Question about Smeg DWI614 Built-in Dishwasher
E6 I have been getting E6 error message over and over again. I have had the machine to pieces, cleaned out the pump and hoses, and still the same problem. Occasionally, the error message changes to E8 or E1, but no matter what, I can't get it to work. Any ideas? When I start the machine, select any program and close the door after a short while the machine does not complete the wash cycle and I get the following message either: E1 or E2 will appear in the control panel Any suggestions Dave M
  • Anonymous Dec 14, 2007
    bizarrely we have just started having the same problem - long beep and E next to the programme number
  • bluenose66 Dec 22, 2007
    Select program P4, close door and you can hear the dishwasher start but can't hear any water spraying inside the machine. There is a highpitched beep and E6 displayed on panel. Opened the dishwasher and the crocks are still dry, no soaking as per the norm.
I had this problem and fixed it tonight. When selecting a program water pumps into the machine, but with no drain i ended up with too much water and error code E6.
I traced the fault to a broken wire between the electronic module in the door and the pump. The point at which the door opens and closes on the cables had frayed the insulation and broken through the wire. As this was the live feed to the pump and a potential short from 240VAC to the chassis its dangerous!!
Repairing the wire break and re-insulating fixed the problem.
Lee
Posted on Aug 11, 2008
What do we do after replacing the pump on an LG frontload washing machin, yet still get error message OE?
Assuming you cleaned the pump strainer?
Likely the drain hose leading from the pump to the drain, the section
inside the cabinet that "u-turns" back down is plugged up with
junk.. I had to remove the hose from the machine and force water
thru it at a outside faucet to clear what looked like a turd from the
inside of the drain hose..My shop vac could not dislodge it..
Aug 16, 2014 | LG Washing Machines
I get code e06 on a samsung p1005j Ken
Hi there
Here are all the error codes and what you should do:
General Error Codes
E1: Water Supply Error
-Display Shows 'E1'
-Water Supply Error occurs when water level frequency does not show changes more than 100Hz or water is not supplied up to the water level presetting for 20 minutes or more at the time of initial water supply.
-To help fix this problem please check the Hot and Cold water intakes, there is a filter screen in each input valve, remove and clean these filters. ** Make sure you replace the filters, they are very important for the operation of the Washing Machine.**
-The error status can be cleared by turning POWER S/W OFF and resuming the POWER ON initial status.
E2: Water Drain Error
- Display shows E2
- In case the water level frequency is 25.5Hz or less in the initial phase of UNB-detecting cycle.
- Water Drain error can be cleared by turning POWER S/W OFF and resuming the POWER ON status.
E3: Over-Flow Error
- Display shows E3
- Over-Flow error occurs when the water level is too high. It can be cleared by turning POWER S/W OFF, turn POWER S/W ON and then run the drain cycle for 2 minutes. Water is drained prior to POWER S/W OFF and it is forced to be drained for 2 min if a frequency of more than 25.24 KHz is detected
Door Open Error:
- Display shows door
- This can fixed by closing the door
E4: Unbalance Error
- Display shows E4
- Laundry load is unbalanced; loosen any tangled laundry.
- If only one item of clothing needs washing, the final spin result might be unsatisfactory and an E4 error message will be shown in the display window.
- Unbalanced error is cleared by POWER S/W OFF and by resuming the POWER ON initial status
E6: Please see "Eb" at end of list.
E7: Pressure S/W Error
- Display shows E7
E9: Water Leakage Error
EA: Tacho Error
- Display shows EA
- This is error can be cleared by turning the power off and then on again.
Eb: Motor Triac Short Error
- Display shows Eb
E6-EB can only be corrected through Service. Please contact Customer Service Department at 1-800-SAMSUNG (option 1-1-2) to schedule an on-site service call for english service.
Thank you for using FixYa. Have a nice day and please remember to rate this solution as 356ebb3.png if it helps you.
Kind regards
Dustin Ellse
Jul 03, 2008 | Samsung Washing Machines
How do you clean brother SQ9050
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide this is important for the tension
try using a different bobbin
clean under the needle plate and in the bobbin area for lint
also possible that the machine may need some type of adjustment
or the machine could be starting to have a timing problem
Dec 08, 2012 | Brother Sewing Machines
What does error message E6 mean on a prompt set spa #jl017108?
I am having the same problem, not E4 but E6 error code and have to keep resetting it and about 15 min later it start beeping the error code again? Please help
May 21, 2012 | Pool & Spa
My washer stopped mid cycle and wouldnt drain or spin or anything. The error message is "nd". Can I fix it myself? thanks
Hi
ND=-no drain error.
Remove the back panel you will see the pump. Simply remove the pump and remove the obstruction that is keeping it from draining. Check for thongs, baby socks and sometimes hair pins or even screws can obstruct the water pump. There's going to be some water left in the pump and drain hose, so get a large towel ready. Remove screws attaching black piece (motor) to white piece (housing), pull out motor and clean the housing and motor impeller. Reverse steps to assemble it back together. If you don't hear pump running after completing the cleaning, you may need to check the wiring and/or replace main control board located inside the console. If the pump seems to be running but no water is being drained - replace pump.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Aug 06, 2011 | Maytag MAH2400A Front Load Washer
Error 21 was on washer, we cleaned out drain then started washer it appeared to be working, but then error message 21 came on again. It is very late so tomorrow morning we will open drain again.
Hello, it can only be dirty filtersomething in the pump drain line blocked up or failed pump. I would check the filter again and if its clean put the drain hose in a bucket see if it drains but chances are you will need a new drain pump. hope this helps please rate my answer thanks
Jun 08, 2011 | Whirlpool Duet GHW9150P Front Load Washer
I have a drain error
this basicly means you have something either caught in your drain or in your pump first thing to do would be to clean out through the clean out trap small door on lower part of the machine if after you clean this out and put the pump knob back in place and you still have the error then you would have something caught in one of the lines that go froom the pump which is a headache because you have to take the whole front of the machine off and disconnect each hose from the pump and the drain line and find out what is blocking but start with the pump and message me back if you are unable to clean out the pump please call a technicain if you have any further questions please message me back and please remember to rank how this opinion has helped in your appliance situation Thanks again
Rick
Dec 12, 2010 | LG WM-2277HW Front Load Washer
Error 15 on a Hotpoint WM72 Washing Machine
The problem is your pump or filter is blocked,
Remove rear cover of washer, and remove large black hose from tub, remove and clean filter inside hose, check for a blockage in pump, refit filter and hose, and it should now be o/k.
Please rate my solution.
Thanks.
Jan 28, 2009 | Hotpoint Ultima WF860 Front Load Washer
Error message on washing machine E20
E20 is "A problem with water draining"
Solutions:
The drain hose may be squashed or kinked
the drain pump may be blocked
or possible your filter is totally blocked. Clean out the filter everything will work again. Put a large bowl under the filter as you unscrew it; a fair amount of water could be there.
Good luck.Please rate the solution if accepted, also do post comments in case of any doubts.
Jan 23, 2009 | Zanussi Washing Machines
Will not drain and shows E6 error code
I had this problem and eventually found a small piece of mussel shell in the bottom part of the machine, it seems they are very sensitive to the tiniest fragment of debris.
Sep 24, 2006 | Smeg 24 in. DWF614SS Stainless Steel...
Smeg DWI614 Built-in Dishwasher Logo
1,506 people viewed this question
Top Smeg Dishwashers Experts
Starnley Johnwells
Starnley Johnwells
Marvin
Marvin
Are you a Smeg Dishwasher Expert? Answer questions, earn points and help others
