Question about Whirlpool LER4634J Electric Dryer
My whirlpool LGR8648twg is squeeking when it runs . I would like to oil it. How do I do that
  • 304 Answers
Don't oil anything...it makes a mess and if you get it on the belt you'll be replacing it and doing a lot of cleanup.
Replace the idler pulley and drum support rollers. This will likely stop the squeaking.
Disconnect power and turn off gas before working on this dryer. Working on gas dryers is not recommended for people who are not professionals.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
Take careful note of belt configuration BEFORE removing drum. Draw a diagram of its travel. Take care not to touch or hit the ignitor on the gas valve or you will be replacing it also. It is VERY brittle. After drum removal you will see the two drum roller attached to the rear wall. Replace them along with the idler pulley for the belt.
Grasp front edge of dryer drum and rotate counterclockwise slowly to align idler and motor pulley and to remove any twists in the belt.
Check the rear seal of the dryer drum to be sure it's flat and not curled under. Use your fingers to uncurl it all the way around.
Reverse process to re-assemble.
Motor and idler pulley for dyer will be on right. Gas components will be on left
Posted on Sep 11, 2009
How do I fix a squeek on a whirlpool elec. dryer
this is the sound of a bad belt tentioner ... small plastic wheel that keeps the belt tight .. easy fix cost maybe 12.00
Aug 06, 2014 | Whirlpool Dryers
Reebok RBTL18911 squeeks when walking or running. Left side is more than the right side.
I would check manual, it may need to be oiled or cleaned. You can always call tech support for help
Apr 16, 2014 | Horizon Exercise & Fitness
I have a large whirlpool airconditioner in the wall - it colls my living roon and kitcher but within the last few weeks its begun to make a squeeking noise - like a fan that need oil - it doesn't seem...
IT MUST BE THE BLOWER/ ROTTER WHICH IS MAKING THE NOISE. OPEN THE FRONT PANEL AND SPRAY WD-40 TO THE MOVING PARTS. SWITCH OFF THE MAINS FIRST.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | Whirlpool Heating & Cooling
Whirlpool model LEQ8800 - squeeks when running, periodic in nature (1 squeek per revolution), sort of like a high pitched chirp; louder and longer when fully loaded. Is this a bearing (that needs to be...
he belt tensioner has a roller with a bearing in the middle of it. that is your squeaking problem on every revolution it turns
replace the roller and belt sold as a kit at SEARS
Jun 10, 2010 | Dryers
A squeeking type sound coming from the serpentine
Noise could be the result of a dried out belt, a belt that needs adjustment or any one of the pulleys driven by the belt. The oil pump has nothing to do with the belt. Inspect it and try tightening it up a bit. If that does not help, remove the belt and check all the pulleys for noise and rough turning, replace the belt and re-tighten.
May 03, 2010 | 2001 Dodge Ram 1500 Truck 2WD
Dryer is squeeking. Ok to oil in hole on back?
no oil.there's a kit you can buy it's a belt rollers and pulley inside the kit,change them out and you should be fine,don't put any oil in there it will get on clothes
Apr 18, 2010 | Whirlpool WED5500S Electric Dryer
Squeaking noise in bread machine
Remove the bake pan and rotate the connector in the base. If it feels tight, then this is likely the problem.
They don't like being dishwashed either.
Leave overnight with half a cup of olive oil in the pan to see it it will work itself into the plastic bearing.
If you run the machine briefly without the bake pan in there - and it still squeeks - lightly oil the base bearing too.
Ifthese are not the problem, and the squeeking persists, it will be an internal bearing needing a drop of light oil, or the belt could benefit from a dusting with talc (or cornflour)
Feb 20, 2010 | Kitchen Appliances - Others
Dryer squeeks until warming up
If it is a Sears or Whirlpool the drum rollers or the belt idler need oiled. Use AutoTransmissionFluid or 3n1 oil(no WD-40 as it will ruin the bushings) a few drops each. If a GE or Hotpoint the drum sliders and bearing need to be serviced and replaced. They can be lubed with bar soap. If this is helpful,Please leave Feedback. Thanks, SnugglePants
Oct 21, 2009 | Dryers
Squeeking fan on power ventilation my unit is a AW1400A/XAA, when I turn unit on it squeeks. It sounds like its in the squirrel cage or fan.
Hi there!
This is almost certainly a dry bearing on the fan motor. If there is little or no oil on there, a little rust may form and the next time this is powered up, the rust comes off - but is polished onto the bearing - creating the squeek.
Buy a can of maintenance oil in a pressurised can, and squirt some on the bearings at each end of the motor. It doesn't matter if it drips or runs down anything. If there are 2 separate motors - you need to oil 4 places.
If the unit is very old, it may use a motor with brushes. I'll give more details if the oil doesn't work.
Thanks for using Fixya - and if this works, please rate as such.
Jul 01, 2008 | Heating & Cooling
Whirlpool LER4634J Electric Dryer Logo
76 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal DeAngelo
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
