Question about Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model
I have a Craftsman mower LT1000 riding mower 17 horse power. It will start and run, but only for a few min. I've replaced the battery, sparkplug, carb. rebuilt, replaced valve cover gasket, fuel line, fuel filter, and gas cap. It still does the same thing. What is wrong with this?
    President:
  • 986 Answers
Need to pull tour carb bowl and clean out, make sure while you have off check you float and make sure it moves free,I hope this helps you and thanks,
Posted on Sep 10, 2009
  • 396 Answers
Also, unplug the wires connected to the bottom of the float-bowl. Just wiggle the plug loose off the bottom of the bowl.
These are 12 volt powered when the ignition is on. Put your key in the ignition and turn it to ON. * DO NOT ATTEMPT TO START THE MOWER.*
With the key in the ON position, use a volt meter and test for 12 Volts
to the terminals of the plug. The Grey is Positive and the Black is Ground.
You should see 12 volts to this connection which powers the Fuel Shut-off solenoid. This solenoid shuts off fuel when you turn off your mower to prevent backfires (IMO-doesnt work!) If you dont see 12 volts, check the plug on the opposite side of your mower where the Grey and Black wires go to. We have had several of these connections fail due to corrosion (needs di-electric grease-Craftsman...are you listening?) Disconnect the plug and see which pins feed the Grey wire. Now test for 12 volts at the plug on the side that leads back up to the ignition switch. If you see 12 volts you know you have the same corrosion problem. Clean the pins, if you have it, a shot of di-electric grease so it wont happen again and reconnect. Test at the float-bowl connector now. Hopefully you will see 12 volts and are all set. If no voltage is at the ignition switch side of the connector you need to test the ignition switch. I believe most mowers will use a Red wire down to the connection we checked and follow that wire to the ignition switch. Tap the wire close to the switch and test for voltage. If you have voltage you know there is a break in the wire leading to the connector. If no voltage is present at the output of the ignition switch it may be time for a new one. You could test all the wires of the ignition switch for another wire that has 12 volts when the ignition is on and simply place a jumper between that wire and the Red feed wire for the solenoid. Of course this is a last resort but should work in a pinch. Good luck.
Posted on Sep 29, 2009
  • ExSP Mar 18, 2011
    I had the same problem with the same mower. It would run for a few minutes, then die. Lots of spark, gas, clean filter, etc. Then I remembered dropping the gas cap, on the garage floor, while filling it. I raised the engine cover and found that the tiny hole in the center of the gas cap had become clogged with debris. The fuel will not properly feed if the vent in the center of the cap is plugged. I cleaned it out and eliminated the stalling problem. Sometimes it's the simple stuff.
I have a craftman riding mower model 917-273381, It will run & cutt grass good for about 4 to 5 min & then stop. I`ve replaced carb kit & check the kill switch. It still doing the same thing.
How long does it have to sit before it starts again? Does it need to be jumped? If battery is old or not recharging you can loose power. I had a regulator go bad and mine would keep dying. I would charge the battery and mow for awhile then would die again. Have you checked battery and regulator?
Sep 07, 2013 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman LT1000 riding mower with 18hp B&S engine. Mower acts like the battery is almost dead. Will try to turn over but doesn't seem to have the power to cycle the engine. New battery, starter,...
There is a compression release device on the cam shaft to allow the engine to spin easier when starting. This is likely the culprit because the starter isn't strong enough to push the engine past full compression. The fix is to replace the cam shaft.
Oct 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman Lt1000 with 21hp keeps wanting to die after 5-10 minutes, battery, plugs and air filter has been replace, any help would be great.
Have you replaced the fuel filter? My 21 horse did the same thing until I put in a new fuel filter.
HOpe this helps.
Aug 19, 2009 | Garden
Craftsman LT1000 tractor not moving
hello otto i would check the belt that runs to the rearend but the brakes could be also froze up i would try to jack it up & see if it will move then go from there
Jun 08, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 LT1000 Won't Start - Need Help
pull the flywheel and check if the key(latter models the flywheel itself will need replaced if stripped)is damaged. This is a possibility.
May 27, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 19.5 riding mower starts runs quits no power
When you let it sit did you remove all the fuel or add a additive? If you did not then I would recommend that you remove all the fuel and add brand new fuel to your system. Gasoline only last for about 3 to 4 months before it will start to go bad and this sounds like your problem
May 22, 2009 | Craftsman 20 Hp 42" Deck Lawn Tractor
I have a 1987 craftsman riding 17 horse mower. I
Sounds like the rings are worn and letting oil escape past them into the cylinder head. After all, it's been in service a long time. There are several options, including a rebuild with boring out the cylinder and put oversize rings in, buying a new engine and replacing the old one, or just buying a new mower.
Sirwriter
May 16, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 17.5 hp 42 in. Deck Lawn Tractor - CA Model Logo
1,329 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
