Question about Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091
Always have to hold handle to get it to flush
I have an Eljer two piece toilet, I have to hold the handle down the entire time it is flushing, if I let go, it stops flushing. What can be done about this?
  • 867 Answers
Lift the lid,and look, flush, the rubber valve that opens when lever is is pulled should float, so either its very loose or broken and needs to be replaced.plz rate-bozcro
Posted on Sep 10, 2009
  • 57 Answers
Try shortening the pull chain inside the tank, that lifts the flapper in the bottom of the tank. If that does not help, buy a new flapper at the hardware store (less than $3) and install new one (job takes 1 minute). This will solve your problem.
Flushing problems
Tank needs more water and the flapper has to stay open longer by adjusting chain so the flapper goes up higher when you flush the unit. Practice and you will get it right.
Apr 09, 2017 | Kohler Toilet - One Piece with Ingenium...
The plastic handle on the toilet broke.Can it be replaced?
Yes.here are some video instructions on how to do it.
http://video.search.yahoo.com/search/video?p=toilet+flush+handle
May 14, 2011 | Eljer TITAN One-Piece 1.6 GPF Toilet -...
This summer I purchased a eljer toilet. it listed as a 10 flush which is the best I guess. now it is continually turning on to level out the tank. is this normal for eljer toilets? and if not what has to...
ok, this sounds like a float or valve issue, should be an easy fix. you can adjust the float or just replace it with the one piece type. you may not be able to adjust it and get it to work, so I think the best thing to do is just replace the whole float assembly. About ten dollars or so at home depot or someplace like that. Turn off the supply valve, flush the toilet,and drain the tank by removing the plastic nut underneath on the left side. Drain the remaining water into a bowl. There is also a nut on the supply line that will need to be removed first. When you remove the nut that is flush with the bottom of the tank that also holds the valve in place inside. Take off the rubber hose inside the tank and remove the entire float and valve. The new one piece will have a adjustment for the tank level by just turning the entire unit. Make sure you put the rubber washer that is supplied with it on the bottom and put it back into the tank and tighten from the bottom with the new plastic nut. Make sure the valve inside is pointed at the plastic tube and re-attach the rubber hose. Then attach the supply line, tight, but not with a tool, just your hand. Turn on the supply valve, re-fill the tank, flush, and check for leaks. Remember, buy the one piece type, should be a gray valve with a black float built right on it. Good luck
Dec 01, 2010 | Eljer & Complete Toilet In A Box
Flush valve closes before toilet flushes completely?
lift off cover and adjust =shorten length= between flapper and handle lever
Apr 26, 2010 | American Standard Colony 2388.012.222...
I have to hold the lever of my Eljer one-piece toilet to flush it. How to adjust it?
lift off cover and shorten flapper to handle chain/rubber connection flapper not opening all the way
Apr 11, 2010 | Eljer Toilet Onepiece Canterbury ...
My Eljer toilet does not always flush completely. It is approximately 20 years old. I don't believe that it is a venting problem. I have dismounted, inspected and remounted the toilet and found nothing...
Not being a plumber by trade I don't want to bad mouth what your plumber had to say but there may be other things to consider.
If the toilet does not flush directly into the main drain there is the possibilty that the coupling between the main drain and the toilet drain is under-sized which could cause reduced water flow and your toilet not flushing completely.
Feb 26, 2010 | Eljer & Elongated Toilet Bowl
Flush lever wobbles
lift cover and tighten plastic nut on inside of handle
Oct 02, 2009 | Eljer Toilet Onepiece Canterbury ...
The flap goes down too quickly
Just a thought, you might try to get a piece of chain at a hardware store and do it yourself.....might cost $3, maybe less. There is also a screw on the top of the lever the chain and float are attached to, you can loosen or tight it to change the way the toilet flushes.
You can also check on line at:
www.howthingswork.com
Aug 01, 2009 | Ace Hardware Eljer Toilet Tank Flush Lever
Toilet doen't stop flushing
Sounds like the flapper is stuck in the open position.
They sometimes get hung on the flush tube or the chain hanging from the handle.
Is the water level overflowing the tube?
If so, try adjusting the level down, you may need a new fill valve if that doesnt work.
Nov 18, 2008 | Eljer Aqua-Saver 12" Two-Piece...
Eljer Aqua-Saver 12" Two-Piece Pressure-Assist Toilet - 091 Logo
540 people viewed this question
Top Eljer Home Experts
john h
Mike
Charles T Nevin
Charles T Nevin
Are you an Eljer Home Expert? Answer questions, earn points and help others
