Whining sound during water pumping out and spin
    Champion:
  • 435 Answers
The water pump must be check ,the pump is not working properly
Posted on Sep 10, 2009
Engine makes whining sound
Take the belt off and spin all of the pulleys. the bad component should be obvious. high pitch whine is usually alternator bearing for the 98 3800 its timkin part# 100ccab or it can be the power steering pump(but the pitch will change as your steering if it is that) water pump, idler and tensioner pulleys(if you have to change either one, replace the tensioner itself). if you have the supercharged model there are a few parts that can whine( or the s/c is low on oil.)
Apr 15, 2012 | 1998 Buick Park Avenue
High pitched buzz/whine during wash cycle only, spin fine
1) Make sure valve is open all the way 2) some machines have a screen inside of the hose hook up which could be clogged. 3) last check to see if it is the hot or cold by switch your selector switch on your machine to hot then cold. If one of these positions eliminate the noise then the valve in the machine is bad.
May 16, 2009 | Maytag Atlantis MAV8000
Loud whining sound during the spin cycle? Any ideas
Its possible, something is in the water pump making that noise, if not then its either the gearcase, basket drive/clutch.
Nov 16, 2008 | Maytag MAV9600 Top Load Washer
Washing machine making whining noise during spin only
Yes, bearing, most definitely. It is a cheap part but difficult to replace.
Apr 11, 2008 | Washing Machines
Motor whine w/ agitation & no high speed spin
try undoing the pump assy (just unclipp and move it aside) no need to disconect hoses yet. tyspinning now, if quiet then theres csomethin in the pump, you may get lucky and be able to pull whatever it is out!
Mar 22, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Motor whine during agitation & won't spin at high speed LSQ9200PQ
check to see if the tub has any side to side play to start then pull the motor and check the coupling the clicking is whats confusing
Mar 21, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Washer making noise in spin cycle
Is this unit new? I had a frigidaire that would really get to going on the spin cycle. Got the clothes really dry and sounded like a jet engine if no clothes were in it. Is it a whisling sound or screeching sound...The sound could be coming from the water pump. It may have something in it that is dragging. Some you can take the bottom off of and clean them out..
Feb 10, 2008 | Washing Machines
Whining during spin cycle
zato2
Could be a loose belt, or drum bearings,or ( drum rollers if your model is so equiped) In my mind machine would be worth repair when needed.
hope this is helpful
handiman518
Jan 17, 2008 | Maytag MAH6500 Neptune Front Loading...
Maytag washing machine repair
The water pump may be going bad...Yes it probably is a bearing. Take the belt loose and try turning each pully until you find one that makes noise or is hard to turn. Pump and motor should both spin very easily with out noise.
Nov 27, 2007 | Maytag Atlantis MAV6000 Top Load Washer
Washing Machines Logo
71 people viewed this question
Top Washing Machines Experts
