Question about Canon PIXMA Pro9000 Photo Printer
Cannot print 11x14 paper on my Canon Pro9000 printer.
I am trying to print with 11x14 Adorama Photogloss paper. There is no 11x14 size listed in the printing preferences dialog. I have tried installing the printer profile for the paper with no luck. How do I print 11x14 on my Pro9000?
Thanks, Cameron
    President:
  • 2,306 Answers
The printing software you are using should have that size for you, I use photo gallery, after you select the image the pop-ups should be your printing software with the paper size choices.
Posted on Sep 10, 2009
I wish I had one, because I have the same problem(:
Posted on Dec 16, 2012
Canon pro 9000 printing not printing vibrant colors
I've had 5 Pro9000 & Pro9000 II's so far. Mechanically sound and fairly heavy duty. Mostly by default they print muddy or muted, with unsatisfactory reds and yellows. The default settings usually suck. I have had to develop my own driver settings and save them to printer profiles for individual situations. There is a lot of control in the driver settings and I recommend making your own color charts for reference, displaying the settings on each page. I also recommend regular nozzle checks and calibration. Avoid cleaning via the driver utility as this wastes a lot of ink, which is all deposited on the bottom of your printer and eventually has to be dealt with. Instead, remove and soak the head. Completely dry before reinstalling.
Jun 26, 2014 | Canon PIXMA Pro9000 Printer
Printing 11x14 photos
First use a photo processing programme (like say Photoshop or PS Elements - or if you have not got that (can be expensive) get the free Faststone Image Viewer and size the image to twice the paper size you want, then use the crop tool to select half the image and save that as a file with a name where you can find it again. Do the same with the other half. You will now have two files, each half of the paper size. As they will have small borders, print and trim the borders, so you can then mount side by side to achieve what you want. I would advise to NOT try and print without borders - that can introduce other problems - just accept having to trim the small borders from normal printing.
Apr 09, 2014 | Epson Stylus NX230 Small-in-One USB...
Canon pixma pro 9000 - when printing the paper goes in a couple of cm and gets caught (on the right corner) and tilts to the left side I can hear the rollers spinning but printing ceases
Hello! To solve your problem follow the instruction. 1. Paper must be straight, don let them curve. 2. Paper must not wet, should be tried. That is the only way to solve problem.. good luck
Sep 09, 2011 | Canon PIXMA Pro9000 Printer
My Canon Pizma Pro9000 prints photos that contain TOO MUCH black in it. All the colors appear to be much darker than on the screen. And when I lighten the pics, it doesn't help since all the shadows are...
Hi
I suggest you clean it manually by removing the ink cartridge and rub the print head into a paper with alochol and then run the print nozzle for 2 times to clear some ink residue that cause darken color
Mar 08, 2011 | Canon PIXMA Pro9000 Printer
Canon Pro9000 MarkII roller squeal
You do not use lubricant on printers. Clean all roller and bars with Q tip and acohol. Make sure alcohol is squeezed out so it does not drip inside printer. The noise should stop. If it does not it is the belt that drives the capstans (rollers) that is worn out.
May 28, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
My Canon Pro9000 stopped printing anything on the paper. Goes through the motions of printing, but paper is blank. Just put in a new black cartridge, other cartridges have since run out in an effort to do...
Either pay $40 to $60 to have a qualified technician trouble-shoot the printer, or spend about the same amount to buy a new printer.
Or, if the printer is still under "warranty", then "exercise" the warranty.
May 14, 2010 | Canon PIXMA Pro9000 InkJet Photo Printer
How do you fax a document that is 11 by 14 inches?
Most fax machines and printers will scan and fax an 11x14 document. Just check your owners manual to see if any settings need to be changed AND contact the person you are faxing to let them know to put 11x14 paper in their machine, or some of the print may be lost if the fax will be printed on two 8x11 sheets.
If you don't have your owners manual, post a question and include the manufacturer and model number of your fax machine or printer and one of us will look it up for you.
Feb 10, 2010 | Office Equipment & Supplies
I want to use 11x14 paper on my dj1280 but it is not in the menu. neither is there a provision for user-defined paper sizes. what to do?
The 1280 isn't compatible with 11x14 paper. You can either use legal size (8.5x14) or ledger size (11x17), but you can't customize it to use 11x14.
The best solution would be to print onto 11x17 paper and then cut it to 11x14.
Jan 14, 2010 | HP DeskJet 1280 InkJet Printer
I put in 11x14 size paper in tray 2(11x17) but only get 8.5 inches of width printed instead of 11 inches. how do i solve this problem? thanks, joe.
Go in [user tools /counter]=>[system settings]=>
=>[paper size settings]
Please telll me for what machine you talk about
Jul 16, 2009 | Office Equipment & Supplies
How can you print on 11 x 14 paper borderless with a canon 9000?
sir just read the manual if your printer is capable of printing 11X14 borderless.
thanks
alecz
Apr 23, 2008 | Office Equipment & Supplies
Canon PIXMA Pro9000 Photo Printer Logo
785 people viewed this question
old marine
old marine
