Question about IBM Computers & Internet
I have a Thinkpad T60...AC port on rear of T60 has broken off inside (at the system board)...someone told me a docking station would be an alternative to getting AC to the system board...is this correct? Or does a docking station just plug into the same AC port?
  • knightriderr Sep 10, 2009
    thanks...just to be crystal clear before I order this, the AC power goes from an electrical outlet on the wall thru the docking station into the Thinkpad...the interface between the docking station and the T60 is NOT thru the same little round yellow port on the back of the T60? If it transmits power tho the T60 thru a different port (or interface on the bottom of the T60, then I can see how this will work...I don't care about all of the other ports (USB's, etc)...thanks again
    President:
  • 632 Answers
A docking station is a good alternative but if you have an electronic prowess then you can reattach the broken port..Just open the casing and resolder the broken port..you can provide a support for the port like a glue stick or something that will prevent it from falling off the board.
Posted on Sep 11, 2009
  • 298 Answers
What you have been told is correct. The docking station is using different ports that are additional to those normally used. It is normally considered as a port replicator. Power is fed to the docking station through an inbuilt unit which in turn feeds the thinkpad from the slot at the bottom.
http://www.pcnation.com/web/details.asp?affid=305&item=H16739
Posted on Sep 10, 2009
I have a ibm t60 laptop. The power cotd tests good. But the battery wont charge and the AC power light does not come on.
I see this same thing often, when people push in the power plug too hard, jostle the laptop around alot or even tried to force the wrong plug into the port---it sounds like you may have broken the solder on the mother board on the power inlet, There are 4, 6 or 8 solder spots on most power inlets, you may have broken one or more of them loose---take it to the shop if you are not handy with a screw driver and a soldering pen...
Feb 14, 2011 | IBM ThinkPad T60 Notebook
Machine reboots when it is hot docked
This sounds like a common feature of the T60, when docked it requires a reboot also try to reboot 2-3 time a day to help cooldown. IBM is a quality machine, even go as far as buying cooling extention for the T60.
Apr 29, 2010 | IBM (250410U) Docking Station for ThinkPad
Usb ports on the ibm docking station not active
Dear rajeshraja42,
Try to run the recovery CD from IBM Docking station, and reconfigure your system by connecting your docking station while you run them.
Or try this:
Connect your docking station to your Laptop then turn the Computer On!
Start>My Computer--- Then right click--- Choose 'Properties'>On the dialog box, ----choose the 'Hardware' Tab> Choose the Device Manager box by click them>Now You are in the DEVICE Manager Box>>>
Run the Scan For Hardware Changes... Then if you find that your docking station appear with Yellow Question Mark Then, right click on it and choose 'Uninstall' from context menu and answer YES! then Run the SCAN for hardware changes for ONE last time, Your System should find your Docking station as part of your system now!
GoodLuck!
Best Regards,
bionic23
Dec 07, 2009 | IBM (250410U) Docking Station for ThinkPad
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
Lenovo T60 power port not working
If the docking station charging doesn't work either and your battery is ok you have lost voltage regulator (it prevents overcharging of battery) Take the battery to a battery plus store and they can check it..
Sep 10, 2009 | Lenovo Thinkpad T60 Notebook
Power jack connection broken on HP Omnibook xe3
I bought a docking station (port replicator) off ebay, and it has worked great. I had a look at the motherboard, and the docking station uses a different connection for power than the damaged AC port. So in summary, yes a docking port should solve your problem.
If you can get a docking station for it you may be able to solve it that way.
Apr 15, 2009 | HP OmniBook XE3 Notebook
My printer has a parallel plug and my new docking station...
You can buy a cable that goes on your old printer cable to convert to USB most computer shop will hav these or can get one
Jan 25, 2009 | IBM (250410U) Docking Station for ThinkPad
T-60 will not seat properly in 2504 docking station.
I have the same docking station and I am typing this on my T60 right now. I have noticed that sometimes it is very hard to dock my laptop and other times it just slides on instantly. This seems to be an issue with poor design. If you look a the dock connector under you laptop you will notice there is a strip of plastic in the middle of two rows of connectors. The docking station connector must be perfectly aligned to successfully connect. I would inspect it for any damages, but honestly I think it is just an issue of patients, precision and a little bit of luck. If you can not identify any damage I would just slowly try to line it up and keep trying until it clicks. Remember to never force it and once it lines up it will slide in with very little force.
Nov 04, 2008 | IBM ThinkPad T60 Notebook
Computers & Internet Logo
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
