Question about Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive
External drive no longer appears
External drive used to appear in the finder, now it doesn't. It does appear in the disc utility window.
  • 739 Answers
Hi Neil The are many reports of these drives doing just that (mind you, it's not confined to WD)
I'm guessing you're on a Mac - did you install any of WD's software?
the WD software does nothing on a mac other than cause problems. The best thing is to try connecting to another mac to see if it shows up there.
On the positive side, most times it's not the HD but the enclosure that is at fault.
Posted on Sep 10, 2009
How do I fix my greyed out volumes in my Seagate 4 TB external drive?
Is it formatted to FAT by any chance?
Have you tried pluging it into another mac?
Or even a to a Windows PC?
Oct 15, 2016 | Apple Customized 15" MacBook Pro Laptop...
Tip
Ways to burn Discs with Finder and Disk Utility in Mac (versions OS X 10.4 -...
Without purchasing new disc burning software, there are actually 3 ways to burn CDs & DVDs in your Mac OS X system (Mac OS X 10.3-10.6)
There are methods using Finder and Disk Utility.
Both are easy to do and when set up to use will have you burning music, video, data, and image files (ISO) to CDs or DVDs in no time at all.
BURNING DISKS WITH FINDER
1.) Create a Burn folder and burn a CD/DVD
* The easiest way to burn a disc with Finder is to create a Burn folder with Finder. Here's how you do that:
* Click on any blank space on your desktop and in an instant, Finder will appear on the Apple menu bar next to the Apple menu icon.
• Click on File and select from the drop down menu
* This distinctive folder will now appear on your Desktop
* Now insert a blank CD or DVD and in moments, you will see this window pop up:
• Just click the OK button.
* In a few more moments
on your desktop, you will see this Untitled DVD (or "CD: for CD-ROM Disks) icon:
• Now you can either drag and drop files into the folder, or just double-click the folder and also drag and drop files into the open Burn Folder window
* If you notice, each file you drag (or copy and paste) into the Burn Folder window will have a small curved arrow at the bottom left corner of the file.
That is merely a designation that the file is a image of the actual file and ready to be burned to the CD or DVD you use.
* Notice the Burn button (highlighted in the red box). This is the button you will press, to commence the burn (or copying) of the data you have placed in the burn folder to be copied to disk.
• Click the Burn button, name your disk and that is all it takes. When the process is complete, you will now see a formerly Untitled Disk icon on your desktop replaced with a "Your_new_disc_name" DVD.
(Additional Note: If you wish, you can also simply bypass creating a Burn folder, insert a blank CD or DVD and simply drag and drop or copy and paste files into the open window of the Untitled CD as well.)
BURNING A DISC WITH DISK UTILITY
There are actually two ways to burn data to an DVD or CD with Disk Utility:
1.) Burn a disk in Disk Utility
* Simply open Disk Utility by either clicking anywhere on a blank space on your Desktop window and Finder will appear near your Apple menu, select Go >Utilities and that will take you to the Utilities Folder which is the default location of the Disk Utility application.
* Or you can click the Finder icon on your Dock, open a new Finder window, click on "Applications" listed in the side window and select the Utilities folder
* Either way, you will land here.
• Insert your CD or DVD.
* Once you open Disk Utility, you will see this main window
* Now all you need to do is click the "Burn" button located on the Disk Utility toolbar.
* For an example, I am striving to burn a copy of my Quicken .dmg file to CD.
* Once I have selected the file, then I click the Burn button located at the bottom right corner of the Finder window.
* Follow the onscreen instructions to start the burn process.
2. Creating a multi-session disk using Disk Utility:
Now it is known, that one cannot burn more than once with a single CD-R disc, but it can be done as provide from the knowledge base of Apple support:
  • In the Finder, create a folder for the session and drag the items you want to burn into the folder.
  • In Disk Utility, choose File > New > "Disk Image fromFolder." Then select the folder you created in the dialog and clickOpen.
  • Type a name for the image, choose a disk format, and click Save. Mac OS Extended allows burning the disc more than once. Formats such as ISO allow burning the disc only once.
  • When the disk image is complete, select it in the Disk Utility list and choose images > Burn or click Burn in the toolbar.
  • Insert a blank CD in the optical drive.
  • Select the "Leave disc appendable" checkbox. If you don't see this option, click the triangle in the top-right corner.
  • Click Burn.
What is really nice about this CD/DVD burn feature of DIsk Utility, is that now you can come back later and add more files to the same CD without having to waste all the space on a new CD-R.
This especially useful, if the image file you are need to burn is small in capacity. Just pop the previously burned CD in your drive and add that file or files until that CD is filled to capacity- that is all it takes.
So there you have it, a quick tip on how to use Finder and Disk Utility to burn any data to your CD and DVDs.
