is continuing to search (as indicated by the
blinking red light), press the SETUP button and the code search will reverse direction and return to the code.
• When using the Auto Code Search programming method, the device button corresponding to the type of device you
want to control must be selected (for example, the TV device button must be selected in step 3 if you want to control
a TV, the DVD/VCR device button for a DVD player, etc.)
be another code in the code list that performs more functions. Continue the code search as directed above until the
best code is found.
Controlling Combo Devices
Some Combo devices (e.g. TV/VCR, TV/DVD, DVD/VCR, etc.) will require you to setup up two different Mode
buttons to control both parts of the Combo device. For example, if you have a TV/DVD Combo, you might need to set
up one code under the TV button to control the TV part AND a separate code (under any other Mode button) to
control the DVD part.
Master Volume Feature
The Master Volume Feature allows you to select a single device (TV or audio receiver) that the volume control
always controls. For example, the remote can be in TV mode while the volume buttons control the volume on your
audio receiver instead of your TV.
Enabling the Master Volume Feature
Press and hold the SETUP button until the red indicator stays on (approximately 4 seconds) and then release the
button.
2. Press and release desired device button (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2) for the device you
wish to setup to control
the volume.
3. Press and release the MUTE button.
4. Press and release the VOL + button. The red indicator will blink twice and then go off. To test the feature put the
remote in another mode such as the TV mode if you programmed the audio receiver to be the Master Volume
Device. Point the remote at the audio receiver,
press and hold either the VOL + or the VOL - button. If the audio receiver volume changes then the remote is
programmed correctly. If the TV volume changes and not the audio receiver, you will have to repeat the steps above
and test again.
Disabling the Master Volume Feature
Press and hold the SETUP button until the red indicator stays on (approximately 2 seconds) and then release the
button.
2. Press and release the device button (TV, CBL, DVR, DVD, SAT, AUDIO, AUX1, AUX2) which is programmed to
control the Master Volume Feature.
4. Press and release the VOL - button. The red indicator light will blink twice and go off. To make sure the Master
Volume Feature is disabled, put the remote in TV mode if you programmed the audio receiver to be the Master
Volume Device. Point the remote at the TV and
press a volume button. If the volume changes on the TV, the feature is disabled. If the volume on the audio receiver
changes, and not the TV, you will have to repeat the steps above and test again.
Reset to Factory Settings
button.
2. Press and release the MUTE button.
3. Press and release the number #0 button. The red indicator light will flash twice.
Remote does not operate your device.
• Make sure the batteries are fresh and installed correctly.
• Aim the remote directly at your device, and make sure that there are no obstructions between the remote and
device.
• Make sure you select the appropriate device on the remote you wish to control, for example, TV for TV, DVD for
DVD, etc.
• Try programming the remote with a different code. See Direct Code Entry section.
• Remote may not be compatible with your device.
Remote does not operate some features of your device.
• Sometimes a particular code might operate a few features but not all. Try programming remote with a different code
from the code list.
• Remote may not be able to operate all features of your device or button names may be different than that of your
original remotes.
Remote Code is not available for a combo device (e.g. TV/VCR, TV/DVD)
• Some Combo devices (e.g. TV/VCR, TV/DVD, DVD/VCR, etc.) will require you to set up two different Mode buttons
to control both parts of the Combo device, For example, if you have a TV/DVD Combo, you might need to set up one
code under the TV button to control the TV part AND a separate code (under any other Mode button) to control the
DVD part.
Jan 06, 2016 | JVC Remote Control 118579 6.0 p/n:118579
My New Xfinity XR 5 remote codes will not turn my receiver on & off . OOnly control Volume & Mute.
You either have the wrong remote code or it may be a case where-as the remote will not properly operate "all" functions. Wrong programming "codes" with universal remote controls often operate some but not ALL functions and some remotes are unable to duplicate every function. If all else fails, you use two remotes with one for Xfinity and one that came with your stereo.
