Question about HP Color LaserJet 5550hdn Printer
No power on hp color laserjet 5550
My hp color laserjet 5550 has no power i changed the LVPS and DC controller board what next
    Problem Solver:
  • 12 Answers
Firmware Dimm on the Formatter Bd.
Posted on Nov 22, 2009
    Problem Solver:
  • 14 Answers
Here http://www.generalmanual.com/Printers/HP-Color-LaserJet-5550dn-Printer.htm
you can download this is printer user's guide (under "download now" near the bottom of the page) help you.
Posted on Sep 10, 2009
Error code 55.4k
This error 55.4k appeared in printer hp color laserjet 5550. The following trouble shooting did. Orignally my printer fault is display blank.Then i replace dc board with formatter board. blank is gone dueto new ram.Machine display showed the memory process. but immediatly the error 55.4k appeared on display.The reason for this error is, communication failure between formatter and dc board.The dc board which i was replaced by old type one.Then i found exact same dc board, replaced. Error was gone.Machine came to normal status , working fine.
Oct 01, 2013 | HP LaserJet 5550dtn Printer
I want to know what the problem 59.CO message on my printer Laserjet colour 5550 and how to get it solved
59.XY PRINTER ERROR
A printer motor error has occurred.
(C)= developing disengaging motor rotation error / (0)= no color/black
Developing disengaging motor error
1. Reconnect the connectors J16 for the developing disengaging motor and J1100 for the DC controller PCB.
2. Replace the developing disengaging drive assembly.
3. Replace the DC controller PCB. Calibrate the printer after replacing the DC controller.
Jul 13, 2011 | HP LaserJet 5550 Printer
We have an HP color laserjet CM6040 MFP that is displaying an unknown error message of 58.04 I have checked the service manual and that code doesn't exist. The event log shows the error as a device...
I am having error code of question mark (?) from Hp CM6040 MFP printer.... How can I olve this problem and what is the course?
I need your urgent respond
Thanks
George Sunday
Tel: +234 806 560 7993
Jul 11, 2011 | Office Equipment & Supplies
HP Color LasrJet 5550 dn Error code 59.30
The error says that the printer has a "fuser motor startup error".
Not a good error to get.
Possibilities are a bad fuser motor, bad DC Controller or fuser drive assembly.
If you haven't already, power cycle the printer.
If the error persists, you are going to have to have a tech look at it.
Feb 28, 2011 | HP LaserJet 5550 Printer
Hp clj 5550 not printing cyan
Check the black cover on the pick up assembly under the cyan cartridge. If it is only a fraction too high cyan will not print. Make sure it is clipped in place correctly.
Jan 20, 2010 | HP LaserJet 5550 Printer
59 C0 error on hp color laserjet 5550
the printer is sensing that one of the motors are not turning.remove the cover from the left side .you will find the main drive motor,next to the motor you will find a sensor clean this sensor with some electronic board cleaner .be sure that the sensor it dry before turning the printer on.
Dec 17, 2009 | HP LaserJet 5550 Printer
I have hp laserjet color printer 5550 getting 59.0 error
ERROR 59.0, 59.1, 59.2
1. A temporary printer main motor error has occurred.
2. Replace the main motor
3. Replace the D.C. controller board.
Jun 14, 2009 | HP LaserJet 5550 Printer
59.C0error on hp color laserjet 5550 dtn
can you please suggest a solution for the above error on my printer urgenty
Apr 10, 2008 | Office Equipment & Supplies
Hp Laserjet 8150 LVPS replacement
It is located in the back of the printer on the bottom. Remove the back cover. With the power off, remove the formatter board by loosening the two big screws and pulling out. Remove the plastic cover by the side of the formatter cage. Remove the fan housing by the power connector by removing the two screws, disconnect the cable and pull straigt out. Now remove the big cable at the top and unwind from the high voltage ps. Remove the white connector in the middle of the low voltage ps. Next trace the white cable wires running from the ps to the dc controller and remove the cable from the dc controller. Now trace the fan cable for the fan in the front of the ps and remove it from the dc controller. Remove all the screws which secure it to the frame and pull straight out. Move the fan in front from the old ps to the new and reverse instructions...
Take off the large metal side cover. Look down at the bottom of the printer. The large box is the LVPS. Remove the screws holding it and follow the wiring up to where it plugs in and pull the connectors off. You'll also have to remove the fan above the LVPS on the top right side of it. You will have to take the fan mounted on the LVPS off and put it on the replacement LVPS as they don't come with fans.
Oct 23, 2007 | HP LaserJet 8150 Printer
HP Color LaserJet 5550hdn Printer Logo
606 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
