Question about Electrical Supplies
Operators and part manual for model 135212 type
Operators and part manual for model 135212 type 012901 code 961112yb
I need to understand why my printer is flashing the color & black with a symbol showing and flashing the number 5
on most printers the flashing symbols indicate very low ink levels in the cartridges
read the operators manual for the fault codes
if you do not have one then go google and type in-- operators manual for (make and model) printer
Oct 13, 2015 | Office Equipment & Supplies
How much oil to fill for oil change
if its a 5 hp engine fill to top of thread on fill hole
Apr 12, 2014 | Briggs & Stratton Garden
Briggs+stratton
the older models had points,yes. the air gap at the coil-magneto is .010in.
May 12, 2013 | Garden
I have a Weed Eater Electrolux Model 961340001 02 push mower with a Briggs and Stratton Q4.75 engine. I'm have trouble finding the model # on it.
Look on the engine blower cover should be on the side. It will say model and type and code. Go to sears direct and put the model and code in and should bring you up to the owners manual.
Jan 23, 2013 | Garden
I have a Briggs & Stratton 5HP Engine (Horizontal shaft) And it has the diaphragm carb on it. The last person to own it messed with the carb adjustments and it'll have trouble starting and idling...
2 turns out should get ya started adjust from there. If adjusting doesn't help you may need a new diaphragm. While you have diaphragm out blow through the 2 holes you'll see under diaphragm with air to hopefully avoid pulling carb off to clear screens on pick up tubes. Also check carb mounting screws through carb into tank. They frequently come loose on chippers and log splitters because of hard mount.
Oct 07, 2010 | Mtd Heavy Machinery
I need a manual for a 18 hp ohv Model 31D707
Best I can do is an llustrated Parts List HERE. For some reason, I can only find the Slovenian version of the operators manual. A call to Briggs and Stratton on (866) 927-3349 may help.
Oct 01, 2009 | Garden
Briggs & Stratton 135212/0129 - Homelite HL2500
the choke should be in the off position when running. YOU put the choke on to start it then when it starts u turn it off. If the choke is on the engine will die when reving
Aug 02, 2009 | Electrical Supplies
I went to start my go kart 5 hp 135212 model and when i did it trying running full thottle on its own i had to hurry up and turn it off fool with the throttle and the clutch but still the same.
check the throttle position and make sure that its not stuck in the open position if its ok check the internal components of the carburator inside the flapper may have fell off , its usual held in place with a screw or 2. check the govenor and all springs
Jul 08, 2009 | Ingersoll Rand SS3J5.5GB Wb Ir Portable...
I need a manual for a brother AX10 model
if your machine only types numbers, you have a bad keyboard or main board, and will need a repair shop for a cure.
Dec 29, 2008 | Office Equipment & Supplies
Electrical Supplies Logo
218 people viewed this question
Top Electrical Supplies Experts
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
