Question about Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television
I have a sharp LC-C3742U which has not been use for a few days, but is connected to Verizon FIOS box. When we turn it on with FIOS remote, the power indication light is green, but no picture and no sound. We tried to turn it off by hitting the power button on the set or with Sharp remote but it just would not turn off. We unplug and replug, the power indicator is on green again and nothing else works and it stuck at the power-on position.
  • bbmacbeth Sep 10, 2009
    Please tell me what (and where) is the main board and what is the power board as I have no schematic diagram. If to replace as you suggested, what is the name, or number for these boards that can be ordered, and from whom?
  • 10,594 Answers
It sounds TV got problem with system control section on main board and board need to be replaced.
Please check supplied volts mentioned on power board towards main board, if supply volts are OK, replace main board. Qualified TV tech is required to test volts.
Click Shop Jimmy for main board info.
Thanks.
Posted on Sep 10, 2009
  • Shahid Electronics
    Shahid Electronics Sep 10, 2009
    from whom?
    If you follow AC cord of TV that will take you to power supply board.
    I gave you Shop Jimmy link, click that link to see main board image, part number and its price info.
    I would recommend to have qualified TV tech to fix TV if you have not sufficient experience of electronics stuff repair.
    Thanks.
C3742U. Where can I get a replacement power cord?
If you mean the Sharp LC-C3742U TV, the power cord is part number: QACCDA039WJPZ . Several vendors have the power cord, including Amazon.com. See http://www.amazon.com/SHARP-OEM-QACCDA039WJPZ-CORD-CORE/dp/B001DEJTN6 and https://www.partstore.com/Part/Sharp/Sharp/LCC3742U/Sharp/Sharp/QACCDA039WJPZ/New.aspx, among other links.
I hope this helps.
Dec 18, 2015 | Sharp Aquos LC-13B6U-S LCD flat panel TV...
Sharp lcd tv will not respond to remote control
You are paying fios good bucks for service so let them earn it by getting your system to work with their gear as intended.
Make sense? It is THEIR not yours. U did not have this issue with the other company!
Sep 06, 2017 | Sharp AQUOS LC-32SB21U 32 in. LCD TV
Sharp lc-c3742u will not power-on can i cut wires and unite them bypassing what it looks like a hot-dog
TV will develop smoke then fire. doing that. The power supply board has failed. replace that.
Oct 09, 2010 | Sharp Aquos LC-32D40U Television
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Philips TV HDMI CEC EasyLink tries to control Cable set top box
I finally found a fix to this! YAY. I thought I might have to return the TV. I have the Phillips 42PFL5603D, but should work for other models.
On the TV press menu picture settings---picture---dynamic contrast (turn off) AND active control, turn off
If you have Comcast Moto box: on the Cable box go menu--->setup--->cablebox set up---RF BYbass set to ON
If you have a non-Comcast Moto Box, I'm sure there is an RF bypass setting in the menu. You'll just have to look for it. Another fix was close saying to only turn of the active control, but it took all 3 of these for it to work consistently. The latter let it work for all of 30 seconds.
Dec 29, 2008 | Philips 42PFL7403D/27 42 in. LCD TV
Need remote codes to enter into my verizon fios remote
what kind of equipment is it? cus you can go to verizon.com go to fios tv then installation then support and click on remotes then get codes for yada yada yada/
Oct 23, 2008 | Broksonic CCVG297 9 in. TV/DVD Combo
POLAROID 1511-TLXB LCD TV Remote Code for Verizon FiOS STB
I posted that as a point of information. I noted from searches that other people were having remote code problems w/that TV set. Code 0205 worked for me.
Aug 23, 2008 | Polaroid 1511-TLXB 15.4 in. LCD Television
Sharp 37'LCD missing Close Caption in Component and HDMI input
I HAVE A SHARP SHARP LC19SB25U - 19" Class HDTV LCD TV. I can turn it on but I have no pictue and cannot use the remote that came with it. For some reason, when I press buttons on television or the remote, it won't respond. Can you help me.
Jul 31, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Verizon FIOS Motorola 6200-2 HD box remote freezes
i'm a verizon employee currently working at a customer's house. just swapped out 3rd 6200 stb, the channels will seemingly change on their own(scrolling) after pressing the remote just a few times. the root of the problem is that the remote is not responding to the stb in the first place properly. all i can figure is that there is some type of ir interference. i've placed the remote 1" from the stb and the same problem exists. it's not the box and the remote is brand new, tried 3 remotes as well. there is something going on in the atmosphere around the box - in or outside the custmer's house. they were on vacation and when they came back this is the trouble they were having. i don't have an answer, just some type of possibilities. there is a power transformer outside on a pole approx. 100' from the house and we had bad storm related issues in the past week. i know it's a stretch, but you never know. could be surround sound/ stereo equipment generating some kind of field??????????? good luck.
Apr 30, 2008 | Arris DCT6200 DTV Receiver
Sharp Aquos LC-37G4U 37 in. HD-Ready LCD Television Logo
341 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
