Question about Amana Easy Reach Plus ABL2227FES Stainless Steel Bottom Freezer Refrigerator
Amana abl2227fes freezer works but the refrigerator does not
My freezer works but the refrigerator does not work. The digital panel with the control setting is on and turning it to a colder setting does nothing. Tried unplugging it for 5 minutes and plugging it back in did nothing.
Any help would be appreciated!
Jon
  • 4,070 Answers
If the board is not opening and closing the damper from the freezer to allow air flow, the board will need to be replaced. If the control does make any of the damper parts move then it would be a mechanical problem with the damper conrtol linkages.
Posted on Sep 10, 2009
My Amana refridgerator does not cool but the freeer works.
This is one of the first signs that the refrigerator is missing defrost. Open freezer door and look at the back wall of your freezer. When a refrigerator does not defrost you will see a frost layer covering the rear panel back or bottom panel of your freezer. Below is a small photo of a refrigerator freezer that has not been defrosting. For a larger photo click=> HERE Thanks, Sea Breeze
Your BX50RE is sold in the UK? Think you may have one of three problems causing this and number one is the defrost heater two is the defrost control and last the defrost thermostat.9_7_2012_10_48_56_am.jpgClick to enlarge
By the way you will not see this in freezer because the rear panel covers this, but there should be a layer building on the outside of that panel.
Sep 07, 2012 | Amana Refrigerators
I have an amana bottom freezer/refrigerator model ABB2522FEQ. the bottom freezer works great, but the coils have frozen two times. I thawed coils out again and it only lasted 2 weeks, eventhough the fan...
HI,IF THE FREEZER IS BUILDING ICE ON EVAP COVER THAT IS NOT DEFROSTING PROPERLY,REPLACED THE CONTROL BOARD AND DEFROST B-METAL TO REPAIRD THE PROBLEM..
Jul 04, 2011 | Amana ABB2524DE Bottom Freezer...
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Is it Ok to lay a refrigerator on it's side for a short time (less than 30 min.) while moving.
Yes, you can, but allow a couple hours in the upright position before turning it back on.
Aug 15, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
Our produce are spoiling within 2 to 3 days. Do
First I need you to unplug the refrigerator. Remove the rear panel in the back of the freezer and tell me if the coils are clear, frozen or blocked with ice. Make sure both fans were working before unplugging. Below the bottom and the fan inside the freezer. This will let me know if there is a problem with your defrost system. If frozen over use a hair dryer to defrost coils and let me know. We will need to check the defrost heater and defrost thermostat. Let me know when you are ready or if this is helpful, Thanks Sea Breeze
Jul 14, 2009 | Amana Easy Reach Plus ABL2227FES Stainless...
I have an Amana Side by Side. The freezer section
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air
check defrost heater, defrost thermostat. If the heater and thermostat are ok it’ll be the adaptive defrost control.Part 13 on this diagram of your fridge controls. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=ASD2625KES&productCategoryId=0165000&brandId=1268&modelName=AMANA-REFRIGERATOR&diagramPageId=00005&componentDescription=CONTROLS&documentId=M0612301&backToLink=Return%20to%20Sub%20Components%20list
Is the evaporator fan in the freezer running.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
Jul 13, 2009 | Amana ASD2625KE Side by Side Refrigerator
Bottom freezer not working
Check for frost build up behind back panel. Defrost system consist of defrost timer or adaptive control board, defrost heater, defrost thermostat. check them here
Jan 23, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
Amana BX22A2W - freezer works, fridge not cooling
Same problem here with an Amana refrigerator with the freezer on the bottom. I removed the back panels and vacuumed dust and cat hair out. The back panel in the freezer was frosted over with ice on the bottom. I removed the shelves and food and used a hairdryer to loosen the panel. The ice maker made it harder to remove the plastic panel so I pulled it back and saw the cooling fins frozen solid. I used the hairdryer to melt the ice and a shop vacuum to collect the water. It works like new again.
Dec 02, 2007 | Refrigerators
Amana Easy Reach Plus ABL2227FES Stainless Steel Bottom Freezer Refrigerator Logo
208 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
