Question about Hotpoint HSS25GFP Side by Side Refrigerator
Replaced evaporator fan in freezer but not running, what is wrong?
  • 4,066 Answers
    Champion:
  • 435 Answers
You must check out if electricity is flowing in the wire that goes to the fan,
Posted on Sep 10, 2009
Side-by-side refrigerator - freezer is working just fine, but the refrigerator is not cooling.
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Dec 27, 2010 | GE GSL25JFPBS Side by Side Refrigerator
Ice accumilation at bottom of upright freezer
i could be wrong, but, look along the bottom of the door to see if the seal is tight to the frame......if there is an air gap it is causing the floor to freeze the cold air....
Jun 04, 2010 | Woods Upright Freezer MU07W
Frigidaire Gallery refrigerator, evaporator fan not running
As insignificant as it may seem, that evap fan motor is as important as petrol in a car. That fan controls the fridge cooling on many fridges and circulation in tha freezer compartment. Replace it with the correct one and you should see a functional fridge/ freezer again. Note, i wouldnt run unit without it for long, as condensig temperatures run high and compressors dont last long.
May 23, 2010 | Frigidaire PLHS267ZA Side by Side...
Freezer is not cold and evaporator fan (inside
ok well... those pipes coming from your compressor one of them should be hot. if not your compressor is not running.
Nov 10, 2009 | Amana Freezers
REPLACED EVAPORATOR FAN YET I CAN'T FEEL NO
There are two fans in most modern refrigerators; one that circulates the cooled air between the two compartments, another that pulls or blows air over the external coils under the cabinet. You may have bet on the wrong one.
Oct 24, 2009 | Frigidaire FRS26R4A Side by Side...
Freezer not freezing fridge not cold, freezer frosted up
There is one compressor that serves both the freezer and refridgerator compartments. You need to confirm if the evaporator fan in the freezer compartment is working. When you open the door to the freezer, you should see and hear the evaporator fan in the freezer compartment running. Particularly if there is a demand on the unit through the thermostat setting. If the evaporator fan is not operating, you can check the evaporator fan motor with a volt meter to see if it's getting power. If its getting voltage, but not operating, you need to replace the evaporator fan motor in the freezer compartment. There are 3 wires that attach to the evaporator fan motor. One hot wire, one neutral wire and one ground wire. The ground wire is usually marked green, the voltage wire is usually marked black and the common wire is usually marked white. You should get a reading on your volt meter of a voltage from the hot post to the neutral or from the hot to the ground. If it is getting power but will not operate, then it is definitely a bad fan motor that would need to be replaced.
Oct 03, 2009 | Refrigerators
FREEZER WORKS, REFRIGERATOR DOES'T
GE Freezer works but refrigerator doesn't cool
Either the evaporator is froze up due to no defrost or the evaporator fan is not running to blow air into the refrigerator. Do you hear a fan running in the freeezer?
Sep 22, 2009 | Refrigerators
Compressor & Evap. Fan both work for 12 hours then evap stops
I believe that because defrost is done by the mother control board this is why this is happening the part of the board that controls defrost is malfunctioning and the only way to resolve the problem is to replace the mother board part number WR55X10656 You can find the replacement board at these places below. Sea Breeze
http://appliancepartsse.blogspot.com/
Aug 25, 2009 | GE Refrigerators
GE fridge runs continuousely
Simple! The replacement fan ran the wrong way forcing air circulation the wrong way. Fortunately it was possible to reverse the moter shaft.
Dec 11, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Hotpoint HSS25GFP Side by Side Refrigerator Logo
148 people viewed this question
Top Hotpoint Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal DeAngelo
Are you a Hotpoint Refrigerator Expert? Answer questions, earn points and help others
