Question about Gateway T-1625 Notebook
Gateway T-1625 Laptop won't boot up - screen blank
When I press the power button, the fan comes on and the hard drive spins. The system does not begin the posting process and the screen is blank. The power button pilot light comes on and stays on. The behavior is the same whether I power up under battery or charger cord. I tried hooking up to an external monitor, but no image appears. I replaced the memory sticks and tested the hard drive on another laptop. I finally replaced the motherboard, using the same CPU. The problem remains the same.
At this point, can I assume the problem is a dead CPU?
    Brigadier General:
  • 10,406 Answers
Yes, if the CPU/motherboard will not POST (Power On Self Test), then changing the CPU is the only thing that you have not tried.
Posted on Sep 10, 2009
Gateway MP8708 Won't boot past BIOS and won't boot into CD/USB/Safe Mode on XP - Blank screen with keyboard dead - Num locks on and wireless light
Somehow your MBR (Master Boot Record) likely got corrupted or possibly your hard drive went bad coincidentally.
Simply, you will start your computer from your Windows CD/DVD install disk, then when at a DOS prompt ( D:\ ) you will then type: FDISK /MBR (press enter).
Find your Operating System install DVD and start your computer with it, then follow instructions within this discussion:
Restore Windows XP MBR without Windows XP disc
Alternatively, review my search results for other instructions:
fdisk mbr windows xp Google Search
Nov 22, 2017 | Gateway MP8708 Notebook
My Gateway Gt 5220 will not turn on. Technicaly it does turn on ex: hard drive spin processor click couple time power brick and processor fan spins hard drive light flickers couples time and cd drive will...
sounds like your system is booting up and running due to the hold power shutdown procedure. you might try replacing the video card or adding one if your video is integrated.
Dec 23, 2010 | Gateway GT5220 PC Desktop
I dropped my notebook about 5 feet about and when i booted the message was operating system failed.
First thing to do is determine the health of the hard drive. Enter the laptops setup on boot and see if the BIOS has a hard drive test utility. When you boot the laptop, look at the screen and find the function key (F10, F2, F12) that you will need to press to enter the BIOS. After that, look through the menus related to the hard drive and see if a test is in there.
Oct 27, 2010 | Gateway T-1625 Notebook
Gateway m-1625 laptop hard drive replacement
did you create a boot partition and format NTFS?
Nov 06, 2009 | Gateway M-1625 Notebook
Gateway screen comes up; optical and (new) hard drive spin up, both drive lights light up during this time, fan spins up and air moves out of the side vent continously but still nothing but a blank screen....
If you have an operating system disc that came with your computer try putting it is and see if you can load the disc. If you can go to the repair screen after it loads all files. When you are at command prompt type: chkdsk /r
It will try to repair operating system. When done type "Exit" and restart. If you can't load the operating system disc you might be having a graphics card problem. Go to the manufacturer's website and check on their forums for your problem. Hope this helps
Jul 05, 2009 | Gateway MX6931 Notebook
Gateway t 1625 laptop not booting
If u can, try to reformat it, reason i say this simple solution is because u already had the laptop looked at professionally, and due to you're laptop being stuck at the windows screen, i see this happen on HDD swaps a lot. The HDD needs to be repair-formatted or fully reformatted to talk to the new mobo when switched out, try this if all else fails, i personally think giving this simple solution may fix the boot up issue, but do make sure ur friend who looked at your laptop hadn't reset ur C MOS and may of not reconfigured it, this may also be the main cause of boot up troubles so make sure everything looks fine in ur BIOS. Gabriel will have a more proper solution than this but i believe by doing this it may help u bypass ur loading issue
Jun 24, 2009 | Gateway T-1625 Notebook
I have a gateway laptop model MA7and it wont start up.
It is not a hard drive issue. If hard drive is a problem system wont boot till motherboard processor. Try to reinstall your OS. It will fix your issue.
May 14, 2009 | Gateway (M520HD80G) Hard Drive
Gateway m 1625 operating system not found and its overheating
This means either the operating system on your hard drive has become corrupt and you will need to reinstall your operating system or, more likely, your hard drive has failed and you will need to replace the hard drive and the operating system.
As for your heat issue, use a can of compressed air and blow out all the vents on your laptop. This should help the heat issue; note that it is common for the laptop to feel hot as it is dissipating the heat from inside.
Thanks and please take a moment to give this solution a thumbs up rating with a solved solution as I answered your questions. Thanks.!
Apr 05, 2009 | Gateway T-1625 Notebook
I have a Gateway Mx6440 Laptop and et CPU FAN error upon boot. afte w while i try spinning th efan and it starts working, i belive it is the heat sink that is defective but where can i find the proper fan...
"Turn off computer and unplug power cord. <br>Disconnect all external devices. <br>Remove the battery. <br>Press power button and hold for 10 to 15 seconds. <br>Plug power cord back into computer and press power button. <br>Check front panel LEDs (lights) on bezel (front face) or optical drives and listen for power supply fan. <br>If LEDs are on or power supply fan starts spinning, watch for boot screen on monitor. <br>If computer begins to start, turn it off. <br>Reconnect any external devices. <br>Press the power button and make sure the computer starts.
Please save this steps and go through that. If in case you require further help, you need to contact Answers by Gateway department which is a paid support. The phone number for Answers by Gateway is 1.800-237-6483. Or please consider contact with a local technician for a detailed troubleshooting."
worked for mee!! good luck
Feb 22, 2009 | HP (158800-001) for Compaq Presario 1246,...
Gateway T-1625 Laptop won't boot up at all
It sounds like a motherboard issue. The fan spinning and the LED lights are running off of battery power. This indicates that power is getting to the system. You should look into replacing the motherboard at this point. Before you replace the motherboard feel your system to see if there are any really hot spots that would indicate overheating. If not proceed with the replacement. If so, let me know where the hot spot is.
Regards
Dec 20, 2008 | Gateway T-1625 Notebook
Gateway T-1625 Notebook Logo
926 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Alun Cox
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
