Question about ASUS P5PE-VM Motherboard
Got a new monitor but need to turn off internal video thats on the motherboard its a p5gd1vm from asus
    Scholar:
  • 118 Answers
Access the BIOS settings (you'll see a message on which key to press to access your BIOS setup when the PC boots up) and you'll be able to access the internal video options.
Posted on Sep 10, 2009
Cmos settings wrong chassis intruded fatal error system halted
Hello download the manual here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5GD1VM/#download
Select first windows xp (i guees)
Click on manual and hit global for download.
Unzip the file before you can read it.
You also need a pdf reader to read content.
Good luck
Dec 01, 2011 | ASUS P5GD1-VM Motherboard
How do i disable the video on board in p4 motherboard
It depends on the BIOS manufacturer but usually you need to enter in to the BIOS settings to change the video settings.
Oct 28, 2011 | ASUS P5GL-MX Motherboard
I have a ASUS P5GL-MX motherboard. When I turn on the computer I see nothing on the monitor. I had the opportunity to get my keyboard, mouse, monitor and even the memory checked out to make sure they are...
The operation of the onboard video is programmed into the board, so it should work without any drivers being needed. If you verified that the monitor is working then I'd say the onboard video had gone bad. Your motherboard has a PCIe x 16 slot so you can get around the problem by adding an aftermarket video card. The cheapest of them have quality that surpasses any onboard video and they can be found almost anywhere. Follow this link to see some suggestions.
http://www.tigerdirect.com/applications/Category/guidedSearch.asp?CatId=28&sel=Detail;55_158_13067_13067
Oct 17, 2010 | ASUS P5GL-MX Motherboard
Dear master, i haved asus P5VD1-X motherboard problems, its no beep bios and no display but cpu fan normal, green light at motherboard its normal too, i haved try to clean RAM, clean VGA card, reconect...
Every Asus motherboard comes with a seperate four pin two wire ( internal speaker). Either you're speaker is not connected properly or the speaker may be bad.
Check manual page 2-28, PANEL. Asus makes these connections easy by provideding a jumper-block as shown below;
c355ca7.jpg The jumper block is clearly marked.
You also mentioned a removal of the CPU. I only hope you cleaned the old thermal grease from the CPU and heatsink assembly with alcohol and replaced with new thermal past. The P5VD1-X comes with a built in AGP card. Settings are configured within the bios menu. I understand you are unable to receive a single to display to the monitor. Connect the monitor to the rear VGA port. When you replaced the bios battery the bios reset its self to default settings. This means the intergrated AGP video is most likely being used by the bios. Remove any added video cards. If you can't receive video to the monitor I would suggest you contact Asus.
For more information call Asus Tech at:
1-812-282-2787. Eastern time. M-F 8:00AM to 5:00PM.
http://usa.asus.com/product.aspx?P_ID=SkuBYErUHJtQw76w&content=specifications
Mike
Jun 02, 2010 | ASUS P5VD1-X (90MBL3C0G0EAYZ) Motherboard
Monitor connection
Hi:
You need to install a Graphics card , because this board does not have on board video!
Apr 29, 2010 | ASUS P5PE-VM Motherboard
Nothing shows up in the monitor even the cpu on
Install a new graphics card and plug your monitor into that new video card. Do u get video output? If not, the problem is the system board.If u do, the problem was the graphics card.
Mar 15, 2010 | ASUS P4S533-MX Motherboard
My monitor does not turn on when power is turned on. the monitor stays black. my mother board is an asus A7V8X-LA
Hi...
When we say monitor doesn't turn on you need to check the power cable if it is correctly plug in, Check the monitor cord if it is plug in directly to your motherboard port. Some motherboard have installed external video card once you have install an video card you can plug your monitor cord to the video card.
When the problem is still occur you need to disassemble the unit. The processor have problem it doesn't display. Remove it and clean after that put a thermal paste so that the heat from CPU will absorbed by the heatsink.
Regards
PCmania
Sep 25, 2009 | Computers & Internet
I got a problem with installing a pciex16 video card... i installed the card set the PCIE in the bios and nothing happens, when i unplug the video kaart the system starts up with the onboard even when i...
The system recognizes both. You can do either of these two:
1. Disable the internal video card via the BIOS. It will start using the add-on.
=== or ===
2. Right-click on your desktop and select [Properties] [Settings]
You will see two monitors #1 & #2.
Click [Identify] so that you know which is which.
Click on the monitor attached to the new video adapter and "checkmark" the box [Extend my Windows desktop onto this monitor]
At this point, don't select [Use this device as the primary monitor] until the above steps are successful in accessing the new monitor.
Hope this helps!
Sep 18, 2009 | ASUS P5VD2-VM SE/BULK Motherboard
Monitor will not find new motherboard
the monitor is not the one looks for motherboard or drivers the monitor drivers is on the motherboard so if you installed new motherboard and your monitor drivers are not set or missing so you nave to download the drivers the one is going to work with your monitor and they are video drivers if you don't have the cd drivers for asus you can get them on http://www.asus.com or http://www.driversguide.com
Dec 31, 2007 | Computers & Internet
MicroATX motherboard work but the monitor shows a black screen.
I assume the monitor is turned on? Try the monitor with a known good computer to verify it's OK. I believe this board has AGP video. Verify that it's properly seated, or try another board.
Sep 13, 2007 | AMD Asus A7V-ML Socket A MicroATX...
ASUS P5PE-VM Motherboard Logo
42 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
