Question about HP PSC 1315 All-In-One InkJet Printer
No HP Director
Hp director has disappeared since transferring to my new vista computer?
  • jetilley Dec 10, 2007
    I need to reinstall on a new computer printer works as does the copier. scanner will not work with new computer running win vista
I had this same problem when switching to our new pc and still running xp. I was told that the new pc was installed with the new version of the program and had to uninstall the new version and load the old from the cd in order to use the programs I was framiliar with. Check with HP tech support and have them help you through the uninstall.
Posted on Dec 10, 2007
Free download HP director for HP Office jet 7410
the hp support wesite should have it---if not, try driverguide.com
May 08, 2010 | HP OfficeJet 7410 All-In-One InkJet...
Hi There! I am having problem opening my hp director program
  1. Open HP Director using one of the following methods:
    • From the desktop : On your computer's desktop, look for the HP Director icon (c01425509.gif), and then double-click it.
    • From the Windows taskbar : Click Start , click All Programs , click the HP orHewlett-Packard folder, and then click HP Director .
    Although HP Director does not appear to be open , it is open and loaded into the computer's memory, but it does not open in a new window as usual.
  2. Without navigating to another open window, press Alt and Space bar at the same time. The Shortcut menu displays near the top-left corner of the computer. Figure 1: Shortcut menuc00833293.gif If the Shortcut menu does not open, repeat steps 1 and 2 until it does.
  3. Select Minimize from the Shortcut menu.HP Director displays (minimizes) as an item on the taskbar (the row of open software programs that appears at the bottom of the desktop screen). If HP Director does not minimize, click Minimize again until it does.
  4. Click the HP Director icon on the taskbar . The software opens and functions normally.
Dec 08, 2009 | Microsoft Windows XP Home Edition
Hp director does not open when i click on the icon
After installing (MS IE 7 or MS IE 8) browser on the computer that is connected to the HP product,This issue occurs on some HP products. The MS IE 7 or 8 browsers might be incompatible with HP Director
Follow these steps to use a workaround to open HP Director each time you use the software. These steps must be repeated each time you use HP Director.
1-Open HP Director using one of the following methods:
From the desktop : On your computer's desktop, look for the HP Director icon ( ), and then double-click it.
From the Windows taskbar : Click Start , click All Programs , click the HP or Hewlett-Packard folder, and then click HP Director .
2-Without navigating to another open window, press Alt and Space bar at the same time.
3-Select Minimize from the Shortcut menu.
4-Click the HP Director icon on the taskbar ( ). The software opens and functions normally. NOTE: The HP Director window and icons might appear larger than normal, but the software is functional.
5-Repeat Steps 1 through 4 every time you use HP Directo
Thanks,
Nov 30, 2009 | Computers & Internet
CAN,T GET HP DIRECTOR TO OPEN ON VISA COMPUTER
HP Director isn't compatible with Windows Vista. HP Solution Center replaces HP Director in Vista.Check out the explanation here - and some information about how to install Solution Center.http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01471226&cc=us&lc=en&dlc=en&product=303753
Jun 06, 2009 | HP PSC 2410 All-In-One InkJet Printer
Can't open Hp director
I read ur problem.This problem with HP director occurs if you are running Internet version (7.0).If u have difficulties knowing your Internet version, pls do the things mentioned below.
1.Open internet explorer->click help->then click on "about internet explorer".---There you will see the version of your browser.
SOLUTION.
If see an hour glass appearing and disappearing without displaying the HP director window after clicking on HP director, You got the following solutions.
Solution 1.
1.Double click HP director icon.
2.Then Press Alt + space key together.
Result:YOU will see a small pop menu appearing on the desktop screen.
3.Click on "minimize" on that pop up screen.
Result:Now u will see a tab on the taskbar.
4.Right click the tab(hp director),then click restore...Now you will see your HP director window.
Note: Above solution should be performed while trying to open HP director.(ie) You should try this every time if u want to open HP director.To go for full time resolution,then try solution 2.
SOLUTION 2:
1.Open "www.HP.com"
2.Select "software and driver downloads"
3.Type your product name in the "for product text box",then hit enter.{(eg) if u type 7410 for office 7410,then u have to select the exact model in the next window}
4.Select the operating system.(if u dont see a option to select operating sys, there u will see "software and driver downloads"
5.In the next page, you will see a list call "Updates" you have to download a update which says "
Critical update to resolve an issue with HP Director after installing Internet Explorer "
6.After downloading the update, run the file and thentry to open HP director it will open the director window.
This will work.I assure u total problem resolution
Regards
Chittaranjan
Dec 25, 2008 | HP Scanjet 3570 Flatbed Scanner
WHERE COULD I DOWNLOAD THE HP DIRECTOR SOFTWARE
It wont work with xp, it will only work with windows 2000 and lower
Nov 28, 2008 | HP PSC 1210 All-In-One InkJet Printer
Hi go to hp site find utiliity section for this printer
Sep 03, 2008 | HP Officejet 5510 All-In-One Thermal...
Can't open HP Director
You say it works with XP, so I assume it doesn't work with Vista? If that's the case you can download the newest Vista drivers HERE.
Hope that helps...
Geno
Mar 25, 2008 | HP Officejet 4215v All-in-One Printer
HP PSC 1210 all-in-one Director does not work with VISTA
I've been fighting the same. Did some hunting on the HP and MS web sites. Found a "work around". Not what I wanted but at least I can scan. I think HP Director is gone for Vista users. :(
Scanning with Windows Photo Gallery
1. Click the Start ( ) icon.
2. Click All Programs .
3. Click Windows Photo Gallery .
4. Click File and then click Import From Scanner or Camera .
5. Click Import .
6. Click Scan .
Jan 16, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP PSC 1315 All-In-One InkJet Printer Logo
65 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
