Question about Garden
Electric PTO won't re-engage after running OK for a while
Simplicity Regent 17HP Hydro. Seems to work after cooling down. Also I can lift up momentarily on the seat causing the engine to start to stall and when I sit back down, the engine and the PTO start running.
  • fixya_20_mar Sep 15, 2009
    I fixed the problem by adjusting the gap between the clutch plates on the PTO. Old gap was .037". I adjusted the gap to .012" by tightening the 3 adjusting nuts. Very simple.
  • 47 Answers
Might be rust between the plates or you need to adjust the springs tenson there are 3 bolts on it
Posted on Sep 11, 2009
Testimonial: "Adjusting the gap worked. Old gap was .037". I adjusted it to .012"."
Simplicity. How do I test the interlock module?
snapper mower:interlock module - how test?
www.homeownershub.com > Home Repair
May 28, 2005 - 1 post - ‎1 author Snapper 1438H Hydro, rear-engine riding mower. Thing yesterday just quit. ... Next item up the line is the INTERLOCK MODULE... All the safety ..
Sep 05, 2015 | Garden
What belt engages the blades
pto belt engages deck then you have a deck b elt
Sep 02, 2014 | Simplicity Regent 22 44 Riding Lawn Mower...
Why does my engine shut off after running for awhile with PTO engaged; will restart with PTO disengaged, but shuts off when i attempt to engage PTO?
Does this only happen when the engine is warm or at operating temperature or all the time even when cold? In older engines, a 'bad ignition coil' would fail when the engine warmed up and would not start again until cool or at ambient temperature.
Apr 27, 2014 | Garden
PTO stay engaged on allison transmission md3060/ PTO chelsea 277
wires to the pto solenoid incorrect and not wired properly through the switch
did you put the correct shims under the flange of the pto mount as it it is incorrect distance , the pto teeth will say jammed in the transmission gear teeth
suggest that you take it to a shop that fits pto and have the installation checked before you damage the transmission
Mar 12, 2013 | Garden
Simplicity Regent Starting Problem
The wrong seat switch was installed. There are black ones and gray ones. I believe you need the gray one for open circuits.
Aug 10, 2012 | Simplicity Regent 19.5/38
Engine shuts down when pedal is released, and when pto is ingaged
check your Reverse Gear engage switch and PTO (blades engaged switch), either a bad switch(es) or short in wiring indicating that you are in Reverse with the blades engaged. Is there an override function so that you can mow in reverse? Check that circuit vs. the PTO and reverse gear. good luck
Mar 17, 2010 | Garden
Simplicity regent mower electric pto suddenly stops working but will work again later.
I have the same problem with my regent. Sometimes i just ride around a few minutes and it suddenly engages. I have no idea why.
Aug 19, 2009 | Briggs & Stratton Garden
Garden Logo
624 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