Mar 28, 2015 | Yamaha RX-V665 Receiver
How fix talkback in magnum delta force
you need to check the audio path from the chatback board to the audio circuit
usually the audio out the board will go to the center connection
on the volume control
sometimes people use a resistor to attenumate it to a level
or a T pad
and connect it to the left side {audio out to amp}
so a volume control works like this
left center right
ground audio into control audio to amp
so usually the center is used as the volume will track up as your sets volume is increased
so simply connect the audio out from the chatback
to the right audio to amp section
on the chatbacks ive made and installed in the past
had a small pot on the board
this allows the volume from it too be increased
so look for this first
if you cant find it you can make one up like this
100K log pot 3 pin
1 2 3
L M R {left middle right}
1= ground
2= audio from chatback
3= audio to the right right audio to amp on the cb's volume control
then no matter what level the actual audio from the set is set too
the chatback can be set to a standard level for all
hope this helps you
i used too build chatbacks for the rnid year back and fit them free
Dec 02, 2014 | Magnum DeltaForce CB Radio
How do i connect my amp to my vizio tv there are right and left outputs on tv but only one input on back off amp
Typically you need an preamplifier between your tv and amplifier. you run one optical cable (or coax ) cable from you tv audio output to the preamplifier then you run audio rca cables from preamp outputs to amp inputs (2 for stereo 5 or 7 for surround). the preamp decodes audio and controls volume and surround modes.
If you have a cable box and need just simple setup for watching tv just run rca cables from your cable box audio outs to your amp inputs. you then program your cable remote control to control volume.
Oct 29, 2013 | B&K Reference 7250 5-Channel Amplifier
I dont have the remote. is there a volume control on the system?
No. Volume for external sound sources is usually left up to the preamplifier or amp.
The remote is available here for under $30...
http://remotes.com/remotes/servlet/rs?a=gmi&uuid=12969479069380&smodel=SLMC4&brand_pn=TECHNICS_SLMC4
Feb 05, 2011 | Technics SL-MC4 61-Disc CD Changer
I have put an equalizer on to my technics saex-310 just wondered can I use it on my amp
I am afraid the equalizer cannot be used on an amplifier only. The receiver has a power section and "preamplifier" section as well, meaning it has power and a control section for volume, etc. There must be a control section present for the signal from the equalizer to be processed. Just the power amplifier by itself is not enough to process the signal. You will need a preamplifier section as well to do the job.
Oct 31, 2010 | Audio Players & Recorders
My cable tv remote will turn this unit on with the codes supplied for the remote. But the remote will not control the volume or turn the unit off. Is there another code, or is this a problem with the cable...
There has to be another code and when you find it you will probably have to "lock" your remotes volume control to your audio device not the cable box (set-up that way from cable co) once you do that the cable box will be controlled from the remote(channels) and the audio will be controlled by your receiver from the same remote without even having to switch functions.. ask your cable company for a setup guide for your remote they will probably have a copy online.
Nov 27, 2009 | Onkyo TX-SR606 Receiver
The volume doessnt go very high on my zenith 32' tube tv.
Hello daymakerserv,
Ok you are correct these sets have a master volume control accessible fro the remote control only. If you have the remote go to menu Audio settings and possibly advanced audio settings and you should see the master audio setting. Now you have to have the remote to do this. If you do not have the remote control, you will have to order them from the manufacture, they do have the model of remote that will work with these sets or they can provide an OEM remote that will allow you to access these functions. A universal remote may not work in gaining access to the master settings, so it is best to contact the manufacture and get either an exact replacement or one of the OEM models of remote.
I hope this helps,
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Mar 25, 2009 | Zenith B27A11Z 27" TV
Comcast remote
The volume keys should be working by default, but you may have volume punch through turned on (meaning the remote is sending signals for TV or CABLE volume function no matter what mode you are actually on). To unlock volume control for AUX mode, do the following:
1. Press and release AUX
2. Press and hold SETUP until the remote blinks twice
3. Type 993
4. Press and release VOL-
The remote should blink four times to confirm unlock.
Jul 05, 2008 | Yamaha RX-V1400 Receiver
44 people viewed this question
 Grubhead
Grubhead
