Question about Sony VAIO PCG-K23 Notebook
My laptop is a Sony Vaio PCG-6Q2M with Power and Battery Problems
Over time I noticed that the battery was not charging properly and the battery indicator always flashes. I checked the power adapter and it gives out a healthy 19.5 volts. So I bought a new original 5200mAH battery and it has made no difference. It did charge once, but when I switch the laptop on the battery level gradually diminishes - even though plugged into the adapter. If I remove the battery the laptop goes dead and will not start on the power adapter. Now the laptop simply won't start at all. Both the power and battery lights flash once, then it goes dead. Help!
  • 674 Answers
Fix first the power adapter/ it not charging some problem of your power adpater,, check the charger if it is working properly or not, then follow by dc connector should know that your dc connector has no deffect// if its okay check the motherbaord of your pc maybe som chips need to replace or damage...ic capacitor fause..ech..
Posted on Sep 11, 2009
I need a driver for camera for sony vaio pcg-6q2m i cant find
happy to help but the real sure shot way to get the drivers are from the manufacturer . all u need to do is go to the website and click support and in case the drivers u r looking for are not available . u could get in touch with them or use website life www.soft32.com u will find the drivers there.
Nov 30, 2014 | Sony VAIO Computers & Internet
Sony pcg-81114L power supply not detected
If thelaptop battery is more than 3 - 4 years old then the battery could be worn out.Rechargeable batteries have a finite number of charge and discharge cycles andwill lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up at all. OR Thebattery shows a 100% charge but when the adapter is disconnected the batterydrops off to zero capacity in a very short time. If the battery drops to anunacceptable charge level then the battery needs to be replaced.
Aug 04, 2012 | Sony VAIO PCG-K33 Notebook
HI IAM USING SONY VAIO LAPTOP VGN SERIES NR11Z/T WITH MODEL NO.PCG-7Z1M. MY LAPTOP DOESNT USE THE BATTERY WHEN I CAHRGE. PLEASE HELP ME. IAM FACING TROUBLE AS I WILL HAVE TO ALWAYS CONECT TO POWER IF I...
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Mar 12, 2011 | Sony Vaio PCG 7Z1M Laptop Universal AC...
HI my battery doesn't charge anymore. I'm not sure
battery is out....
change battery...the battery wears out with frequent charge and discharge...it has a running live of some 15000 to 20000 hrs
Dec 14, 2009 | Sony VAIO PCG-V505EC Notebook
Hello, SONy Pcg-FRV37,Power problems
Clean the metal contacts on the Battery and in the compartment. Then, reset the BIOS to its default settings.
Next, plug in the AC Adaptor to charge the Battery.
If the issue persists then the problem may be related to the power circuitry.
Oct 16, 2009 | Sony VAIO FRV37 Notebook
The best advice would be to update the BIOS and then go to the BIOS utility and restore the settings back to default. This might resolve the issue if it is software related. If not then visit the manufacturer's website and download the latest chipset drivers. Restart.
Try using a different power adapter of the same kind and check for the issue.
Turn off system and remove the power cable and battery and press the power button for about 30 seconds to power drain the system.
Turn on and check.
If not the main board itself is the issue for which I would request you to contact the manufacturer.
Sep 10, 2009 | Computers & Internet
Charging problem
If your computer runs correctly on AC power (without the battery), the power adapter is fine. So the problem may rest with your battery. If you have been using the same battery for 3-4 years, I suspect that it may not be holding the charge (end of life)
Try charging you battery and run the computer on battery alone and see how long it lasts.
Hope it helps
Sep 07, 2009 | Sony VAIO PCG-K35 Notebook
Sony VAIO PCG-K23 Notebook Logo
864 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
