Question about LG 42LC2D 42 in. LCD HDTV
Samsung LCD 40 Sensor & picture problem.
Samsung LCD 40" TV: TV turns on and off repeatedly. It seems to be struggling to keep itself powered. The remote doesn't change anything. If it decides to stay on long enough to get a signal, the picture is narrow vertical rainbow stripes. Will not stay off unless unplugged. Sound is OK when TV is on.
  • Anonymous Mar 18, 2014
    starts ok but rapidly deteriorates
  • LG Master
  • 5,568 Answers
Since this is affecting several functions, the problem is likely the main power supply. It may be that the supply itself is failing (switched mode power supplies like hari-kari) or an assembly (possibly the backlight invertor) is producing a fault condition which is causing the supply to drop out to protect itself.
Try the instructions below -
The supply is normally built on a separate board since these are often out-sourced by set manufacturers.
Unplug your set overnight to allow potentially hazardous voltages to discharge, remove the back panel of the set so you can see the guts.
Look for a smaller board with larger parts on it; some cylindrical (capacitors), others block-like and relatively large (chokes and transformers).
You should also see a relationship between the board and the incoming AC.
Check the board for a label or if not present, a stamped-on number.
Call the manufacturer's service center with your TV model number and the number found on that board and inquire about repair/replacement costs; if both are offered, they won't be that much different.
If you must buy a new board, don't dispose of the failed one as there are smaller companies that can repair it for less than the mfr. and then keep it as a spare as this problem will likely arise again.
Posted on Sep 10, 2009
How do I fix my Samsung 40 LED TV that has sound but no picture?
Samsung 60-Inch 1080p 120Hz Slim Smart LED HDTV ...
? 10:42
www.youtube.com/watch?v=hcVhHU322Gk
May 18, 2015 - Uploaded by Thomas M. Landry
samsung un60h6350 60-inch 1080p 120hz smart led tv,samsung... 120hz smart hdtv,slim led tv,65 inch smart tv deals,samsung 40 led 1080p 120hz ... LCD & LED TV Repair - No Image & Blank Black Screen Flashlight Test ...
Oct 15, 2015 | Samsung 40" 1080p 120Hz Slim LED Smart TV...
MY PICTURE SETTINGS KEEPS RESETTING ITSELF AFTER ABOUT 40 MINS.
I have got a Samsung LE40R88BD 40in lcd tv that after about half an hour the screen goes black and then comes back on after about ten secs but the picture is very much darker. what is the problem?
Nov 02, 2010 | Samsung LA40R81BDX 40 in. LCD TV
Samsung LA40A550 no picture and sound
Power supply board is dead.That the board,the power a/c cord go into it.Replaced the power supply board will solved ur tv power lite LED light indicator blinking and ur tv power will be stable and work again.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
Jun 04, 2010 | Samsung LA40A550 40 in. HD-Ready LCD TV
Tv keeps shutting off and going back on by itself
Cold solder joint in the power-supply board, once it heats up it expands and shuts off. Open it up and start scanning the board for defects and hit them with a hot soldering iron and a dab of solder.
Cheers
May 05, 2010 | Samsung LN-S4051D 40 in. LCD Television
Samsung tv wont turn on stand by button just keeps
hi,
your lcd tv got to replace the ip board (power board) the capacitor has already exhusted.
Apr 19, 2010 | Samsung LE40M91B 40 in. LCD TV
Power won't come on- constant clicking loop instead
My T.V. did the same thing and it was due to bad capacitors on the power supply board. the tops of the capacitors were bulged, once replaced it worked fine. It involves sodering in new capacitors total cost $30. that includes buying the sodering tool. Keep looking around on line someone had pictures step by step how to do it.
Mar 26, 2009 | Samsung LN-T4042H 40 in. LCD HDTV
Samsung LCD tv - Turns on and off by itself.
Since you have another TV with the same problem you can try using an antenna(indoor model ok) to see if the cable is causing the problem. If not return TV before the warranty expires.
Mar 03, 2009 | Samsung LN46A850 LCD TV
Samsung LCD 40 inch LNT4061
Howdy,
It sounds like you have a Power Supply Board problem. The PSB is the center Board (towards left) after you remove the back off the TV. Remove Board from TV with the 6-7 screws. Replace capacitors CM852 & CM853; 2200ufd 25volts.
Thanks for using FIXYA, big IRISH.
Dec 31, 2008 | Samsung LN-T4061F 40 in. LCD HDTV
Samsung LN-S4051D slow to turn on.
You are likely to have a module bad....part number BN94-00864A and if you take it out (unpluggs) you should inspect it for capacitors that may be domed or pooched up at the top. If so they should be replaced first before getting the module as the capacitors are about $1.00 each. Do a search for Samsung parts online if you need the module and call them toll free
Mar 16, 2008 | Samsung LN-S4051D 40 in. LCD Television
Samsung lcd tv le32r8
perchè quando collego il computer al televisore l' audio è assente?
Oct 15, 2007 | Samsung LN-R409D 40 in. LCD Television
LG 42LC2D 42 in. LCD HDTV Logo
138 people viewed this question
Computer Repairing
Computer Repairing
