Question about Kenmore 65942 Electric Dryer
I have a Kenmore 70 Series electric dryer #66702 that stops before the end of the cycle time. It will start up again after pusing the start button but may turn itself off again after a few more minutes. Any ideas? Thanks, Doug
  • moonshadow80 Sep 20, 2009
    Thanx alot for the response. Once inside the interior, I vacuumed around the motor and ends. Didn't seem especially built up with lint. After reassembling, did a few loads over a week or so with no problems. Now today, while drying, Wife opened the door to pull something out while still damp. When she closed the dryer and pressed the button to re-start....Nothing. Have waited over 45 min. and still won't start. Could it be something else?
    Thanx again
  • 304 Answers
This is usually caused by a motor getting too hot. The motor has a shutoff to protect it against burnout. It will reset when it gets cool. As the motor overheats more and more these shutoffs become more frequent and longer
Motors get hot for several reasons:
1. Motor going bad
2. Lint around motor causing it to retain heat
3. Vent system open at some point inside or behind case allowing heated air to remain in motor area
Follow the procedure below to disassemble and check interior of dryer. Vacuum carefully especially around and in the ends of the motor.
Disconnect Power. Lift Cover on lint filter. Remove two Phillips screws taking care NOT to allow them to fall into the blower housing. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a 5/16” hex head screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior. Reverse process to re-assemble. Take careful note of belt configuration BEFORE removing it. Draw a diagram of its travel.
Motor and idler pulley for dryer will be on right.
Posted on Sep 11, 2009
Testimonial: "Sep 20, 2009 - Thanx alot for the response. Once inside the interior, I vacuumed around the motor and ends. Didn't seem especially built up with lint. After reassembling, did a few loads over a week or so with no problems. Now today, while drying, Wife opened the door to pull something out while still damp. When she closed the dryer and pressed the button to re-start....Nothing. Have waited over 45 min. and still won't start. Could it be something else? Thanx again"
  • Controlfrk
    Controlfrk Sep 20, 2009
    The problem you now describe is usually caused by a thermal fuse intended to shut the dryer motor down and keep it off because of a problem with air flow within the dryer.
    The following process will allow you to test the thermal fuse and replace it if you find it open.
    Unplug unit and turn off gas if gas model. Check to be sure you have 240 Volts at wall outlet.
    Most parts likely to fail on electric dryers are inside the rear cover. Heater is on right inside can, safety thermostat on lower left of can, High limit thermostat (non-resettable) higher left of can. On the blower housing to the left are the operating thermostat and, in some models, a thermal fuse (white plastic). ALL can be continuity checked easily. Always disconnect wire on one side of what you are testing. One will likely be open. Replace the component that fails the continuity test.
    The thermal fuse or high limit thermostat failure generally points to a reduction of air flow due to SOME blockage either inside the dryer or in the vent pipe leading out of the house. If you find either of these parts bad be sure to check the vents after replacing parts to ensure the same parts won't fail again.
I have a Kenmore Series 70 Dryer and I changed the thermal fuse got hot for a few minutes the model #110.74722400
The cycling thermostat must also be replaced when replacing the thermal fuse. The cycling thermostat's failure to cycle off the heating element results in overheating of the dryer which consequently blows the thermal fuse open.
Replacing only the thermal fuse should the dryer stops running and fails to start will result in its premature blowing or even the thermal cut-out (cut-off) located on the heater duct. Like the cycling thermostat, the high-limit thermostat must also be replaced once the thermal cut-out blows open. Refer to the parts diagram in the link below and look for item numbers 31(thermal cut-off), 34(hi-limit thermostat), 39(thermal fuse), and 41(cycling thermostat.
Kenmore Series 70 Electric Dryer (110.74722400) Bulkhead Parts
Aug 21, 2011 | Dryers
63942 Dryer: how do you turn off the dryer signal on kenmore 70...
Hi, you can turn the signal off by using the start button on the dryer (located on the right side of the panel under the words "Push to start dryer"). Turn the knob to the left to turn the signal off, or to the right to turn it on. Each side should be labeled, but the lettering may have worn off over time.
If you've turned the knob to the left and it still signals at the end of a cycle, the switch that controls the signal may be broken.
May 18, 2010 | Kenmore 63942 Dryer
Dryer stops but the timer continues on
Fixed! The "push to start" button was stuck. Must have been some dust. I pushed the knob a few times and that's all it took. Works fine now.
Dec 12, 2009 | Kenmore Dryers
Kenmore Dryer 70 series
Hi, the problem with the dryer not stopping is most likely the switch that controls when it starts. This switch is located behind the button you would push in to start the dryer, and if you can take off the rear panel and get to it, you can most likely adjust the internal contacts so that they don't continuously make contact. Or you could just replace the switch, which might be easier!
Jul 21, 2008 | Kenmore 64742 Electric Dryer
Kenmore Series 70 Dryer Buzzer won't stop buzzing - Model 110.96573220
  • the buzzer is located under the control panel.
  • you can unplug it.
  • unplug the dryer or turn the breaker off first
  • then take out the 2 screws on both sides of the control panel
  • bull it forward toward you and unhook it from the case
  • you should see the buzzer with two wires going to it
  • only need to disconnect one.
  •  just make sure you wrap the bare wire connector with electrical tape to keep it from touching metal.
Jun 28, 2008 | Kenmore 60172 Electric Commercial Dryer
Signal
Kenmore 70 series. Model/Stock 66702692 Serial MG2402832
Cycle Signal works but then won't shut off until I open up the dryer door - it just keeps buzzing for hours. Also the dryer will turn on if I close the door ( and arrow is within a number and not on off) without pressing the start button. So if door is closed - the dryer will run or buzz (depending on arrow). How do I fix this?
Thank you
Jan 04, 2008 | Kenmore 64892 Electric Dryer
Kenmore 70 series model # 96573220
Sounds like the push to start switch has gone bad. Not to expensive to fix, and pretty easy to do as well. You can remove the rear of the console, remove the push to start switch (lift the tab, then turn to unlock) and replace. Be sure to mark your wires so they go back in the right order. Jim
Nov 18, 2007 | Kenmore 60172 Electric Commercial Dryer
Kenmore 65942 Electric Dryer Logo
404 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
