Question about Smith Corona Wordsmith 200 Typewriter
I was typing and the letters became fuzzy and there is a line by each letter now.
    Champion:
  • 204 Answers
The printwheel may not snapped in properly and going to it's home position. . Keep trying..it will spin to its home position when installed properly, providing its not broken or bent.
Squipps
Posted on Oct 08, 2009
The nakajima ae610 types two vertical lines instead of letters
The print hammer is striking between the letters. Two thing
you may have a petal, letter broken off. If its the same letter every time usually thats it, need new daisy wheel.
Or Homing is off when the wheel turns hammer hits between letters. Needs repair.
Or
Daisy wheel petals are bent.
Dec 12, 2016 | Nakajima Office Equipment & Supplies
Olympia Startype 3 occasionally types double vertical line and spacing is changing between letters
Check the printwheel for any broken or bent spokes. vertical lines means the wheel is between letters so either a problem with printwheel or something preventing wheel from turning normally.
Sep 15, 2014 | Olympia Startype 3 Typewriter
Typewriter spaces the letters wrong and types the wrong letters
how to install and set the daisy wheel correctly onto the typewriter
May 22, 2013 | Brother GX-6750 Typewriter
How to write letter verifing address
Instructions
    • 1Before you begin, set your marginicon1.png 1 inch from the top, 1 inch from the bottom, and 1.25 inches on both sides.
    • 2If you're using letterhead, there's no need to type in your name and address. If you're using plain white paper, type in your name, address and phone number (phone number is optional), centering the text. Make the font in this portion of the letter slightly larger than the rest of the text. You should also type your name, address and phone number in boldicon1.png type.
    • Sponsored Links
    • 3About four lines down from your name and address, type the date in full after strikingicon1.png the "Tab" key seven times to bring you a little further than the middle of the page. The date should be typed in full like this:
      February 1, 2009.
    • 4Four or five lines down from the date, at the left hand margin, type the name and address of the person you're sending the letter to. This portion of the letter is called the inside address. If the person you're addressing the letter to has a title, type his or her name first, then type in a comma, space once and type in the title, such as:
      Jamie L. Mulligan, Manager
    • 5Two lines down from the inside address, strike the "Tab" key seven times and type in the subject line. The subject line tells the recipient what the letter is about. In this case, it should look like this:
      Re: Verification of address
    • 6Two lines down from the subject line, type in the salutation. The salutation could be Dear Sir, Dear Ms. Mulligan, Gentlemen, or To Whom It May Concern (if you don't know the name of the contact person). The salutation should look like this:
      Dear Ms. Mulligan:
    • 7Two lines down from the salutation start the body of your letter five spaces in from left margin. The body of your letter should start out saying something such as:
      I am writing you this letter to verify that 101 Washington Street, Lynbrook, New York 11593 is the address I should ship your order to.
    • 8Two lines down from the body of your letter, after striking the "Tab" key seven times, type in a complimentary closing such as:
      Very truly yours, or
      Sincerely
    • 9Four lines down from the complimentary closing and in line with the complimentary closing, type your full name in, like this:
      Jamie L. Mulligan
    • 10Sign your name in the space between the complimentary closing and your typed name.
Read more: How to Write an Address Verification Letter ' eHow.com http://www.ehow.com/how_4745362_write-address-verification-letter.html#ixzz2DRXhelUj
Nov 27, 2012 | Computers & Internet
Windows could not finish to format my removable disk
Sometimes this is a faulty flash drive (Assuming that is what you are talking about)
In XP
Try to format it from the command line. Go to START - RUN - and type in the letters CMD in the box and hit ENTER. From there type in FORMAT and type in the drive letter of your removable disk.
In vista/7
click on the START ORB. type in the letters CMD. At the top of this menu a "command prompt" icon shows up. RIGHT CLICK on the icon and left click "RUN AS ADMINISTRATOR".
From there type in FORMAT and the drive letter of your removable disk.
Jul 20, 2011 | Computers & Internet
Hi i have a problem with my key board.. if i press number 3 it shows instead 3 only it became 23 and same to letter e becames we,letter d becames sd ansd letter c became xc..please i need your help to...
This should be leakage in the keyboard touching sensors. Cleaning inside the keyboard may resolve this issue, otherwise you need to replace the keyboard.
Mar 11, 2011 | Computers & Internet
The letters scramble after a few lines. I mean if
It sounds like something is interfering with the printwheel. Remove the P/W, rotate it and look for bent or broken spokes, Be sure the correction tape is a non tacky type sticky ones will give you fits.
DickyO
Jan 04, 2010 | Brother GX-6750 Typewriter
Smith Corona Wordsmith 200 Typewriter Logo
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Hjalmer Lamminen
Hjalmer Lamminen
Jim Goldsmith
Jim Goldsmith
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