Thanks for viewing my Mac OS X tip from FixYa Support. Stay tuned for more tips for how to make the most of your Mac OS X systems!
Regards,
-Mactechtrainer
on Feb 23, 2010 | Computers & Internet
My Toshiba 250gb external hard drive model hddr250e03x is not recognized by my macbook pro but the light turns on. It works on my friend's macbook pro but not mine
I'm assuming you mean it doesn't appear in Finder. Open up disk utility and it should appear there if you say the MacBook is providing power to the hard drive light. You may have to reformat or reset your Mac if you want it in finder
Oct 14, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
Fantom drive volumeSerial No.12072
Disconnect the external firewire drive. Start the Disk Utility app in the Utilities folder inside your applications folder. With the Disk Utility window open, connect the external drive and power it on. It should appear in the left column. If not, your drive has probably failed and may have to be replaced.
If the drive appears, select it, click First Aid, then Repair Disk. Wait for this testing and repair to complete. Any problems should be resolved. If the display indicates irreparable disk problems, you may be able to use the Erase function to reformat the disk - but you will lose all the data on it. If repair seems to work, select the drive in the left column and click Mount in the toolbar. From the desktop, open the drive and see if data appears to be accessible. If so, close Disk Utility, restart your Mac and see if the external drive seems to work (repairs can cause some loss of data, but generally you won't be aware of the loss).
If you don't do so now, you should set up a backup of anything you don't want to lose (and we recognize you might be using the external drive for Time Machine). Disks crash and die. You should have a good backup when they do. Time Machine is your friend. Use it.
Jul 01, 2013 | Apple iBook G4 (Z0AZW13397068) PC Notebook
Iomage macmini 1TB not recognised in disk utilities
Check cable. Try different cable. Try different ports you connect the Iomega with the computer with en on the Iomega itself.
Dec 17, 2011 | Iomega MiniMax Desktop - Hard drive - 500...
Help me! I cannot detect my LaCie Little Disk on my MacBook
There are a number of things that could have gone wrong here.
1. Perhaps you have a bad (USB) cable, try another...
2. Perhaps it's the MAC that may be rejecting it, try it on another MAC or PC (if you do try it to a PC and the drive is formatted to MAC OS, you will need to search for it in disk management.
Right Click on my computer > select 'manage' > on the left-hand pane, select disk management. The drive may come up as unknown if it does appear there.
If the drive has a FAT or NTFS fomrat, then the drive should come up under my computer, although I still advise check disk management.
If you try it on another MAC, just check disk utilities again.
3. The drive has a controller failure, which could explain why it appears to be on but not functioning correctly (the controller function is to communicate with the CPU, so that it appears in disc utilities / disk management.
If you are effected by the second option, you will need to get in touch with MAC support...
If you are effected by the 3rd option, you will most likely need to have it replaced
Hope that helps and clears it up for you!
Jan 25, 2010 | LaCie Hard Disk 1TB Desktop with Hi-Speed...
Accidental ejection
try turning the external drive off & wait a minute then turn it back on.if it works just drag what you want to transfer from your mac to the external drive and it should copy it to the drive.
Apr 06, 2008 | SmartDisk 250GB SMARTDISK CROSSFIRE EXT...
Computer no longer reads drive
It sounds like a permissions issue, allways repair permissions after an update and dont use the machine while installing updates. If it will not repair permissions from disc utility then boot from the install disc, select language and on the page that appears there is a menu bar at the top, select utilities and disc utility and use that.
Apr 03, 2008 | Toshiba 200GB USB 2.0 Portable External...
How do I copy the files to my computer?
• Windows XP After connection is established, simply drag-and-drop files, using Windows the PC. The DVD Camcorder appears as an external DVD-RAM drive in Windows • Windows 98SE, ME, 2000 After connection is established, simply drag-and-drop files, using Windows PC. The DVD Camcorder appears as two external drives such as a removable Explorer. If DVD-RAM disc, the movie files will be copied from the removable If DVD-R disc, the movie files will be copied from the DVD drive.
Sep 05, 2005 | Hitachi DZ-GX20A DVD Camcorder
How do I read the disc on a computer?
• Windows XP Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as external DVD-RAM drive in Windows Explorer. DVD-R disc is read from the camcorder “ drive”. • Windows 98SE, ME, 2000 Install in-box software. Select DVD mode by the mode switch. Connect USB cable between Camcorder and PC. The DVD Camcorder appears as two external drives such as a removable drive and a DVD drive in Windows Explorer. DVD-R disc is read from the DVD drive.
Western Digital My Book Essential 500GB External USB 2.0 - WDH1U5000N 500 GB Hard Drive Logo
401 people viewed this question
Top Western Digital Computers & Internet Experts
Marcin
Mike
Are you a Western Digital Computer and Internet Expert? Answer questions, earn points and help others
