Question about HP Photosmart C3180 All-In-One InkJet Printer
Print cartridge(s) missing or not detected
When I try to use my c4380 hp printer the window shows "print cartridge(s) missing or not detected. I have replaced the black 350 cartridge with a new one but the problem remains.
  • margemarino Sep 29, 2009
    i have a printer that is reading print cartridge (s) missing or not detected what do i do i can't use copier
I have installed colour cartridge 351XL and black 350 cartridge but my printer still says Print cartridges missing or not detected
Have you removed the shipping tape from the print cartridge? It covers the print head on the cartridge to protect them so they won't leak ink.
Nov 01, 2010 | HP Photosmart C4280 Aio Printer
Printer: HP C4599 All in One, Limited Ed Wireless Error message Printing cartridges missing or not detected. both cartridges are in the printer. This error message appeared 4 days ago, Have any idea...
I suggest you try to reset the printer. remove the cartridges before starting these steps.
1. Press the Power button and the Cancel button at the same time and release them. The display will show 'Enter Special Key Combo'.
2. Now press the Blue(Scan), Green(Color Copy) and Grey(Black Copy) buttons one after the other. The display will show 'Support
Oct 03, 2010 | HP Office Equipment & Supplies
I have a problem with my hp c4380. Says print cartridge missing or not detected?
Feb 23, 2010 | HP Office Equipment & Supplies
Brand new Print cartriges not being detected...
If 350 & 351 are the original cartridge, you can ask to the cartridge seller for a guarantee. There is a chip inside the cartridge, sometimes the printer firmware failed to detect the chips. Or you can try to find, by Googling "C4272 Resetter Software" to download it.
Sep 06, 2009 | HP PhotoSmart C4180 All-in-One Color...
HP Officejet printer, says cartridges are missing or not detected
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr11
Aug 13, 2009 | HP Officejet 5610 All-In-One InkJet...
HP 2550L printer
Theblack print cartridge is empty or missing. The black-print-cartridgelight is blinking, and then printer stops printing. An error 40208 iswritten to the event log. The printer cannot detect the print cartridgecorrectly. Action
  1. Reinsert or replace the print cartridge.
  2. If the print-cartridge light is still blinking but the Attention light is not on, turn the printer off, and then back on.
  3. If the problem continues, contact HP Customer Care at http://www.hp.com/support/clj2550 or see the flyer that came in the printer box for other contact information.
Mar 24, 2009 | HP LaserJet 2550L Printer
Cartridge not detected or missing message.
did you remove the tape from the new cartridge ?
Dec 23, 2008 | HP PhotoSmart C4280 Laser Printer
Hp photosmart c4380 replacing color ink cartridge with cartridge 99 not fitting
There is some confusion about the 99 cartridge. The info for the C4380 says that the 99 Photo cartridge is an option, but HP's website doesn't show the 99 cartridge as compatable with the C4380. It goes from C4280 to C4385.
Here is their list of compatable printers: HP 99 Cartridge Compatability
I would suggest you contact HP via email and get some clarification whether it will or will not work.
Here is a link to their Contact page: HP Contact
Sorry I couldn't be more help.
Oct 29, 2008 | HP Office Equipment & Supplies
Black cartridge problem
Try the steps mentioned in the link bellow:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01091133&cc=us&lc=en&dlc=en&product=1141647
If it still does the same then the printer is not detecting the ink catridge, the printer might have to be replaced.
Good Luck
Sep 01, 2008 | HP PhotoSmart C4180 All-in-One Color...
Light is flashing
check cartridge compatibility first:- HP Deskjet 810c HP15................black cartridge compatibility HP 23 ....................colour cartridge compatibility Issue ---A print cartridge is missing. Solution Install the missing cartridge. Issue --The printer detects a faulty, incompatible, or improperly installed print cartridge. Solution 1. Open the top cover of the printer. 2. Make sure the correct print cartridges are installed. Click here to go to the printer/cartridge compatibility chart. 3. Replace or reinstall the print cartridges. 4. Close the top cover of the printer. Issue ---The print cartridge contacts are dirty and the printer does not recognize the print cartridge. Solution Clean the contact points on the cartridges with a dry, lint-free cloth. 1. Open the top cover of the printer. 2. Remove the print cartridges. 3. Clean the copper-colored contact points on the cartridges with a dry, lint-free cloth. NOTE: Do not wipe the nozzle end of the cartridge or touch the silver-colored nozzle plate on the bottom of the cartridge. 4. Use a dry, lint-free cloth to remove the moisture from the contacts. 5. Insert the cartridges back into the printer. 6. Close the top cover. 7. Try printing again.
Sep 11, 2007 | HP DeskJet 810c InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
1,527 people viewed this question
Seeker5211
Seeker5211
