Question about Creative Labs ZEN Vision:M Digital Media Player
I have creative zen vision m that won't turn on, the led only flashes when i plug it in. i have tried reseting it to no avail. its about 3 years old so i'm willing to open it up myself, but i don't think i can justify the cost of repair
    President:
  • 392 Answers
Jus let it stay connected for charging for a long time(like for hours together) and it should come on...it seems just to be a battery drain problem...
Posted on Sep 11, 2009
My creative zen won't turn on it's vision m 30 gb and when you plug it in all it dose is flash It doesn't pop up or even say anything in my computer PLEASE HELP
I am unable to reset my ZEN Vision M player. It will not even connect with my computer and the battery is completely dead. Is there a solution?
Jul 03, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen won't turn on
had same prob to the T...found this post and it fixed it...it's the computer not the zen...once I did the two steps my zen started charging and turned on...go figure...the flashing blue light doesn't mean it is charging.
posted on Feb 25, 2009 abeales
If you have windows set to do automatic updates, you most likely had a windows update installed that caused this conflict with Win Media Player 11. No fix has been posted by Microsoft yet, so the only workaround is to Uninstall/Rollback Windows Media Player 11. Goto <Control Panel<Add/Remove Programs and remove Windows Media Player 11. Follow prompts, restart computer when prompted to. Also uninstall Windows Media Player 11 Runtime application following same procedure above.
This will roll your Windows Media Player back to version 10 or 9, whichever you had installed prior to version 11. You will need to re-configure Windows Media Player again.
Your Zen should now be recognized by WMP and Creative software. You probably need to upgrade your firmware at this point, follow the instructions on upgrading your firmware, and you should be good to go.
This is a windows problem, not a creative problem. Dont blame Creative for the screwed up hotfixes that Microsoft puts out on a regular basi
May 28, 2009 | Creative Labs ZEN Vision:M Digital Media...
I had a similar problem with my Zen Vision:M, whereby the computer just stopped recognizing my device. I found out it was because Windws has updated to Service Pack 3 automatically, and for some reason my player only works with SP2. It started working again when I installed SP2 again, but then I keep getting the annoying upgdate notifications from windows.
May 27, 2009 | Creative Labs ZEN Vision:M Digital Media...
Vision: M won't charge
The battery not charging,
I hat the same probleam. Solution reset the unit while is plugged on the Ac charge, turn off and on. will work.
ciao Enzo
May 10, 2009 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision :m 30gb wont turn on
if you don't have the kind of charger that goes directly into the dock connector, the zen vision needs a 5V charger ( it happens to be compatible with the PSP charger). if you just plug it into a usb cord it will not charger. you may also need the little white adapter piece the goes into the dock connector. i know only one place that sells older creative zen accessories and repairs creative zen visions . if you have all of that: i assume you pressed the little reset button on the bottom, it may just be frozen? if that doesn't work and you are sure you're charging it right, your logic board is dead.
Apr 03, 2009 | Creative Labs Zen Vision Digital Media...
Creative Zen just flashes
have you tried to charge it using an ac charger?
May 19, 2008 | Creative Labs ZEN Vision:M Digital Media...
Dead Creative Zen M
Usually this problem is due to the firmware. When the firmware is updated to version 1.62.02, this problem usually will be corrected. The older firmwares have problems in recognizing the battery and allowing the battery to power the unit.
You will need a wall/AC charger for the operation. Plug in the wall charger and USB cable at the same time. Your Zen should power on when connected to direct AC power via the wall charger. Once it is powered on, connect the USB cable to your computer. Then begin the firmware download.
If your Zen does not power on when connected to the wall charger, your unit is dead and its time to replace it or get the motherboard replaced via one of the Repair services offered on this website.
If the upgrade button on the firmware window is not available, it is also time to replace your motherboard due to corruption of a chip on the board.
Mar 13, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative zen vision won't turn on
Q. Zen V is dead
"If your Zen V is dead, wont respond to anything, try this, plug it in to the computer, hold the power switch in the on position, THEN trigger the reset button, worked like a charm for mine, I had thought it a lost cause."
Q. How to reset Zen v +
http://www.youtube.com/watch?v=22T_gkkZjmM&feature=related
also try this if above doesnt work
Feb 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Creative Zen Vision m
Zen V is dead
Zen Vision:M Not Responding SOLUTION! to No Charge, Device Not Connected or Recognize
http://www.anythingbutipod.com/forum/showthread.php?t=10960
Dec 16, 2007 | Creative Labs ZEN Vision:M Digital Media...
CREATIVE ZEN VISION MZEN VISION M TECHNICAL SUPPORT
read this:
Dec 12, 2007 | Creative Labs ZEN Vision:M Digital Media...
Creative Labs ZEN Vision:M Digital Media Player Logo
82 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Mohamed Ismail
Mohamed Ismail
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
