Question about EliteGroup 865PE-A7 Motherboard
Motherboard not responding
Hi, ive just recently set up my old 865PE-A and i get no display from my AGP card, ive tryed many different combinations of setup and other agp cards but with the same result. The system seems to be working fine, with all componants spinning and powered...i need help???
  • Tim Orr Dec 11, 2007
    no there is not built in graphics on my board, and ive tryed two diffrent ram chips of different mg and maker, also the computer doesnt make an indcation to me such as a beep to point to the RAM for checking like other motherboards
    Problem Solver:
  • 36 Answers
This could be a RAM problem. try changing your ram. Is there built in graphics on the board of the mother board. You may have to turn this off in the Bios.
Posted on Dec 11, 2007
I have an Intel SE440BX-2 motherboard, celeron 300 A and 192 MB of RAM. My question is which graphic cards are best for my configuration. Since my computer is pretty old its hard to find information...
well you should check for AGP video cards version 1.5 V this is whats is your slot as i saw photos of the model of motherboard you have.
this the different type of AGP slots
as ive mentined the 1.5V seems to fit from the picture i saw below of your motherboard ...the AGP is the brown slot as u might know.
so you will have to find a card that have the characteristic ive mentioned so if u buy a card make sure u ask if that AGP card is Compatible with your 1.5V because if its another AGP socket
it will simply not fit in.
good luck
Oct 20, 2010 | Computers & Internet
Won't post, no beep. No display on monitor. Tried different AGP video card, different memory. I have unplugged everything but the AGP card and hard drive. The monitor works on a different computer so...
Basically, display card, RAM and processor are the ones affecting the display. IF trying different memory and video card doesnot help. Try changing the different processor. Thanx with regards Sajan
Jan 21, 2010 | Abit IC7-MAX3 Motherboard
The specs of my computer is intel pentium 4 2.8c 800mhz processor with 4GB pc3200 ddrram. the video card is hercules radeon 9600 256mb w/ tv-out/dvi/8x agp. i'm using this computer for editing videos from...
Well I'd try a different video card first,even an old piece of **** will do & see if it hangs. If that doesn't work,try a different monitor. If the board were bad it wouldn't work at all. Last possibility is the video card is getting too hot. Make sure the fan is running if it has one & the heatsink is free of excessive dust buil up. Write back if that doesn't solve it. The motherboard should be a lasdt resort. Keep in mind I'm giving you the way to test stuff without the use of high tech equipment that we pros have.
Jul 15, 2009 | MSI 865PE NEO2-PLS Motherboard
Black screen even the power is ok!!
Your Intel D850MV motherboard uses an AGP video card. There is no onboard video (built into the motherboard). Before replacing the video card try swapping out your monitor with another. Check for display. When the system is powered on can you hear the internals running? If the swapped out monitor does not show display you'll have to replace the AGP video card. The Intel D850MV motherboard only supports AGP cards that run at 1.5volts only & can run at 2x or 4x speed. Intel shows the difference between compatible 1.5v AGP card connector & the 3.3v non compatible video card connector. Click on the Intel link to see this; This next link shows a compatible AGP video card that will replace your old card; Thanks for using fixya
Jun 04, 2009 | Intel D850MV Motherboard
ECS 865PE long beeps monitor does not come on
u said the AGP video card doesn't seem to be getting power, right? May be your PSU is quite lower than your computer requires to run perfectly. Pls try to change the PSU and see if the problem gets solved....
Mar 08, 2009 | EliteGroup ECS 865PE-A7 Intel 865PE...
Looking to upgrade video. is there a limit to uprade old mboard
Only cards that work with this board are AGP 4x graphics cards or possiblly AGP 8x cards that are backwards compatible. If you buy an 8x card do your research to make sure it's backwards compatible before purchase. Newer graphics cards are pci-express x16 or pci-e 2. These will not work with your board. Hope this helps & please remember to rate my answer. Thanks.
Jan 10, 2009 | Matsonic MS9327E (MS9327E+(USB))...
AGP installation problems
If you do see the BIOS post but the screen turns black when your OS is loading, then the AGP-card should be OK. HOWEVER, you do need to uninstall your MB-video drivers before installing a new GPU.
Jul 06, 2008 | ASUS K8V-MX Motherboard
System doesn't see AGP card
Hello flaxx
I believe you'll need to find a way to disable your integrated (onboard) video in the BIOS. I know there isn't a direct way to do it but, please, see the next link. The user there found a way.
HERE is the way another user accomplished this task. (disabling onboard video). It concerns a different Asus motherboard but, I checked your motherboard manual, those same features are available.
HERE is the AsusTek forum for your motherboard. You can search and post here. There will be other users of that same board there that I'm sure will be able to help you.
HERE is your motherboard manual. However, I didn't see anything that particularly addressed disabling the onboard video.
Please, post back here w/ your results, questions, and any comments, etc.
Thank you
BJ @:)
Apr 12, 2008 | ASUS P4GE-MX Motherboard
EliteGroup 865PE-A7 Motherboard Logo
101 people viewed this question
Top EliteGroup Computers & Internet Experts
Alun Cox
Jerry Umali
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
