Question about Pioneer DEH-1500 CD Player
I want to connect my ipod to the aux inputs on back of unit
On the back of the unit there are right and left channel rca inputs. I connected the ipod and when the radio antenna was not plugged in, I could get connected, but when I plugged the radio antenna back in, the ipod music would only come through one of the radio channels and then it was along with the regular radio programming. How do you select the correct input?
Thanks, Greg
  • 655 Answers
Hello gcd_sun,
The RCA jacks on the back of the Pioneer DEH-1500 are preamp outputs, not inputs. They are to connect an external amplifier for additional speakers or subwoofers.
The output from your iPod is probably "bleeding over" into the receiver detector stage. When the antenna is disconnected, the signal passes into the amp by itself. Connecting the antenna provides enough signal so that both are amplified.
To connect the iPod, you need to purchase a wireless iPod adapter, or a new head unit that includes an "AUX" input or a dedicated adapter for the iPod.
Hope this helps.
Posted on Sep 11, 2009
  • Sam Tim Mar 30, 2014
    Why does the unit have an aux channel then?
How to connect an MP3 Player to NAD C320?
You will need a cable with headphone jack (for mp3) and RCA left/right to connect to your NAD 320. You can connect to CD or AUX in the back and then you will need to change the input with remote or with on board buttons to CD or AUX depending where you plugged it.
Jun 20, 2012 | NAD C320 2-Channel Amplifier
I need to connect an ipod to the Aux of the electron master unit, Can it be done , and if so what connections on the rear of unit do i use.
You should just have an aux input. Depending on what that connector is ( RCA? Qtr inch? Screw terminals? ) will decide what cable because it will be 1/8th output of iPod ( headphone jack ) to the aux in. If it's the screw on terminals you can take a headphone cable and cut and strip 1 end off Tip is Left Ring is Right and sleeve is ground. Or you mat need eigth inch to dual RCA (most likely this is the case).
Aug 26, 2011 | Audio Players & Recorders
I have a BOSS BV9970 stereo. the usb will not let me play my ipod, it starts to load it but stops halfway through. and when i try to use the aux, my right rear and right front speakers will not play.
sounds like a loose connection on the aux input. boss has a pretty bad reputation for there usb / aux connections inside the unit. also if your right rear and right dont play on anything its bc you have them turned down. or if this is recently installed they got mixed up. please let me know more details so i can better help you
Mar 20, 2011 | BOSS AUDIO SYSTEMS BV9970 Car Video Player
How do i hook up mt ipod
To hook up your ipod to an a/v reciever you need a stereo mini to male rca cable. You plug the mini side into you ipods head phone jack, and the male rca's left and right(usually red and white colored plugs) to an auxilary input on the a/v reciever.-Example, tape, aux, sa/cd.
Change the input on the reciever to correspond with where you connected the ipod
Ensure the ipod is powered on and playing with the volume turned up.
Jan 04, 2011 | Audio Players & Recorders
Having trouble connecting a ipod to the back of the reciever with rca cables. I plugged in to the V-AUX and also put the input to AUX on the reciever. still no sound
I think the V-AUX is a video input, not audio. Look for a red and a white RCA female input to connect the cable. Those represent the right and left, respectively, audio.
Dec 31, 2010 | Yamaha HTR-5830 Receiver
Panasonic SA-AK630 can i plug a ipod into it some how ?
for these stereo you have a AUX IN on the back (L and R RCA sockets)
from your manual follow these steps.
1. Press [AUX].
The unit comes on.
2. For listening: Proceed to step 3.
For recording: Press [a, REC] (recording starts).
3. Start playback from the external source. (For details, refer to the
external unit’s instruction manual.)
External unit connections
An analog player with a built-in phono equalizer can be connected.
For details, refer to the instruction manual of the units which are to
be connected.
When units other than those described above are to be connected,
please consult your audio dealer.
Rear panel of
this unit
(R) (L)
R L
then you need a ipod audio cable, available on mac store, but these cabble has 3,5 mm jack connector, need a adapter 3,5mm stereo jack to rca Connectors, and these is available on electronics stores, or professional audio store
try these and post
Jan 29, 2010 | Panasonic SC-AK630 CD Shelf System
I have a audio/video multi-channel receiver VSX-D810S digital processor, probably about 7 years old. How do I hook up my ipod to play music out speakers in my home, same as cd's?
Check Radio Shack, thay make an adaptor with a white and red audio plug that can connect to an input on the receiver (AUX) the other end goes into the headphone jack on the iPOD.
Aug 17, 2009 | Pioneer Audio Players & Recorders
Whinning noise when car is on and AUX is connected to ipod
ENGINE NOISE PLUG ALL YOUR RCA DIRECT TO AMP BYPASS EQ AND SEE WHAT HAPPEN IF THIS STILL HAPPEN CHECK ALL YOUR GROUND AND RCA MAKE SURE YOU HAVE GOOD CONNECTION
Mar 30, 2009 | Boss AVA-1215 5-Band Car Equalizer
IPOD ADAPTOR
you have to buy the ipod connection kit to pioneer, but if your deck have RCA input at the back..all you need is Y cable 2 (RCA male - 35mm jack)
RCA will be connected to DECK, 35 mm jack to your ipod.
to use your ipod...change the input setting on your deck to AUX (auxillary) most deck have this for CD Changer connection
Good Luck
Mar 13, 2009 | Pioneer DEH-P6700MP CD Player
Auxilary RCA inputs have no volume control
Your problem stems from the fact that the CDA-7892 is not equipped with an RCA aux-input jack. If you're plugged into RCA connectors at the back of the head unit, they're outputs, not inputs. The sound you hear is just feeding back through the outputs and into the head unit's amplifier. If you want to play your iPod through this head unit, you need to purchase either the auxiliary input adapter (KCA-121B) or iPod adapter (KCA-420i).
Mar 15, 2007 | Alpine CDA-7892 CD Player
Pioneer DEH-1500 CD Player Logo
1,640 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
