Question about Sport & Outdoor - Others
I have 2003 jayco qwest popup camper need to replace section of floor. Can I remove rear body panel to get acces to floor
3 Suggested Answers
canbruce75
  • 1776 Answers
SOURCE: Jayco lift system cable replacement
Try this link and see if it will help you any with the info that you need. Sure hope this helps you find resolution to the problem. Best wishes.
http://www.ehow.com/how_4708883_repair-jayco-camper-cables.html
Posted on Jul 23, 2009
canbruce75
  • 1776 Answers
SOURCE: Broken Cable on Pop-up trailer need help
Posted on Sep 06, 2009
Need repair manual 1406 jayco
What year and style of 1406 Jayco?
Jayco has a series of repair videos on YouTube. "YouTube Jayco 1406 Camper Repair " got me to the videos.
You have not described the type of repair you need to do.
Aug 23, 2017 | RVs
I want to replace canvas on jayco camper
take the camper to a jayco service center and get the correct replacement items for that camper
then it is a matter of removing all the fitting strips to allow removal of the old canvas and the fitment of the new items
a clue her is to when the new canvas id fitted is to leave the camper opened up and to wet the new canvas with silicon fluid and allow it to dry put before folding it away
why , it stops water coming through the canvas when touched in the rain and prevents mould if folded away when wet
Jun 14, 2016 | Jayco 2008 Baja 10Y
Can I pull a Jayco camper trailer with my 2003 saturn vue 4 cylinder
Any vehicle can tow a trailer, but you have to think about the ability of it to brake hard if you need it to. In your case I would say no problem. A braked trailer helps.
Aug 13, 2015 | 2003 Saturn VUE
Where is the ignitor for the furnace in a 1998 flagstaff popup camper
This is the car and truck section. You may want to repost this in the RV section, or contact the company that built the camper.
Sep 26, 2012 | Cars & Trucks
How i can replace the gearshift?
SECTION 501-12: Instrument Panel and Console 2003 Expedition/Navigator Workshop Manual
REMOVAL AND INSTALLATION Floor Console -Front, Navigator Removal and Installation
  1. Apply the parking brake.
  1. Position the front seat forward.
  1. Remove the two front floor console rear bolts.
  1. Position the front seats rearward.
  1. Disconnect the battery. For additional information, refer to Section 414-01 .
  1. Remove the pin-typ retainer and the window control switch panel.
    • Disconnect the electrical connectors.
  1. Move the shift lever to NEUTRAL and position the shift indicator bezel aside.
  1. Remove the screws and the center console finish panel.
  1. Disconnect the shift cable.
  1. Disconnect the front floor console electrical connectors.
    1. Loosen the electrical connector bolt.
    1. Disconnect the connector.
    1. Disconnect the electrical connector.
  1. Remove the front floor console side finish panel.
    • If equipped, disconnect the electrical connector.
  1. Remove the front floor console front bolts.
  1. Remove the floor console.
Feb 13, 2011 | 2003 Lincoln Navigator
Jul 23, 2009 | Sport & Outdoor - Others
Broken cable in older Coleman pop-up camper...how to replace it? Can't see in body of camper where the cable needs to go through to the posts that raise the top.
This camper uses the Coleman lift system which uses a threaded rod that connects to a tracked distribution block to which all four cables are connected and then routed by pulleys to all four corners of the popup.First raise the popup to it;s full height by using automotive jacks and poles once extended securely clamp the poles to the telescoping up rights This IS SUPER IMPORTANT FOR YOUR SAFETY. Next get under the camper find the broken cable unbolt it's routing pulley(s) pass the broken ends out the pulley(s).Next unbolt the end from the distribution block. followed but unbolting the cable from in side the telescoping column;carefully note the routing in side the column. Buy or make up an exact length cable of aircraft grade stainless steel twisted wire cable of the same gauge. Reverse steps to re install,take lowering strain on crank make sure crank handle is captured by anti free wheeling device on camper un clamp poles remove, lower and raise top by crank to ensure smooth working. You're finished.
Apr 19, 2009 | Coleman Sport & Outdoor - Others
How can I remove gear shift knob on a 2003 Navigator?
it looks like you disconnect the shift cable and remove the center console finish panel with the shifter.
REMOVAL AND INSTALLATION Floor Console —Front, Navigator Removal and Installation
Apr 17, 2009 | 2003 Lincoln Navigator
Sport & Outdoor - Others Logo
166 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
