Question about Xerox Document Centre 420 DC Laser Printer
Xerox 420 DC won't power up
Copier is getting no power
How to adjust the paper registation timing during coping
Posted on Dec 12, 2009
  • 239 Answers
If the machine does not power up it is somewhere in the low voltage area, possibly a Low Voltage power supply.
the machine does have a ciruit breaker on the back, check it and make sure it is on.
the power switch also is not only a switch, but also a circuit breaker built inside the switch. It would take a trained person to diagnose this area, due to high voltages in these areas.
Also, if the machine does not start, then there can be a ciruit board or even a electric compontent that can be causing the low voltage board to power down, or even cause damage to it.
If all else fails, place a service call with Xerox. It is safer to have a trained person check this critical area.
Posted on Nov 03, 2009
    Scholar:
  • 118 Answers
Make sure the circuit breaker on the back (near the power cord connection) isn't tripped. If it is, toggle it to a fully off position, then back to on. If it keeps tripping, try moving the unit to a different wall jack and repeating the process.
Also, do not have this unit plugged into a surge suppressor. Xerox copiers have built-in surge suppressors. Adding another external surge suppressor to the circuit can cause the unit to malfunction.
Posted on Sep 10, 2009
2 Suggested Answers
  • 2072 Answers
SOURCE: xerox 420 dc ports?
If it's a DC that means Digital Copier, It does not have print capabilities. That would be the ST versioin.
A 420 DC is simply a copier. It can however be upgraded to an ST.
Posted on Jan 05, 2009
1) I have XEROX Document Centre 425DC, when ever I take a copy I find black lines on the print , Even on the blank paper 2) When I bought this machine I was told that this machine can be connected to the...
First of all clean the platten glass, also the narrow glass to the left of the platten glass. If the lines are still there after doing a copy,open the upper left cover and look at the fuser heat roller,the lines could be from a toner contaminated heat roller,this can be cleaned with a minerised scowering pad.with the copier switched on press the Key button then # 1 1,touch Enter on the touch screen.touch HSFI tab,scoll down to copies on cru and enter, if the count is above 20,000 the fault could be the cru ( copy cartridge) needs replacing as it is not cleaning the drum.
There is not a USB port on the 425 dc. If the copier has a ESS on top of the engine ( you should see a floppy disk drive slot on the front of the copier) it means it has been converted to a 425 ST, if not it will cost a to much to convert. A xerox 425 ST will connect to a computer. Xerox ST copiers means Networked
Jan 15, 2011 | Xerox Document Centre 420 DC Laser Printer
What usb cable do i need to conect my xerox 425dc to my computer
425DC is a Digital Copier and it cannot be connected to PC, it only can copy, but can't print.
Nov 15, 2010 | Xerox Document Centre 420 DC Laser Printer
Trashing xerox 420dc due to main failure. I've heard there is a hard drive or memory card that I should remove. Is there and where?
Hi Scunning84, I don't have the solution but I too am trying to figure out where the hard drive is in this copier? Were you successful in locating it? Thanks for any help you can offer. Carrie
Nov 04, 2010 | Xerox Document Centre 420 DC Laser Printer
I have a Xerox Copier Document Centre 350 it has a fuser error U4-1 How do I reset fuser as the copier will not work as it says call technician
I would truly call in for service. Copiers require a trained tech to replace the fuser. Trust me I work in the IT industry. Have a trained tech fix it.
Nov 23, 2009 | Xerox Document Centre 420 DC Laser Printer
Xerox DC 3535 error 116-332
Simultaneously press and hold the 1,the Stop
and the Power Save buttons on the Control
Panel,if problem continues repeat the same
with
6,the Stop and the Power Save buttons
4,the Stop and the Power Save buttons
3,the Stop and the Power Save buttons
Aug 28, 2009 | Xerox DocuColor 3535 Copier
Scan failure
Anything with scanning problems on this machine, would require a service call.
Turning off and wait for at least 30 seconds and powering on the machine "Might" get the machine back to a good "Ready" condition.
The problem might be a bad scanner motor gear or even curciut board. There might even be some major binding that might knocked out some sensor, giving this condition.
Most times, a service call needs to be placed with Xerox.
Mar 13, 2009 | Xerox Document Centre 420 DC Laser Printer
Xerox 420 dc ports?
Jan 05, 2009 | Xerox Document Centre 420 DC Laser Printer
How to do 'mirror' on photocopier
Hi, I made a mistake, sorry. It is not a 423 Greyscale etc.. that I own but a Xerox Workcentre pro 420 black and white photocopier. I have but no manual to find out how or if it has a 'mirror' or 'inverse' function. Thanks
Dec 14, 2008 | Xerox WorkCentre Pro 423 Copier
For xerox work center 420
If you are using oem products than send it back they are reset with a chip within the drum unit
Sep 24, 2008 | Office Equipment & Supplies
Open Questions:
Dear Sir, I am very happy if you could talk to From Rector Divine Union Seminary Ayyappankavu P.O . 680 751 Mulayam Trichur 0487 2315166 To Manager Customer Care Xerox India Ltd 20th Floor DLF Square Jarcada Marg M-Block Gurgaon ? 122 002 Email: Digital.solutions@xerox.com Respected Sir, I am writing this letter to bring to your kind notice and attention a serious problem concerning the Xerox 0420 photocopier. We had purchased the machine on 06-12-2007 from your noble institution paying a huge amount of money. It is very sad to say that it is the second time that the copier is not working well and needless to say that there was no necessity of replacing the drum cartridge either. That is to say that we have not taken even 12,000 copies. Within this time we had to replace once HVPS which costs nearly 27,000/- rupees. We replaced it on 11-10-2008.Again we are confronted with the same problem. The machine is not working well again due to the dysfunction of HVPS. It is also very sad that this part cannot be repaired. When we use the copier the copies are not clear and show ?U9? code. And the service personnel from the Trichur Computer Clinic is asking us to replace the HVPS. We had purchased the machine through ?Trichur Computer Clinic? (TCC). And we were not given even 1 year warranty instead they gave us only 3 months; though the warranty card shows one full year of the purchase. Dear Sir, it is impossible for us to pay you another 27,000/- to purchase a new HVPS. To do so it seems like putting one?s own foot into the hole of a snake. We feel thoroughly cheated by you and our trust and confidence in the company is shaken. We hear similar complaints from many buyers and even from the service engineers. It is at their advice that we are writing this letter. We would like to hear from you soon .I hope you will be kind enough to take up this matter as an urgent case and do the needful as early as possible. If we don?t hear from you we will be forced to take up the matter to the consumer court . Yours Sincerely, Rector Fr. Antony Pittappillil sdv Email:pittappilly@gmail.com
Dec 15, 2009 | Xerox Document Centre 420 DC Laser Printer
Xerox Document Centre 420 DC Laser Printer Logo
256 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
