SOURCE: Can't use the fax on my Canon MP 530
There are 2 ports on the rear, 1 for the incomming phone line, and one to plug in a telephone handset (passthrough) if the telephone line is plugged into the wrong port, the fax machine is unable to dial properly, So try plugging into the other port on the back, it's just next to the other port hope this helps
SOURCE: can't send or receive faxes on my Canon MF 6550
Is there a DSL filter connect to the phone line that you are faxing from?
SOURCE: I can't send faxes on my Canon Pixma MP530 on digital phone line
They're telling you your hardward doesn't play nice with their hardware. A few suggestions:
Update your printer, and see if any improvement is found:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=13371#DownloadDetailAct
If that doesn't work, see if your computer has a fax modem that itself can be updated and can support the hardware. Your multifunction printer has a scanner; you can scan in the things you want to fax, then fax from the computer if the computer can fax. This is starting to look like a Dr. Seuss book.
You can also try to learn more about what the problems are and look elsewhere. Your "digital" phone is actually voice over Internet, something VOIP. If you Google for VOIP FAX you'll find some information, like this:
http://www.3cx.com/PBX/FAX-VOIP.html
SOURCE: How to I delete my
Hi
Go to Control Panel>Double click of Printer & faxes >It will open up a window you need to delete all tasks from that. If it still doesnt help contact Canon people for further assistance :
http://www.usa.canon.com/consumer/controller?act=ContactCanonAct
Thanks
Rylee
SOURCE: Sending a fax directly from computer using Canon Pixma MX 310
With the document open, you click Print, then choose Cannon ...Fax.
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15603
