Question about Samsung SCH-u740 Cellular Phone
Unalbe to Text in landscape and speaker come on randomly
The light stays on even when the phone is closed
I am unable to text in landscape mode it jumps straight to reply
and the speaker comes on randomly during a call.
I bought a new battery thinking this was the issue but it still happens. Help? Anyone? Did a reset of settings still nothing...
Unable to send or receive text messages message shows unfortunately messaging has stopped
Samsung Galaxy S 4G: Not able to send or receive text messages (airplane mode not enabled)
Hello. It's possible that your cellular service has not enabled your ability to send and receive text messages on their end..
Call your service provider on a different phone to let them know that you are not able to send or receive text messages in all the areas you've tried. Indicate how far away from each location that you are unable to get signal from. If you can not send or receive text messages anywhere at all, this should also be addressed. They may even walk you through resetting your APN settings
In some cases, it could just be the building that you are located in that is blocking cellular service.
Sometimes, it could be a fault of the service provider. They may need to reset your connection on their side. If not, at least you can get them to try..
It sounds like it is not the fault of your phone, but has to do with the Cellular Service Provider.
Jan 28, 2016 | Samsung Galaxy S 4G Cell Phone
Ok hi I have a i1237 polaroid camera And I put on the affects like hmm text? and i take a picture no affects happen Why is this so? Im ReallY getting mad with this camera
Text isn't an effect, it's a shooting mode designed for taking pictures of text. It's intended to optimize the settings for crisp and legible text, just as landscape mode is intended to optimize things for landscapes.
Mar 15, 2011 | Polaroid i1237 Digital Camera
Why does a black box keep appearing on my screen?
The box is probably because you have closed-captioning turned on and set to "text" mode. Check the TV remote control for a button marked "CC" or "CAPTION" or something similar. Press the button to cycle through captioning options until you get to "OFF". This should clear up the trouble.
What's happening is that in text mode, the TV blanks out the area on the screen where the text should go, but there's nothing to display. Text mode isn't widely used, but in some markets it's used to display weather or other information. What sometimes happens is that the caption button on the remote gets pressed and you don't know the TV is set to text mode until the box starts coming up. And it doesn't happen on every channel, or even all the time on the same channel, so it can seem very random.
Thanks for using Fixya!
Oct 06, 2010 | Sylvania SRT2232S 32" TV
Unaudioalble Speakers And Keeps Turning Off.
I can help you with your Pantech c740 Matrix Cell Phone.
It sounds like your phones firmware is corrupted.
I recommend trying to update the system software of your phone.
Review the users manual for the auto-update options.
It is available here.
I hope that helps.
May 26, 2009 | Pantech Matrix Cell Phone
Flipping a page in Office 2003
I think the problem is not affecting by changing the layout from portrait to landscape but specific to the text box layout.
You will have to format your text box to either wrap text, or 90 degree angle - once you have done this on one box you will be able to copy the format to other boxes using format painter.
Apr 21, 2009 | Microsoft Word 2003 for PC
Set auto view text
push the messages button (the bottom left corner in landscape view) - this takes you to the menue
push the same button again - this enters settings
push down and ok - this goes to text message settings
push ok - selects auto text
push up, then ok - changes from "off" to "on" then selects
that should do it!
Apr 19, 2009 | Samsung SCH-u740 Cellular Phone
I need to flip my text to print on a transfer for a t-shirt
You want to flip the text? Do you mean you want the text to display 90 degrees from normal portrait mode into landscape?
If so, when you select a document to print a window should pop up with options to select number of copies, etc. Take note of a pull down menu with portrait, and landscape options.
Use landscape to print your job with the text in this mode.
If you want this set as the default option you can set this in your print settings in the computer.
Open your printer settings in control panel, (assuming you use windows) select the printer with right click, and choose properties. There should be an item labelled document preferences. In this you can select a between Portrait and landscape. Hope this helps.
Feb 11, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Sending dirty texts by itself
Your phone is infected by virus. These kinds of virus send text sms automatically. To avoid this issue format your device or goto your local nokia care shop.
Oct 26, 2008 | Nokia N70 Cellular Phone
Texts random letters and then sends on it's own
have you tried to change the TEXT T9 from iTap to just ENGLISH
Dec 29, 2007 | Motorola Mobility RAZR V3
Samsung SCH-u740 Cellular Phone Logo
29 people viewed this question
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
